Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Mar 10, 2021 at 9:55 PM
    #1621
    Mech1txs
    Mech1txs Well-Known Member
    Troy
    Nor-Cal
    06 single cab manual FJ swapped add delete
    6 gear riddle me this , do you know if a 2nd gen single cab Tacoma’s roof is pre drilled with threaded holes for mounting a roof rack ?
  2. Mar 11, 2021 at 1:36 AM
    #1622
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Negative, access cab ain’t either. Only crew cabs
    6 gearT444E likes this.
  3. Mar 11, 2021 at 1:43 AM
    #1623
    Mech1txs
    Troy
    Nor-Cal
    Guess I’ll have to break out the rivnuts and drill some holes when the time comes.
  4. Mar 13, 2021 at 4:46 PM
    #1624
    PacoPreRunner
    PacoPreRunner Well-Known Member
    Dalton
    OC, CA
    06 V6 AC PostRunner
    4x4 swap, scented mirror ornament
    Does anyone know where I can find the the 6 pin connector on the 4WD harness that plugs into the ADD? I'm doing a PreRunner to 4x4 swap while wiring in my own switch to control the ADD using a DPDT relay and a switch, and that connector is the only non-generic part I need for the harness
  5. Mar 13, 2021 at 4:49 PM
    #1625
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    I do not but I think most people cut the connector off and wire it directly. That is what I plan to do
  6. Mar 13, 2021 at 6:31 PM
    #1626
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    I would just do a non add tube from an awd fj cruiser or gx470. Then u don’t have to worry about any electrical at all.
    6 gearT444E and TireFire like this.
  7. Mar 13, 2021 at 6:52 PM
    #1627
    TireFire
    Olympic Peninsula
    And you can sell the 4WD ECU and diff actuator
  8. Mar 14, 2021 at 11:31 AM
    #1628
    6 gearT444E
    Deep South
    Herculiner Hootus
    Pdugan6, HomerTaco and tacoma16 like this.
  9. Mar 14, 2021 at 6:45 PM
    #1629
    PacoPreRunner
    Dalton
    OC, CA
    06 V6 AC PostRunner
  10. Mar 15, 2021 at 8:55 AM
    #1630
    6 gearT444E
    Deep South
    Herculiner Hootus
    you're welcome, so now you know the "RST harness" that costs $180 is a $15 harness, a $10 switch, and maybe $10 worth of wire/connectors LOL. Make your own for $35 or pay $180 and never get a harness, I hear that fellow is out of business.
  11. Mar 15, 2021 at 9:13 AM
    #1631
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    you know where i can get a replacement switch? My led in mine went out.
  12. Mar 15, 2021 at 9:19 AM
    #1632
    6 gearT444E
    Deep South
    Herculiner Hootus
    Brian422[QUOTED] likes this.
  13. Mar 15, 2021 at 9:21 AM
    #1633
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    4th gen 4runner with the V8 as well. Those were all AWD and did not have ADD. 2003 - 2009.
  14. Mar 15, 2021 at 9:24 AM
    #1634
    Brian422
    Brian
    Birmingham, AL
    Not Stock
  15. Mar 15, 2021 at 9:35 AM
    #1635
    6 gearT444E
    Deep South
    Herculiner Hootus
    you're welcome, you can use my diagram for the pin outs on the switch. The only difference between the VJD2U66B and VLD2U66B is the VJ style is maintained and the VL is momentary spring return to center; otherwise they are identical.
  16. Mar 15, 2021 at 9:52 AM
    #1636
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    This is the switch im running now
    [​IMG][​IMG]
  17. Mar 15, 2021 at 11:16 AM
    #1637
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
    Well, with exception of new Y pipe that comes tomorrow. She’s all done! Had an issue with the first parts yard transmission; leaked like crazy from the bell housing and pulled 6 codes right from the start. Swapped it out with their warranty and installed a new one. Running great now.
    Now time to figure out how to attach the shift boot to the console and clean it up a bit.
  18. Mar 15, 2021 at 12:37 PM
    #1638
    6 gearT444E
    Deep South
    Herculiner Hootus
    Sweet, it should be a direct swap just keep the terminals labeled the same when you transfer over the new switch body.
  19. Mar 15, 2021 at 1:14 PM
    #1639
    pdaddy
    Preston
    Central AL
  20. Mar 15, 2021 at 1:28 PM
    #1640
    6 gearT444E
    Deep South
    Herculiner Hootus
    I’m assuming you maybe didn’t have that plug? The ADD just has male pins on it and no wires, be awful hard to connect something into that without an oem connector and have a solid connection.
