Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Jan 6, 2019 at 9:49 AM
    #361
    weldo
    weldo Well-Known Member
    Pittsburgh, pa
    2014 base ac 2.7 5-speed 4x4
    Gotcha! Thanks guys!
    I’ll probably just obtain a shifter and cut the handles off and work from there. I’ve seen on this thread lots of guys mod the shifter to work with the auto tranny, but not as many set ups for the manual trans.
    So where’s a good place to look for boots? Is there something available for a twin stick or did you guys custom make something?
  2. Jan 6, 2019 at 11:45 AM
    #362
    6 gearT444E
    Deep South
    Herculiner Hootus
    I used the oem 6 speed fj cruiser boot. Sealed the tranny tunnel up nicely
  3. Jan 6, 2019 at 11:50 AM
    #363
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    One of these days I'm going to beg and plead and beg again just for your supervision while I do this to my truck. And try to bribe you... forgot that part.
  4. Jan 6, 2019 at 11:55 AM
    #364
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Me too!
  5. Jan 6, 2019 at 11:58 AM
    #365
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Does anyone have the PN and/or source of supply for an input shaft that'll fit a 6sp truck? If I do the swap I'd like to have the transfer case ready to go in when mine comes out.
    dborrer and ee1284 like this.
  6. Jan 6, 2019 at 1:14 PM
    #366
    weldo
    Pittsburgh, pa
    Dude, that's a great idea! I'll look into that. Thanks!
  7. Jan 6, 2019 at 1:35 PM
    #367
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    @05Taco4x4 installed an FJ case in his 4cyl, 5sp truck. He used the stock FJ shifter, rubber tunnel seal and shift boot. I don't think he had to do any modification to the stick. There's info in his Prerunner to 4x4 conversion thread. https://www.tacomaworld.com/threads/prerunner-to-4x4-conversion-guide.534480/
    05Taco4x4 likes this.
  8. Jan 6, 2019 at 1:56 PM
    #368
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Since I have 3 in a row I got a replacement aftermarket triple boot for a ford bronco. Had to make a custom base plate but it worked well.
    :D
    TacoFMS likes this.
  9. Jan 6, 2019 at 2:16 PM
    #369
    Manwithoutaplan
    ID
  10. Jan 6, 2019 at 2:17 PM
    #370
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    :wave:
  11. Jan 6, 2019 at 2:18 PM
    #371
    Manwithoutaplan
    ID
    Hello. I need to do this or sas
    HomerTaco likes this.
  12. Jan 6, 2019 at 6:35 PM
    #372
    SMKYTXN
    SMKYTXN If it can't be overdone it's not worth doing Vendor
    Nathan
    Houston
    11, 4dr, TRD Sport, 6sp
    DCFB
    I used the FROR twin sticks. With the use of a map gas torch I heated and bent them as needed to come up through just one of my cup holders. My case is also clocked at 15deg, so the sticks point more towards the passenger side.
    canadian bum, HomerTaco and Raincity like this.
  13. Jan 6, 2019 at 10:45 PM
    #373
    6 gearT444E
    Deep South
    Herculiner Hootus
    Bring the parts up here and we can knock it out any weekend!
    I've got plenty of "sick" days to use at work too lol
    TacoFMS[QUOTED] likes this.
  14. Jan 6, 2019 at 10:53 PM
    #374
    6 gearT444E
    Deep South
    Herculiner Hootus
    36201-35130. Or just find someone with a junk 6 spd t-case.
    ee1284 and vssman[QUOTED] like this.
  15. Jan 7, 2019 at 7:19 AM
    #375
    SMKYTXN
    Nathan
    Houston
    DCFB
    I have my original 6spd case sitting at the house.
  16. Jan 7, 2019 at 9:11 AM
    #376
    vssman
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    PM inbound...
  17. Jan 7, 2019 at 9:56 AM
    #377
    HolyHandGrenade
    HolyHandGrenade NOOB
    Tim
    Garage Most Likely
    DCFB (RIP)
    Some Stuff
    EDIT:
    I see a few people have liked this post recently. I just want to update it. The rubber roofing sealing the floor did not hold up. I’m going to do a real shift boot on the floor this time around.
    Kees likes this.
  18. Jan 7, 2019 at 4:43 PM
    #378
    weldo
    Pittsburgh, pa
    That shifter next to the trans is a crawl box I'm guessing? I'd like my shifters to come up in that location.
  19. Jan 20, 2019 at 2:38 PM
    #379
    Dvst8r1K
    Dvst8r1K Night-Taco
    Greg
    2nd gen Black Tacoma SS 4.0l 4-dr 4x4
    1" Toytec body-lift, K&N filter, coolant by-pass, mesh cotton screen delete, TTBS, WeatherTech in channel visors, 2.5" Rancho full suspension kit, Oil Catch Can, Toyo 285/70 A/T-2's, 21.5" light bar in grill, blacked-out grill, de-badged entire truck; and again, more to come.....
    Read all of thos post, and others. I have the 2013 TSS-auto with 4.0 I have a chance to get the transfer case. If I can source this case, because I have an auto, do I need to get the FJ axle tube?? Or can I just do the ADD?? I really want this case, but not sure what else is involved. How straight of a swap is this. People talking about changing bearings out and what not.. Help me please, in the simplest form, thanks. For real, thanks!!!
  20. Jan 20, 2019 at 3:15 PM
    #380
    Kees
    Kees Active Member
    Kees
    Southwestern Ontario, Canada
    2009 4x4 Access Cab 4 cyl 5 speed manual
    FJ case swap, twin stick conversion
    An automatic FJ transfer case should be a direct bolt on for your truck. You’ll need to wire in a switch to manually operate your ADD. There is no need to do the FJ axle tube swap if you don’t want to. I’ve done the swap and did a comprehensive write up. It’s here somewhere.
