Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Jul 10, 2019 at 7:48 PM
    #561
    6 gearT444E
    Deep South
    Herculiner Hootus
    Correct, and you'd have to figure out how to wire up the center differential lock actuator to be able to engage 4x4 instead of having the center differential active.
    BassAckwards[QUOTED] likes this.
  2. Jul 10, 2019 at 7:51 PM
    #562
    6 gearT444E
    Deep South
    Herculiner Hootus
    I did not say 3rd gen 4runner, i said 03 4runner which is 4th generation.
    And in case you did not read my post, the case from the 4runner is known as a full time transfer case, NOT a multi-mode case. Just trying to make sure people are clear so in the terminology. There are both multi-mode and full time cases in the 4th gen 4runners, I believe the multi-mode cases came in the TRD pro or some fancy model.
    Edit: I may be wrong on the year the manual shift was offered in the 4runner. The info out there is not very good lol
  3. Jul 10, 2019 at 8:11 PM
    #563
    YamaDirtrider
    YamaDirtrider Custom bumpers @FORT-ifyRigs
    Josh
    Elizabeth CO
    06 DCLB sport postrunner
    What hasn't been modified?
    Ah.... yea I read that wrong.
    In all my research I never saw them to have a manual shift. I thing that was the 01-02 years.
    The multimode for the 4th gen was only in the v6 while the v8 has full time awd.
    At least that how it was around the 04-07 years they might have made it only for the higher stuff towards the end. :notsure:
    6 gearT444E[QUOTED] likes this.
  4. Jul 10, 2019 at 8:42 PM
    #564
    6 gearT444E
    Deep South
    Herculiner Hootus
    That could be, so either way the best bet for tacomas that want the "most manual shifting" AWD case, it is to use the 6 speed FJ cruiser t-case. If you combine that with the front differential tube, you'll have AWD and 4x4 with only one electronic actuator.
  5. Jul 10, 2019 at 8:43 PM
    #565
    6 gearT444E
    Deep South
    Herculiner Hootus
  6. Jul 10, 2019 at 8:57 PM
    #566
    6 gearT444E
    Deep South
    Herculiner Hootus
    Or you can just buy a syclone and call it a day, I'm still searching for one of those that isn't a complete clapped out shitbox up here in the northeast LOL
  7. Jul 10, 2019 at 9:05 PM
    #567
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    one of those would be fun
  8. Jul 11, 2019 at 11:19 AM
    #568
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
  9. Aug 21, 2019 at 7:46 PM
    #569
    Chocolates
    Chocolates Well-Known Member
    Seattle or Bellingham
    05 DCLB
    Unicorns and glitter
    Been searching through this thread, looking for folks who kept the single shifter. Would like to see how folks made the J shift pattern work. I saw @ktmrdr setup, any others to show? Thank you!
  10. Aug 22, 2019 at 9:08 AM
    #570
    hoverlover
    hoverlover Never pet a burning dog.
    C-137, Laniakea, Virgo, Milky Way, Earth, USA, TX
    Things. Stuff. Lots of bad decisions.
    Mostly Zip-Ties
    SOLD 10/23
    I've got a FROR twin stick for an FJ case I won't be using if anyone wants it. I think they're $190 new and $30 for the boot. I'll do $200 for both, shipped. It's just chilling on the FJ case, not even tightened down. Literally brand new.
    Figured this might be the best place to drop this.
    Edit: added pic with boot
  11. Sep 11, 2019 at 3:17 AM
    #571
    TacoFMS
    Justin
    Louisa County, VA
    Have a question regarding this swap. My case came with all the plugs cut off. I know that in order to get the lights on the dash to function something has to be plugged in to the case to read what it is doing. Can I just unscrew the the plugs from the stock case and screw them in to the fj case? Bought the case from Wyatt and he has been anything but responsive since.
    Thanks in advance.
  12. Sep 11, 2019 at 6:10 AM
    #572
    wrmathis
    Bonaire, GA
    parts and stuff
    Yeah, you’re suppose to swap your sensors from stock case to the fj case
    TacoFMS[QUOTED] likes this.
  13. Sep 11, 2019 at 7:05 AM
    #573
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    What do folks do with the neutral position sensor? Leave it hanging or wire up a basic LED indicator?
  14. Sep 11, 2019 at 8:39 AM
    #574
    wrmathis
    Bonaire, GA
    parts and stuff
    If I remember right, I just used one of the sensors from the fj case just to plug the hole.
    Littles[QUOTED] likes this.
  15. Sep 11, 2019 at 8:40 AM
    #575
    wrmathis
    Bonaire, GA
    parts and stuff
    The forum forum from Rocksolidtoys going away really lost some good write ups and information
  16. Sep 11, 2019 at 11:24 AM
    #576
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    That's kinda what I figured. I'll see if theres a blank available to fill that hole in the transfer case but I'm pretty sure I dont care about a neutral indicator since I dont have one now, and ultimately I'll have 3 ways to get to neutral. I think I can probably live with a sensor wire dangling and connected to nothing. I've mentally blocked out more important things.
    I'm also super glad I re-read this entire thread again last night. I realized that I didnt properly grind off that little nub that sticks up on the front of the hi/lo shift rail when I did the twin stick mod...an issue that @HolyHandGrenade ran into. It's easy to overlook that nuance.
    HolyHandGrenade likes this.
  17. Sep 11, 2019 at 11:27 AM
    #577
    wrmathis
    Bonaire, GA
    parts and stuff
    Yeah my sensors that came with the case I just cut the wire off at the sensor so I had nothing dangling. Was just going to use a bolt but yeah couldn’t find one that size. Don’t think I have any pics of it. Let me see
  18. Sep 11, 2019 at 11:33 AM
    #578
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    While I appreciate it, honestly, dont waste your time. I can live with it. I will keep the FJ sensors in the FJ case and solder on the taco connectors to the hi/lo and 4wd sensors so I can sell the taco case with the taco sensors, but still have a quick disconnect on the fj tcase.
    HomerTaco and wrmathis[QUOTED] like this.
  19. Sep 14, 2019 at 6:45 AM
    #579
    TacoFMS
    Justin
    Louisa County, VA
    Ok, so the Tacoma case has two sensors and the fj has 3... what goes where and what is just a hole filler? Fj case has two on driver side and 1 on passenger, Tacoma is 2 on solenoid box.
  20. Sep 14, 2019 at 7:29 AM
    #580
    MY50cal
    MY50cal ---- Tread Lightly ---- Leave No Trace
    Mojo
    Camden County, NC
    09 PM RC / 05 SWB AC (RIP)
    Yep.
    IIRC, forward drivers side is the 4WD switch, and the passenger is the neutral switch. Aft drivers side gets the plug.
