Let's see your quad / dirtbike
Discussion in 'All Terrain Vehicles' started by MyToyTaco, Oct 8, 2008.
  1. Jan 24, 2017 at 7:25 AM
    #1441
    allrsdup
    allrsdup Well-Known Member
    Sahuarita AZ.
    2018 dcsb trd offroad 4x4 Inferno
    Here is my new toy, 2016 RZR S 1000 my first sxs ive always had quads. Lovin it so far!
  2. Feb 1, 2017 at 4:19 PM
    #1442
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
  3. Feb 2, 2017 at 8:27 AM
    #1443
    Spintly
    Spintly Well-Known Member
    Greg
    Home of the Groundhog
    85 Single Cab Pickup & 2000 911
    @2004TacomaSR5
    Thanks for the compliment Jon. I had three Banshees before I bought the R (91,94 & 97). They are great machines. You are correct, the handling of an R is like nothing else. Whatever you want it to do, it does.
    Engine wise, I have a pretty new bottom end with OEM gears and shafts and for the cylinder, I'm running a Duncan PC2000 275 Powervalve with a 2001 CR 250 Ignition. The flywheel weight savings is huge with the CR ignition. Thing spools up so quick. I had an ESR 310 non-PV cylinder prior to this with a pump gas dome. Cheaper on fuel, but no where near as fun as the current setup.
    Search craiglist and your local classifieds. I drove all around the eastern half of the US looking at over 25 of them. Most were pretty clapped out and then, after a solid year of religious searching, this one came up 30 miles from my house. It was pretty hooked up when I bought it, but I added a lot over the years as well. Happy hunting.
    Riding Dirty likes this.
  4. Feb 6, 2017 at 1:32 PM
    #1444
    Cowboycq
    Cowboycq Active Member
    Cody
    96 2.7l 5 speed 4x4
  5. Feb 10, 2017 at 12:00 PM
    #1445
    Guat
    Guat Well-Known Member
    The Big NC
    Subscribed :bikewheelie2:
  6. Feb 10, 2017 at 3:35 PM
    #1446
    My02SC
    My02SC instigator
    Frank
    Jersey Shore ,PA
    2003 Tacoma,TRD
    2.5 lift, the usual that goes with it. Work in progress.
    2001 banshee
  7. Sep 5, 2017 at 6:46 PM
    #1447
    Grendel1972
    Grendel1972 Member
    Live in East Tn, Work in Va
    2011 Gray 4wd Tacoma
    I'm not as cool as you guys, but i have a 20170429_180945.jpg 20170715_164656.jpg MB200 Warrior painted OD green with a 6.5hp 200cc predator engine , a TAV30 torque converter and 60 tooth sprocket. It will do about 30-40mph on a paved road and climbs fairly well. My brother and I each have one and he also has two of the Coleman's 200U mini bikes one has a 60 tooth sprocket and TAV 30 set up and it leaves me like I'm sitting still, the other is stock. They are great fun and useful for getting around the property.
    Skidog1 likes this.
  8. Apr 3, 2018 at 8:42 AM
    #1448
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
  9. Apr 3, 2018 at 9:58 AM
    #1449
    Spintly
    Greg
    @Riding Dirty
    Thanks for the kind words. I've had it for quite some time now. I bought a YFZ450R a few years ago to replace it for normal trail rides, but it was no where near as fun - so I sold the 450.
    Problem areas:
    Frame - either stock or aftermarket, check for cracks thoroughly. Especially around the steering shaft mount on top, motor mounts and footpegs. Be hestitant if it has fresh paint or powder as you will not see the cracks.
    Stock Parts - many OEM parts are discontinued through Honda. Took me almost two years to find a good used shift shaft.
    The usual maintenance items - bearings, brakes fluids etc. The airfilter is a great place to look to see if it was taken care of.
    There are differences in years it is mostly broken down into two years 86-87 and 88-89. The frames are different along with a few other minor things. The main difference is the rear motor mount and swingarm. If the bolt goes through the frame AND swingarm then it is a 86-87. There are no major advantages to either setup. I believe the swingarm on 86-87 are longer than the 88-89.
    I would look for something with aftermarket suspension first before engine mods and an aftermarket frame. They are better built. Roll Design and Lager will be most expensive, but Arens made a great replacement frame. Most will be round tube, rather than square.
    One thing to remember is that these have been around for almost 30 years and you will find many that are total POS's and people will still want decent money. BE PATIENT. The right one is out there, you just have to find it. That takes time. Find a good one and then build it up from there, if that is what you want. Be prepared to spend some money for the right one as it will save you in the long run.
    Good luck and post a pic when you find one.
    Riding Dirty[QUOTED] likes this.
  10. Apr 3, 2018 at 9:40 PM
    #1450
    Riding Dirty
    PlastiDip
    Thanks for the good info! I will be keeping it in mind when I find one to actually be able to check out. I’m patient, and want a good one, not a piece of crap.
  11. Apr 18, 2018 at 4:58 AM
    #1451
    bw4706
    bw4706 Well-Known Member
    Illinois
    09 Toyota Tacoma DCSB
    Bilstein 6112's , Eibach Coils,Hankook Dyna Pro MT 265/75/16, SPC UCA's, General Spring HD leaf packs, De-Badged, Ranch Bed Cap, Mag Light Seat Mount driver and passenger, Mini Mag Console Mount,Hard wired GPS, LED's in and out, MB TKO Wheels, After market grill, Heated seats, Diff breather relocation mod, LED Under Hood Lighting, LED Bed Lights, Aux. LED Reverse Lights, 30" L.E.D. Light Bar, Redline Tuning Hood Struts & EZ Down Tailgate. 6 Circuit Aux. Fuse Panel W/Circuit Breaker. Front & Rear Facing DVR cameras, High Lift Jack Bed Rail Mount. Clazio Leather Seat Covers. All Pro Heavy Duty Rock Sliders, 4x4 illuminated switch mod, Ignition converted to Push to Start. Bushwacker fender flares, Cali Raised side projector ditch lights. Cali Raised L.E.D. fog lights. 3 x 3 L.E.D. rear spotlights , Anzo headlights and taillights.
    My 2016 Yamaha Wolverine. Great machine. Unfortunately I'm putting it up for sale after only 3 rides and 125 miles due to a work injury. Never even got to use the snow plow. Fun while it lasted.
  12. Aug 7, 2018 at 1:05 PM
    #1452
    Coolerman
    Coolerman Well-Known Member
    Dan
    Rochester, NY
    2005 4x4 SR5 AC / 2007 4x4 FJC / 2021 Tesla Y
    Pro/2015 Coil-overs n shocks, Icon progressive AAL, Firestone Ride-Rite Air Bags and cradles, ECGS clamshell bushing, Extang Solid Fold Tonneau cover, 2014 Navigation radio and backup camera, Wet Okole seat covers, rcbs204 lighted 4x4 switch, Weathertech digifit floor mats and in channel window vents, Scanguage II, Hayden 678 Trans cooler, Western Suburbanite plow, Pop and Lock PL8521
    I sold my 07 Polaris Sportsman a week ago and I am planning on picking up a new to me 2010 Polaris Scrambler this coming Saturday.
  13. Aug 17, 2018 at 2:44 PM
    #1453
    dan0mite
    dan0mite #NOTNORM
    Dan
    SC
    d00kie
    Check The Build Thread
    Brought home this bad boy last night on the cheap! 2016 Honda Foreman 500 4x4 with 214 hours on it. Some cosmetic damage (cracked plastics, broken rear taillight, front bumper pushed in a bit, etc.) but runs like a champ. Will drop in a few hundred more to fix the cosmetic stuff, buy a winch, and get it serviced and gone through...then she’ll be as good as new!
  14. Aug 23, 2018 at 1:53 PM
    #1454
    John Mc
    John Mc Well-Known Member
    Vermont
    2009 Tacoma SR5 4x4 Access Cab
    Added trans & engine oil coolers. (No factory tow pkg)
    One of my Coot ATVs. Made in the 60's. A fun, quirky antique ATV. 4WD, front and rear axles are driven by a ring and worm gear. Amphibious (not this one, since I have holes in the tubs, but my other one is water-tight). Articulated in the middle to keep all 4 wheels on the ground.
    The original models did not corner very well, due to the lack of any differentials. So later models offered the option of 4-wheel steering (this one was converted to 4WS a couple of years ago).
    This one looks rough, but runs well.
    This one belonged to a friend, fully restored. Shows the articulation:
    strider98, Riding Dirty and dan0mite like this.
  15. Sep 20, 2018 at 5:26 AM
    #1455
    Blais03
    Blais03 Guess I'll bring a spare wheel bearing...
    Nick
    Easthampton MA
    '08 Reg. Cab 4WD + '06 Reg. Cab 2WD
    Hope im not digging up an old thread here but id like some opinions.
    I have a 2006 Honda Foreman 500s 4x4 with 5k miles on it. Someone wants to buy it for $3900. Is this a good price? Should I take it and run or could I get more for it?
  16. Sep 20, 2018 at 6:02 AM
    #1456
    Coolerman
    Dan
    Rochester, NY
    Depends on if you want to sell it, and the condition of the wheeler. Nada shows an 06 Foreman value at less than the 3900, low retail being $2,225 and average retail $2,930. Those are just guidelines but still a starting point.
  17. Sep 20, 2018 at 6:06 AM
    #1457
    Blais03
    Nick
    Easthampton MA
    I like my quad. But I bought it for 3 grand and like the idea of not losing money on it.
  18. Sep 20, 2018 at 6:21 AM
    #1458
    Coolerman
    Dan
    Rochester, NY
    I recently sold my 07 Polaris that I had worked on more times than I wanted to. Then I upgraded to a 2010 Polaris that was in much better shape for just a few hundred bucks more. I guess its personal choice.
  19. Feb 6, 2019 at 3:50 PM
    #1459
    cahzbrah
    cahzbrah Well-Known Member
    Newcastle, WA
    21 TRD OR 6spd
  20. Feb 13, 2019 at 10:06 PM
    #1460
    Babybluetaco
    Babybluetaco Well-Known Member
    Austin
    Monroe, North Carolina
    09 5 lug
    Mine 2017
    Riding Dirty, dan0mite and vssman like this.
