Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Feb 15, 2020 at 9:50 AM
    #741
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    HomerTaco likes this.
  2. Feb 15, 2020 at 9:57 AM
    #742
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
  3. Feb 15, 2020 at 10:06 AM
    #743
    Littles
    Bryan
    Elizabeth, CO
    3 tons of fun
    HomerTaco and clupi like this.
  4. Feb 15, 2020 at 3:34 PM
    #744
    nednic
    nednic Active Member
    Nic
    2010 TRD S Double Cab Ext Bed
    Toytec Boss Toytec add-a-leaf SPC Control Arms Nitto 275/75/17 Ridge Grappler
    Ok, so the transfer case is in and runs smooth. Even got the sensor lights working. However, the ADD won’t kick over. Took it off to test the motor. Mine is very clean but I did the solder on the post just to ensure a good connection. The problem is that when I supply the motor power I can’t get it to spin unless I give the worm gear a slight budge with my finger while supplying power. Basically the voltage being applied isn’t enough to kick it over. I’ve tried running straight from the battery and checked the voltage with a volt meter so I know the supply isn’t the problem. Is it just time for a new ADD, or does anybody have any suggestions on anything else to try?
  5. Feb 15, 2020 at 3:40 PM
    #745
    jowybyo
    Joe
    Baltimore, MD
  6. Feb 15, 2020 at 3:43 PM
    #746
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Have you taken it apart, cleaned it and regreased it?
  7. Feb 15, 2020 at 4:37 PM
    #747
    nednic
    Nic
    yes, haven’t actually gone as far as to remove the motor from the plastic housing, but when I power the motor there is nothing attached to it (it’s not under any load), it’s just bolted into the housing. I’ll try removing it and see if the motor will spin free
  8. Feb 15, 2020 at 5:15 PM
    #748
    jowybyo
    Joe
    Baltimore, MD
    You can replace just the motor itself if you determine it’s messed up. I think they are just 12v 550series can motors. Probably $5.
  9. Feb 15, 2020 at 8:47 PM
    #749
    Rumrunners2k
    Rumrunners2k Well-Known Member
    Thanks! that was the goal
    HomerTaco[QUOTED] likes this.
  10. Feb 15, 2020 at 8:48 PM
    #750
    Rumrunners2k
    Get rid of the ADD. Replace with FJ diff tube and never look back
    6 gearT444E and HomerTaco like this.
  11. Feb 16, 2020 at 6:04 AM
    #751
    nednic
    Nic
    So what’s the different between doing the FJ tube swap or just sliding the fork over and reinstalling the ADD to where it’s just always on?
    dborrer and 10tacotrooper like this.
  12. Feb 16, 2020 at 7:52 AM
    #752
    clupi
    clupi Well-Known Member
    Sacramento Ca
    07 taco 4x4
    Did you do a add delete? Is it true that the fj case can fail from being over stressed if driven daily and on highway frequently?someone talked me out of it and I dont know which way to go! I have all the parts including the diff tube just waiting for the twin stick before I put in the t case
  13. Feb 16, 2020 at 8:40 AM
    #753
    6 gearT444E
    Deep South
    Herculiner Hootus
    you are correct that the spline counts are different, the rest of the internals are the same and it is still a VF2BM transfer case.
    Functionally nothing, but think of the weak points in the clutch hub and gearing between the CV compared to a single axle shaft and you will come to the right decision to make.
    That's also a bunch of BS. The auto transmission and manual transmission FJ cases are the same case minus the center differential on the manual transmission t-case. The gearing, oil pump, input shaft, output shafts are all the same so anyone that says that the auto transmission FJ case can fail from that is just wrong.
    TacoFMS and clupi[QUOTED] like this.
  14. Feb 16, 2020 at 9:02 AM
    #754
    clupi
    Sacramento Ca
    07 taco 4x4
    So are there guys who have ran the t cases with front diff spinning all time for years without issues?
  15. Feb 16, 2020 at 9:11 AM
    #755
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Yeah the guy you quoted has
  16. Feb 16, 2020 at 9:50 AM
    #756
    6 gearT444E
    Deep South
    Herculiner Hootus
    This VVVVV. I've had the setup for about 4 years now and no issues. Just drained my t-case fluid this weekend doing a clutch job and the fluid still looked tits.
  17. Feb 16, 2020 at 11:12 AM
    #757
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    If you are second guessing the fj tube, let me know. I could give it a good home... :D
    clupi[QUOTED] and 6 gearT444E like this.
  18. Feb 16, 2020 at 11:21 AM
    #758
    nednic
    Nic
    100% just the motor that’s an issue. Any leads on where to buy a replacement one? Thought I remembered a thread on this from a while back - remembered it gets pretty tricking making sure the gap for the coupling is correct.
  19. Feb 16, 2020 at 11:48 AM
    #759
    jowybyo
    Joe
    Baltimore, MD
    The motor should have a supplier p/n on the side of the can. Post that number here. Measure the diameter of the shaft (probably in mm). Post both of those things and I’ll find you a motor that should work.
    nednic[QUOTED] likes this.
  20. Feb 16, 2020 at 6:14 PM
    #760
    nednic
    Nic
    here are the measurements:
    Shaft DIA: 2.3mm
    Housing Length: 37.8mm
    Housing DIA: 27.5mm
    Two threaded holes on front face for bracket, 16mm apart and each 8mm from center.
    There is a part number printed, but it is severely faded and I can’t make out the numbers very well.
    My best guess at what it reads:
    RS-58511-5665
    RO679685
