Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Feb 8, 2025 at 8:07 AM
    #3241
    easleycrawler
    easleycrawler Well-Known Member
    Travis
    Easley, South Carolina
    2014 RC Taco 4wd
    Appreciate it.
  2. Feb 8, 2025 at 8:46 AM
    #3242
    beto_sn
    beto_sn Well-Known Member
    Alverto
    Do depending on the size of the coupler will dictate if i have to swap it or not?
  3. Feb 8, 2025 at 8:55 AM
    #3243
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Not 100% sure here. I’ve never heard of people having issues with the coupler being too long. Your safest bet is to get a part time 4wd case out of an 07-14 FJ cruiser. Those will bolt right up and you don’t have to worry about it. The cases ive seen with a longer coupler are out of the 3rd gen 4runners
  4. Feb 8, 2025 at 9:06 AM
    #3244
    beto_sn
    Alverto
    Ok yes thanks you. the one i ordered is from a 07-14 part time tc off a fj cruiser. I just didnt know if i needed to swap out couplers being that my truck is the 4cyl 5sp and most information out is for a 4.0 auto/6sp. It doesn’t seem like a hard job anyways looking at turbos toybox video
  5. Feb 8, 2025 at 2:55 PM
    #3245
    6 gearT444E
    Deep South
    Herculiner Hootus
    never heard of this in anybody doing the swaps ever. Seems unnecessary. I’m betting that the output shaft of the transmission has enough take up to be able to slide the FJ case on in the factory state with the slightly longer fj coupler on there. It’s easy enough to try and make sure case mates up flush than trying to remove those couplers. They don’t come off easy and that guy in the video certainly Jerry rigged it
  6. Feb 8, 2025 at 3:39 PM
    #3246
    beto_sn
    Alverto
    I hope i dont have to remove it lol
    6 gearT444E[QUOTED] likes this.
  7. Feb 8, 2025 at 3:51 PM
    #3247
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    ive removed 2. one was a bitch and the other was really easy
  8. Feb 8, 2025 at 4:27 PM
    #3248
    beto_sn
    Alverto
    How did you do it?
  9. Feb 8, 2025 at 5:06 PM
    #3249
    wrmathis
    Bonaire, GA
    parts and stuff
    first one is on my build page https://www.tacomaworld.com/threads/my-build-thread-v3-0.128687/page-6#post-5224695 basically welded a bignut to the sleeve and then put a piece off all thread in it and made a slide hammer and it came right of.
    the second one i think i just hit it off with a chisel or punch. it was easy i know that. the first one we tried beating it off with a punch but it didnt move a bit.
  10. Feb 8, 2025 at 5:19 PM
    #3250
    BassAckwards
    Ive heated them up with a propane torch and the pulled it off with some channel locks.
    i just realized, I put an R156F in my truck so I think you guys with the 05-15 5spd R155F do need to remove the coupler. I remember removing mine and then having to put it back on bc my trans was output was different than expected. Apologies for the misinformation earlier.
    easleycrawler likes this.
  11. Feb 8, 2025 at 5:41 PM
    #3251
    6 gearT444E
    Deep South
    Herculiner Hootus
    a bearing splitter will make easy work of it. The old one just weld a large nut to and use a bolt to press it off the splines
  12. Feb 8, 2025 at 5:50 PM
    #3252
    easleycrawler
    Travis
    2014 RC Taco 4wd
    That's what I was thinking. Plus in the video I posted, that truck is a 4cyl 5spd.
  13. Feb 9, 2025 at 2:16 PM
    #3253
    beto_sn
    Alverto
    Ok thank you all for the help ! :)
  14. Feb 23, 2025 at 4:47 PM
    #3254
    beto_sn
    Alverto
    Ok guys, so turns out the TC i bought it off a 2012 4runner automatic manual shift. according to salvage yard it is the same from the FJ, is this true? Anyone know?
    Littles likes this.
  15. Feb 23, 2025 at 4:48 PM
    #3255
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Should be. I've got a 4Runner case (from a 2020 Trail Edition 4Runner)
    Littles and beto_sn[QUOTED] like this.
  16. Feb 23, 2025 at 4:49 PM
    #3256
    beto_sn
    Alverto
    Sweet thank you. You had to the front coupler swap as well?
  17. Feb 23, 2025 at 7:59 PM
    #3257
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    I swapped the input shaft due to mating it to a 6spd manual tranny. If you've got an auto tranny, you don't have to swap the shaft.
    beto_sn likes this.
  18. Feb 23, 2025 at 9:03 PM
    #3258
    beto_sn
    Alverto
    Truck is a manual but 5speed
  19. Feb 24, 2025 at 4:04 AM
    #3259
    easleycrawler
    Travis
    2014 RC Taco 4wd
    It's possible. I'm doing it to my 5 spd, I believe the coupler on our 5 spd is longer than the fj coupler.
  20. Feb 24, 2025 at 6:38 AM
    #3260
    beto_sn
    Alverto
    Im sorry for the confusion so that means we still need to do the coupler swap or no?
