Let's see your frugal DIY mods!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Nov 24, 2013.
  1. Dec 1, 2016 at 7:13 AM
    #2261
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    I did something very similar with my cap.
    https://www.tacomaworld.com/threads/lets-see-your-frugal-diy-mods.304174/page-61#post-10003050
  2. Dec 1, 2016 at 6:38 PM
    #2262
    joeyv141
    joeyv141 Well-Known Member
    Virginia
    08 DCLB 4x4 V6 TRD Sport
    Sig45[QUOTED] likes this.
  3. Jan 11, 2017 at 6:07 PM
    #2263
    nazlax10
    nazlax10 Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
  4. Jan 11, 2017 at 10:51 PM
    #2264
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    How did it turn out?
  5. Jan 11, 2017 at 11:03 PM
    #2265
    austinrauh
    austinrauh Well-Known Member
    Nevada
    05 AC OR
    I need some carpet...
    Crom[QUOTED] likes this.
  6. Jan 11, 2017 at 11:05 PM
    #2266
    5 Lug Fury
    5 Lug Fury Well-Known Member
    Kenny
    Knoxville, TN
    V8 Solid axle swapped 5 lug
    Got a lot of stuff lol
    Not sure how frugal but for $6 I'm sure getting a lot of use of it. Swapped a usb outlet with one of the oem 12v sockets
  7. Jan 12, 2017 at 7:49 AM
    #2267
    joeyv141
    Virginia
    Keep meaning to post something but I spent most of last month moving, I'll try to get some pictures tonight
  8. Jan 13, 2017 at 10:53 AM
    #2268
    orezona
    orezona title unspecified
    satan's skillet
    2006 TRD OR DCSB OMGWTFBBQ TL;DR
    WARRANTY VOIDED
    Kind of a stupid, no-brainer mod but after losing one of my shackles off my receiver hitch recovery mount the last time I went out seriously offroading, I did the zip tie mod:
    Not my pic but exactly the same thing. Like I said, pretty much a no-brainer but I'm learning shit so weeeeeeeeee!
  9. Jan 14, 2017 at 5:51 AM
    #2269
    joeyv141
    Virginia
    OK here y'all go. All links are below
    So I got aluminum angle iron and bent one end so it is flush for a top, I brazed that side(picture), last I threaded the now top with a 1/4-20 tap. With a washer and a matching threaded knob and bolt from Lowes that parts done. Thats the top to attach the light to.
    Next the bottom for it to connect to the rail. I got an aluminum spacer from work that was 1 inch long, drilled it out to 3/8 so the bolt would go though, I used a center punch and drilled a hole through so the spacer would fit through the angle iron, next I brazed both sides of where the spacer goes into the angle iron. This was actually rather hard as you need to heat the second side without liquidfing the first sides braze. I got a 3/8-16 threaded knob and bolt to go though the spacer, this threads into a T-Nut from Zoro.
    I did put a washer on both threaded knobs, the top one to go between the knob and the lights base and the bottom one to go between the know and the spacer.
    Lastly I spray painted it to closely match my truck, keep in mind that after spray painting you have to retap threads at the top as paint fills them up.
    20170114_075900.jpg 20170114_075908.jpg 20170114_075926.jpg 20170114_080026.jpg 20170114_080042.jpg 20170114_080047.jpg 20170114_080347.jpg 20170114_080443.jpg
    I couldnt find the link for the threaded knobs from Lowes but they are with the hardware in store.
    http://www.homedepot.com/p/Everbilt-1-in-x-36-in-Aluminum-Angle-with-1-8-in-Thick-801367/204273950
    http://www.homedepot.com/p/Bernzomatic-AL3-Aluminum-Brazing-and-Welding-Rods-334491/203710179
    https://www.lowes.com/pd/Utilitech-Pro-1-Light-10-Watt-LED-Portable-Work-Light/50196411
    https://www.zoro.com/te-co-t-slot-nut-1018-steel-base-78in-41406t/i/G8518361/ (DOUBLE CHECK THE MEASUREMENTS BEFORE ORDERING THIS NUT)
  10. Jan 14, 2017 at 7:32 AM
    #2270
    doghair
    doghair Well-Known Member
    Phoenix
    2013 Single Cab 4x4
    A drink kuzi lined with carpet makes a nice e-cig holder.
    I married my tacoma likes this.
  11. Jan 14, 2017 at 8:00 AM
    #2271
    doghair
    Phoenix
    2013 Single Cab 4x4
    Hers is another. Bulldog Holster with the retaining strap and metal clip removed. Staple some velcro onto the belt support. Tuck the retainer flap for the spare mag into the pouch to use the outside existing velcro to support the front. Fits perfect, out of sight, rock solid, easy to reach.
    Holster cost = $20
    G19 not included
    Not recommended if you live behind enemy lines
    Krim 559 and stbear like this.
  12. Jan 15, 2017 at 8:52 PM
    #2272
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    [/QUOTE]
    You know your truck already has a heater? :rolleyes:
    Great job on the false bottom center consol :thumbsup:
  13. Jan 15, 2017 at 8:52 PM
    #2273
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    upload_2017-1-15_23-50-4.jpgupload_2017-1-15_23-50-39.jpgMy $4 pop 'n lock for my shell. Well, $8 if you do both sides.
  14. Jan 16, 2017 at 6:10 AM
    #2274
    ERMB
    ERMB Well-Known Member
    2002 Land Cruiser
    [/QUOTE]
    Ummm....you seem very......familiar ? o_O
    5 Lug Fury likes this.
  15. Jan 16, 2017 at 5:56 PM
    #2275
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    This isn't really a mod, more of a product recommendation. But this seems like as good aplace as any to post.
    I got tired of Toyota's soft paint scratching under my door handles so I bought a set of precut clear protective film protectors. Pain in the ass to install and I really didn't really like the way they looked. On a whim I ordered a set of Cupeez magnetic protectors and just installed them. I like 'em! As per the directions it was necessary to heat them up so they are flexible. Instead of the recommended blow dryer I used a heat gun on the low settimg. Even though its only 19F outside the installation only took a few minutes . My only complaint is that Amazon sent stupid looking carbon fiber design protectors instead of the flat black I ordered. But the wife really likes them so a flat black set is inbound for me and she can have the silly ones on her Toyota.
    http://www.cupeez.com
    DrFunker and I married my tacoma like this.
  16. Jan 19, 2017 at 8:50 PM
    #2276
    Sudsman44
    Abington PA
    20170119_174342522_iOS.jpg Some scrap plywood, rail mounting hardware and a band saw. Fishing rod holder. Planning to add some eye screws to attach some Velcro straps for secure travel on the beach.
  17. Jan 19, 2017 at 9:20 PM
    #2277
    mcdee
    mcdee Well-Known Member
    mike
    Northern Cal
    12 PreRunner OffRoad TRD
    TRD center cap, quick bed mat, Gatekeeper, WTs, TRD skid plate from bpfab, plastidip emblems, security slider bar, interior LEDs, AFE Pro Dry air filter
    I came across Cupeez 3 or 4 years ago and have them on my Tacoma and wife's Murano. IMO great functional and cosmetic product, reasonably priced and the black accents looks good on my silver truck. I have 3 neighbor's buy them also, diamond rings are tough on door cups(?), gave me a good reason to limit diamond size.
  18. Jan 19, 2017 at 9:27 PM
    #2278
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Nice rod holder. I wish our trucks came with 9ft beds so I could do the same.
  19. Jan 19, 2017 at 9:29 PM
    #2279
    mateo_roberto
    mateo_roberto Well-Known Member
    Mateo
    San Diego, CA
    1995.5 Tijuana Teal 4x4
    Stock
    Bed organizer/sleeper thing. 3/4" single sheet of 5x5 w/ cutouts for all the crap that will enevitably move towards the cab inside the cubbys.
  20. Jan 20, 2017 at 3:40 AM
    #2280
    DrFunker
    DrFunker Well-Known Member
    Ummm....you seem very......familiar ? o_O[/QUOTE]
    :spy:
