Let's see your frugal DIY mods!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Nov 24, 2013.
  1. Mar 24, 2016 at 6:47 AM
    #2141
    Splat
    Splat Well-Known Member
    Pat
    MTL, Quebec
    2016 Black DCLB TRD Sport
    In progress...
    Can't wait to see the mounting brackets...
  2. Mar 24, 2016 at 6:49 AM
    #2142
    Thelgord
    Thelgord The Pantagonist
    Augusta, GA
    '13 TRD (OffRoad, 4x4)
    SOS Rocksliders, All Pro skid plate, Procomp add-a-leaf, Bilstein 5100 @ 1.75", CB, high-lift jack
    I am assuming this is more of a proof of concept than an attempt at a final product/solution. Can't wait to see where you go with it.
  3. Mar 26, 2016 at 8:58 PM
    #2143
    Spunky
    Spunky Well-Known Member
    Dean
    Minnesota
    2015 blue
    None yet
    image.jpg image.jpg 3 bucks for 3 boxes at the cigar store.
    LUSETACO[OP] likes this.
  4. Mar 27, 2016 at 5:30 AM
    #2144
    Jeffvt0508
    Jeffvt0508 Well-Known Member
    Jeff
    Anderson, SC
    2015 DCSB 4x4 trd offroad
    Ome 887s, dakars, lr uca,sliders, konig countersteer,
    Because RTT so much money but it's so worth not sleeping on the ground f7ad1733eac6a78f34dddd75cbb3d450_c3f23cf6469ed12aeaa8632528bd70d733fb2faa.jpg
    JimboAnz likes this.
  5. Mar 27, 2016 at 5:42 AM
    #2145
    taczilla
    taczilla I intend to live forever; so far.... so good!
    Marc
    PEC, Ontario, Canada
    2016 RAM Rebel
    2012 TRD Sport - STOLEN! / 2016 RAM Rebel
    Who makes that one?
  6. Mar 27, 2016 at 5:54 AM
    #2146
    Jeffvt0508
    Jeff
    Anderson, SC
    Unknown.. But talking to tepui and CVT .. It's either a Mombasa or old lab tent RTT.. But oddly enough tepui and CVT components work and fit on it..
  7. Mar 27, 2016 at 8:28 PM
    #2147
    GeoBruin
    GeoBruin Well-Known Member
    BJ
    Los Angeles
    White 2014 Double Cab TRD Off Road
    Here's the update on the pvc frame concept: it worked great! Used a 12x12 tarp from REI and stitched my own door. Needs a few tweaks but it worked well enough on its first outing.
    Chiro22, Alexk3303, Cr47524 and 14 others like this.
  8. Mar 27, 2016 at 8:35 PM
    #2148
    Pigpen
    Dan
    Northwest Montana
    You have way more head room than I have!
    Pabloeeto and Plain Jane Taco like this.
  9. Mar 27, 2016 at 8:36 PM
    #2149
    POOLGUY
    POOLGUY Well-Known Member
    JEFF
    ALABAMA
    2008 TRD Sport 6sp, 2015 TRD Offroad 6sp
    Dobinsons suspension
    Looks like it turned out pretty good. Do you have any pictures of the inside?
  10. Mar 28, 2016 at 2:53 AM
    #2150
    DrFunker
    DrFunker Well-Known Member
    The thread is smiling. Can you feel it? :D
  11. Mar 28, 2016 at 3:00 AM
    #2151
    LUSETACO
    LUSETACO [OP] Here for the Taco Pron
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    Spring mods are coming!!! :D
    DrFunker[QUOTED] likes this.
  12. Mar 28, 2016 at 4:17 AM
    #2152
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    Looks like the maiden voyage was a success! Nice work!!!
  13. Mar 28, 2016 at 6:10 AM
    #2153
    SilverJack
    SilverJack no one
    That is superb! One of the things I hate about tents is the lack of inside space. This design gives you so much more airspace that the walls should sweat less. Seems like your design is a lot easier to assemble than most of the truck tents I have seen.
  14. Mar 28, 2016 at 8:55 AM
    #2154
    Thelgord
    Augusta, GA
    Is this thing collapsable? Or do you drive like that?
  15. Mar 28, 2016 at 9:17 AM
    #2155
    SilverJack
    SilverJack no one
    According to him "as it is, it's all just press fit together. It breaks down into a duffle bag".
    I suppose you could take off the fabric and drive with an open frame. Not like PVC pipe is going to affect the aerodynamics much.
  16. Mar 28, 2016 at 10:02 AM
    #2156
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    No, but it would probably break apart at high speed ;)
    I might investigate something like this but with a foldable wood or aluminum frame.
  17. Mar 28, 2016 at 10:08 AM
    #2157
    Tunngavik
    Alberta, Canada
    Did you use a heavy duty sewing machine to stitch it together?
  18. Mar 28, 2016 at 5:30 PM
    #2158
    Splat
    Pat
    MTL, Quebec
    In progress...
    I travel with way too much stuff to be able to do this. Unload the canoe, cooking stuff, food, hunting stuff, paddling equipment, coolers, moose/deer/bear/grouse/fish meat (when we get lucky), then setup tent inside the truck is not for me. I would rather setup camp on the ground. WAAAAAY les trouble. You must travel lighter than me.
    It looks fun for a light weekend trip though! And congrats on the design!
    Jeffvt0508[QUOTED] likes this.
  19. Mar 30, 2016 at 12:37 PM
    #2159
    ERMB
    2002 Land Cruiser
    It's finally finished! :woot: here's my completed DIY cap-rack made from zink coated Unistrut and some aluminum scrap materials.
  20. Mar 30, 2016 at 2:09 PM
    #2160
    LUSETACO
    Dennis
    South Central Pee A
    2005 PIMP MOBILE
    Yes
    That came out awesome Scott! :cool:
    ERMB[QUOTED] likes this.
