Let's see your FJ case swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACO828, Oct 11, 2016.
  1. Mar 19, 2021 at 5:35 PM
    #1661
    6 gearT444E
    Deep South
    Herculiner Hootus
    the middle is neutral, and actuator will be at whatever position it was before returned to neutral. If you want a maintained switch it would have 3 positions, for a momentary it would be 3 positions but automatically return to neutral.
    pdaddy[QUOTED] likes this.
  2. Mar 19, 2021 at 5:37 PM
    #1662
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Ohhh ok that helps a ton
    6 gearT444E[QUOTED] likes this.
  3. Mar 19, 2021 at 6:37 PM
    #1663
    Mech1txs
    Mech1txs Well-Known Member
    Troy
    Nor-Cal
    06 single cab manual FJ swapped add delete
    I just did an add delete easiest and simplest.
  4. Mar 21, 2021 at 8:54 PM
    #1664
    PacoPreRunner
    PacoPreRunner Well-Known Member
    Dalton
    OC, CA
    06 V6 AC PostRunner
    4x4 swap, scented mirror ornament
    Are 3 positions required for the switch? Essentially, would everything function with no short circuits with a two position DPDT switch left in the "ADD Engaged" or "ADD Disengaged" position full time?
  5. Mar 21, 2021 at 9:09 PM
    #1665
    6 gearT444E
    Deep South
    Herculiner Hootus
    It sure would, assuming you wire in the OEM limit switches (DL1 and DL2). My fear with that though is if the limit switch fails or is intermittent and you leave the switch to an engaged or disengaged position, you can over extend the timing on the actuator motor and easily burn it up. Having a DPDT with neutral "off" position ensure no voltage is present on the actuator motor once it's at the desired position.
    pdaddy likes this.
  6. Mar 22, 2021 at 6:54 AM
    #1666
    pdaddy
    Preston
    Central AL
    Didn’t know this was a thing. I ordered a 10 terminal 3 position switch from Otrattw. Thanks for helping out us dumb folk lol
    Brian422 likes this.
  7. Mar 22, 2021 at 7:48 AM
    #1667
    6 gearT444E
    Deep South
    Herculiner Hootus
    You are welcome. As you can see from this post just a couple of days ago, one cannot solely rely upon the ADD indication circuit, and bypassing the limit switch functions that are provided through the original Toyota design could cause an issue. If one of those limits fail, it will cost you a few hundred dollars if you hold the switch down to "engage" or "disengage", whereas you may be able to clean up the contacts otherwise. DL1 and DL2 will be for motor control, and ADD indicator are for the illumination on the switch for operator acknowledgement of engagement/disengagement. If you wire all of those up, there is little chance of user error to cause damage, but I am not going to tell you the actuator won't fail (because they will, they are pieces of shit :angrygirl:)
    dborrer, TacoFMS and pdaddy[QUOTED] like this.
  8. Mar 26, 2021 at 4:54 PM
    #1668
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I hate how the RST links are always dead since that seems to be where all the info is. Luckily this one was captured a single time in a web archive machine.
    https://web.archive.org/web/20150914154730/https://www.rocksolidtoys.com/forum/showthread.php?t=112
    (Just posting for future readers)
  9. Mar 26, 2021 at 5:06 PM
    #1669
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    907rx7, buyobuyo, TireFire and 2 others like this.
  10. Mar 26, 2021 at 5:11 PM
    #1670
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
  11. Mar 26, 2021 at 5:14 PM
    #1671
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm considering it. One of my friends down here is having nothing but actuator issues which got me thinking. An FJ case is only $230 on LKQ. I'd twin-stick it since I'm a manual and the case would be apart anyways, and for the ADD, I'd either just leave it in the engaged position, unplug it and remove the 4wd ECU or FJ tube it. One's free and one's $335.
  12. Mar 26, 2021 at 5:18 PM
    #1672
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    Do u have a crawl box?
  13. Mar 26, 2021 at 5:18 PM
    #1673
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I do not.
  14. Mar 26, 2021 at 5:21 PM
    #1674
    wrmathis
    Bonaire, GA
    parts and stuff
    Cool. Was gonna suggest if u got a crawl box, then don’t bother with the twin stick. Just because with a crawl box u have 2lo with that.
    But since u don’t have a crawl box twin stick away
    EatSleepTacos[QUOTED] likes this.
  15. Mar 26, 2021 at 5:23 PM
    #1675
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I was also considering keeping the ADD and using that for 2lo but if my end goal is reliability and elimination of actuators failing, then it seems like twin-stick is the way to go.
  16. Mar 26, 2021 at 7:07 PM
    #1676
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I ended up pulling the trigger on an FJ case, $300 shipped from LKQ via their Ebay store. I'm going to just keep it single stick as well as engage/unplug my ADD actuator instead of the FJ tube. Keep the cost low. I figure I've never had a need for 2lo before, probably don't need it now.
    dborrer and airmax233 like this.
  17. Mar 26, 2021 at 7:21 PM
    #1677
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    2 low is nice for between obstacles being able to turn
  18. Mar 26, 2021 at 7:23 PM
    #1678
    jowybyo
    Joe
    Baltimore, MD
    Sweet. Have you considered just wiring the ADD to a rocker switch? I think it’s pretty reliable if you also relocate the ADD breather up high.
  19. Mar 26, 2021 at 7:26 PM
    #1679
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I have considered that and that’s part of why I’m leaving the front end relatively untouched. That way if I want to, I can go back in the future and wire in the actuator to a switch. Keep the front end moving parts minimized and also get 2lo another way.
    I’ve seen some diagrams in here from Ant but god damn I need it explained to me like I’m a 5 year old. So that’s part of why I’m not doing that, I don’t feel like taking the time to learn that.
  20. Mar 26, 2021 at 7:30 PM
    #1680
    jowybyo
    Joe
    Baltimore, MD
    I can explain it to you. I wired mine that way. There’s a few ways to do it but I like using the built in limit switch to cut power once the ADD has reached the correct position. It’s requires pulling a few extra wires between the switch and ADD but prevents you from accidentally burning up the actuator motor if you forget to turn the switch off.
