Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Nov 1, 2020 at 9:34 PM
    #1221
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    I will try, take off the shifter tmrw and give it a go. Saw something in a FJ forum about the shift rods being misaligned..
  2. Nov 1, 2020 at 9:36 PM
    #1222
    ToyotaRoamer86
    Brandon
    Frisco, CO
    No just standard, no twin stick. Truck is 6MT, it everything works in 2WD/4HI/N but no 4LO.
  3. Nov 1, 2020 at 9:59 PM
    #1223
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Also, any tricks to making all the indicator lights work like factory?
  4. Nov 1, 2020 at 10:02 PM
    #1224
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Will it physically not shift? Or is it shifting place but not in low gear?
  5. Nov 1, 2020 at 10:39 PM
    #1225
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I have a (Modified) FJ clutch pedal, they're steel not plasteeik.
    I like the Dog leg gear shift, my 4Runner had one and I never much cared for the stock straight stick. Actually used my 3rd gen 4Runner stick 9n my Tacoma until I got the Core short Shifter, need to make me a dog leg rod for it as I dislike the chromed straight hurst stick.
    I need to do my FJ case mods too...
    :anonymous:
    rheath08[QUOTED] likes this.
  6. Nov 2, 2020 at 7:42 AM
    #1226
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Physically, it was doing 9t on the test run out of the truck. Then put back together all good. Still did it. Thought some force might slide it in to gear. No go...
  7. Nov 2, 2020 at 8:31 AM
    #1227
    hoarder23
    Shay
    NJ
    Scratches
    It was doing what?
    Out of the truck could you physically move the shifter through it's full range of motion or not?
    Does the H/N/L rail move through it's full range of motion?
  8. Nov 2, 2020 at 9:37 AM
    #1228
    ToyotaRoamer86
    Brandon
    Frisco, CO
    No
  9. Nov 2, 2020 at 9:41 AM
    #1229
    hoarder23
    Shay
    NJ
    Scratches
    Sounds like your only option will be to pull it and crack it open. Mine was able to smoothly shift outside of the truck, in a good case there will be nothing to resist the movement except a small detent that has not much holding power.
  10. Nov 2, 2020 at 10:04 AM
    #1230
    Sae68
    Sae68 Well-Known Member
    JimS
    Stockton, CA
    05 FJ 4x4 PreRunner
    I did something like that to my 4x4 conversion.
  11. Nov 2, 2020 at 10:07 AM
    #1231
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Nope, I just made connections from tcase and connected them straight to the instrument cluster. Everything works as should.
  12. Nov 2, 2020 at 10:12 AM
    #1232
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    https://www.tacomaworld.com/threads/lets-see-your-fj-case-swap.455278/page-32#post-22250696
    You can save yourself a little trouble by splicing the connectors to your 4wd ECU so that you don't have to run new wires all the way from the case and pull the gauge cluster, but that's entirely up to you. I can't promise your colors will be the same, but the pin positions should be. Test with a multmeter before you start cutting wires.
  13. Nov 2, 2020 at 10:56 AM
    #1233
    ToyotaRoamer86
    Brandon
    Frisco, CO
    The right rod will not go all the way back.
  14. Nov 2, 2020 at 11:19 AM
    #1234
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Im going to pull the allen key for the detent ball and spring off tonight. So of that is what is stopping up.
  15. Nov 2, 2020 at 11:45 AM
    #1235
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    I ran into the same issue. The rods are made so the left one has to be in the right orientation for the left one to go back up. Make sure the truck is in neutral when trying to shift the rods.
  16. Nov 2, 2020 at 5:07 PM
    #1236
    ToyotaRoamer86
    Brandon
    Frisco, CO
    Tried this too. Nada.. truck os on the lift currently. See if I can get the shifter detents..
  17. Nov 2, 2020 at 5:26 PM
    #1237
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Put the shifter back in and turn truck on and try to move it.
  18. Nov 2, 2020 at 5:51 PM
    #1238
    ToyotaRoamer86
    Brandon
    Frisco, CO
    No luck. Pulling the detent out.
  19. Nov 3, 2020 at 7:34 PM
    #1239
    Dex__43
    Dex__43 Well-Known Member
    Sam
    KCMO
    09 DCSB TRD OR 4x4 Swap
    4x4 Conversion 2.5 inch lifts with 33's Sliders Skids Front Runner racks Satoshi grill Patches and Stickers BAMF hybrid front HC tube rear Light bar 2 Hella's behind the grill Pioneer media player and subs Sleeping platform with lower storage for the bed
    What's up yall? Do we use the first or 2nd gen fj auto tcase for the 2nd gen auto tacoma?
  20. Nov 3, 2020 at 8:14 PM
    #1240
    hoarder23
    Shay
    NJ
    Scratches
    There's only one gen of FJ
