Let's see your frugal DIY mods!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by LUSETACO, Nov 24, 2013.
  1. Dec 23, 2018 at 8:38 AM
    #2401
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    Tell me more. I'd like to use that spot for big mugs as well
  2. Dec 23, 2018 at 4:37 PM
    #2402
    Sudsman44
    Sudsman44 Well-Known Member
    Abington PA
    2012 Tacoma Access 4x4
    Ranch cap w/ rhinorack bars, 5100s, Deaver AAL, 2” front receiver, Matt Gecko bedlights, yadda yadda…
    Full disclosure, these rod holders were a total fail. Took up a lot of space in the cap, and the rods were constantly falling out. There is a kernel of an idea here, maybe someone else can do better, but I scrapped them early and put snowboard racks on the roof for transit to and from the beach.
  3. Dec 23, 2018 at 5:06 PM
    #2403
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    I wonder if you put the notches on the side closest to the window it might take up less space? I'd also add a lip to the notches closest to the cab (or just make them holes through the wood) and a rubber tie down to the notches closest to the tailgate so you could "lock" the rod in place.
    stbear likes this.
  4. Dec 24, 2018 at 7:25 PM
    #2404
    Asian Driver 14
    Asian Driver 14 Well-Known Member
    2012 Single Cab
    I have a $5 led light in my toolbox. Held on by velcro (could use more). It's battery powered so no wiring. However, they die faster in winter because batteries don't like cold
  5. Dec 25, 2018 at 4:01 AM
    #2405
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    You can install some long screws or bolts along the heavier handle side holding the rods and simply use bundgy balls to tie each rod down around the screws. OP, good idea though.
  6. Dec 26, 2018 at 8:22 PM
    #2406
    myfishtaco
    myfishtaco Active Member
    Denver, Co
    15 tacoma
    nothin special
    Borrowed an idea or 2 from this thread,(my new favorite, thanks LUSETACO:thumbsup:). Put locks on both bed compartment doors. After many adjustments they fit tighter than before. Also made a couple of new Quick fist mounts. Took a hammer to some old steel plates I had and for now they hold my ice scraper. Really happy with how those mounts turned out, now I'm just lookin for shit to hang
  7. Dec 26, 2018 at 8:25 PM
    #2407
    Asian Driver 14
    2012 Single Cab
    YE OLD ICE SCRAPER
    E-Paz 732NJ likes this.
  8. Dec 26, 2018 at 10:01 PM
    #2408
    deadpocketss
    deadpocketss Dingus
    Ian
    Colorado Springs, Colorado
    '10 Barcelona Red ACLB MT 2.7L PreRunner (Mia)
    She runs. What more can I ask for?
    Bedmat just marine carpeting? How does it hold up in weather? Looking to do something like this but I don't have a cover and I live somewhere with four seasons.
    How do false bottom?
  9. Dec 27, 2018 at 7:56 PM
    #2409
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    Had a moment between kids and the inlaws and saw your post. I got the general idea for here;
    Will post my tweaks when everyone goes leaves after the holidays.
  10. Dec 31, 2018 at 3:29 PM
    #2410
    BlkDakDave
    David
    CC TX
    The kids and the inlaws have all left, so here's my take on this mod. Mine is a little different, as I believe the original poster used 4" pvc. Since I had a good length of 3" pvc pipe laying around I used a 3" to 2" reducer I bought at Lowes. Here's the link to it https://www.lowes.com/pd/Charlotte-...-Schedule-40-Adapter-Coupling-Fitting/3132737.
    I cut a section of 3" pvc about 2 1/4 to 2 1/2" to slip inside the reducer. This cut section is what actually holds the tumbler. I do recall having to open up the ID of the 3" cut section for the tumbler to fit without sticking. Since the inside of the reducer is beveled the tumbler will be unstable. I figured I needed something flat but wouldn't give under the weight of a full drink. I also wanted to add some weight to the base of the cup holder to help secure the whole thing into the center console cup holder. I did some rummaging and found an old lead spacer along with several large fender washers and an leather coaster. The cup holder was then painted with primer. Here I wish I would have painted it before putting it all together. Once painted and dried I put some electrical tape and cut up an old wet suit to make a buffer between the new cup holder and the center console cup holder. I I also put a piece a electric wrap at the top of the new cup holder to prevent any rattling between the tumbler and the cup holder. I was a little concerned about the tumbler being top heavy in the cup holder, but it's never given me a reason to worry.
    IMG_20181231_160045.jpg IMG_20181231_153631.jpgIMG_20181231_153711.jpg IMG_20181231_153650 (1).jpg IMG_20181231_153755.jpg IMG_20180913_175532.jpg
    yota243, floodedkiwi and Tsinajinii like this.
  11. Jan 15, 2019 at 11:18 AM
    #2411
    Choco_Taco
    Choco_Taco Sarcastic AF
    Tim
    Fredericksburg, VA
    2009 Black DCSB TRD OR
    Can you send me a few pictures of your other quick fist mounts with the axe and shovel? I've been looking to do something like that. Did you build the brackets yourself? How did you mount? to your railing?
    EDIT: Just went back a few pages and saw you used some old skis. Nice repurposing!
  12. Jan 15, 2019 at 8:31 PM
    #2412
    myfishtaco
    Denver, Co
    15 tacoma
    nothin special
    Thanks Choco, hope that post helped, skis are light weight and very strong. Used "T" nuts in the bed rail to mount. I also mounted some ammo boxes the same way, here's some pics
  13. Jan 15, 2019 at 8:37 PM
    #2413
    myfishtaco
    Denver, Co
    15 tacoma
    nothin special
  14. Oct 7, 2019 at 10:26 AM
    #2414
    Jhammerson93
    Jhammerson93 Well-Known Member
    Justin
    05 tacoma SR5 4x4
    2.5" leveling kit, aftermarket 16" rims, 2" hub centric wheel spacers
    So after about 6 months, my light bar got a leak... I contacted Amazon and they sent me a new one and sent back the leaky light. About 6 of the lights on the replacement didn’t work so I called again. Since this was the 2nd defective product in a row, they said I could keep the 2nd one for free, and sent a 3rd! I decided to mount the defective one under my tire gate, and it fits like a glove!
    I do a lot of kayak fishing, so it’s perfect for backing my truck up to water and getting my gear ready in the dark! It also doubles as a f$&@ you light for tailgaters! In fact since I put it on, it’s very rare that anyone actually gets close to me. But when they do... it’s kind of funny to watch them back waaay off after turning it on for a second.
    stbear likes this.
  15. Oct 7, 2019 at 1:45 PM
    #2415
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Got to love the f-you light. Had one on my Jeep only used it a few times but man people move right out the way
    Jhammerson93 likes this.
  16. Oct 10, 2019 at 2:27 AM
    #2416
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Tailgaters beware but turning them on at the wrong time can bring some pretty steep fines.:eek:
    Jhammerson93[QUOTED] likes this.
  17. Oct 10, 2019 at 11:24 AM
    #2417
    Jhammerson93
    Justin
    05 tacoma SR5 4x4
    mod yeah for sure! I definitely keep that in mind when I use it. Also, it has definitely been the catalyst for some pretty severe road rage... so I always use it with caution. It’s just a friendly reminder when necessary, and if they don’t back off, I’ll leave it on lol. They usually get off of my ass one way or another!
    robssol[QUOTED] likes this.
