Let's see your retrofit headlights!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hoverlover, Apr 8, 2019.
  1. May 13, 2021 at 10:40 AM
    #41
    Hyperbarics
    Hyperbarics Commercial Diver & Taco Driver
    Savannah, GA
    2013 DCSB - Nautical Blue Supremacist
    All that gorgeous amber, and you went with yellow fogs? The Lamin-X orange lense stickies match my DRL's almost perfectly.
    Your headlights are sick.
    Johnny DemonT[QUOTED] likes this.
  2. May 13, 2021 at 11:17 AM
    #42
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Sorry, I meant like it would be easier to watch a video on how it's done because you can see what they are doing. Here's a good one.
    BenSkiv[QUOTED] likes this.
  3. May 13, 2021 at 3:33 PM
    #43
    Johnny DemonT
    Johnny DemonT Well-Known Member
    SW Burbs of Chicago
    15 Silver DCLB
    Yellow fogs are LONG GONE haha. Updated look at 78,000 miles:thumbsup:
    Hyperbarics[QUOTED] likes this.
  4. May 15, 2021 at 7:37 AM
    #44
    Lil Taco Guy
    Lil Taco Guy Well-Known Member
    07 Tacoma, Base, manual
    Pro Comp, AAL, Bilstein, 3.73 LSD, intermitent wipers, cruise control, Wet Okole
    Hey, nice job on the headlights
    could you or anyone else please tell me what rubber/plastic "cup"
    did you use on the back of the headlights to cover the wiring
    Thanks in advance
  5. May 15, 2021 at 7:48 AM
    #45
    smoothwhitetaco
    smoothwhitetaco Well-Known Member
    2012 DCSB SR5 4X4
    2012 DCSB SR5 4X4
    Those look great, nice work!
  6. May 15, 2021 at 5:10 PM
    #46
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    Can't believe I haven't seen this thread!!
    RX350 projectors with clear lens, Osram Nighbreaker Laser bulbs, Hella Gen 3 ballasts, Turbine shrouds and Profile halos behind the shrouds. I chose to keep the chrome reflector and painted the shroud. I think it adds a black chrome look and doesn't just look like a solid color, kind of an OEM+ look to it. I also run the halos running light in amber (which also blinks with the turn signal) since it's unique compared to most cars having white now.
    This wall is about 100ft away for reference.
  7. Jan 28, 2022 at 7:39 AM
    #47
    BuildbyBarz
    BuildbyBarz Well-Known Member
    Johnny
    SrQ 941
    14 MGM DCSB
    Friends don’t let friends drive stock
    Clean. How did you wire your switch back to work like that ? I wonder if you can make the white come on only in park. And amber only in turn signal only.
  8. Jan 28, 2022 at 8:23 AM
    #48
    Midnight Blue
    Midnight Blue Well-Known Member
    Ben
    SoCal
    PreRunner, TRD Sport
    Morimoto projector retrofit w/ Profile halo DTRL, Morimoto LED fog lights, full custom stereo
    Thanks! I just used a standard 12V relay. I can't remember what I connected to each post on the relay at this point but I have it written down somewhere. But I think they are currently wired like you say: as long as I have the ignition switched on, the halos are on in white. When I use the turn signal, they flash in amber. When I turn on the headlights, the halos turn off but they will still flash amber if I use turn signals with the headlights on.
    BuildbyBarz[QUOTED] likes this.
  9. Jan 28, 2022 at 8:40 AM
    #49
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 1991 Toyota Pickup MT "Old Greg" 2021 4runner "Luna" 2023 Solar Octane MT "Solaris"
    I'm deciding if I want to so this to my 07 tacoma. But I live in a high snow area. And from what I hear most LED light replacements cake up with highway ice and slush because they don't produce any heat. I's this a real thing? Or just spoon fed whining?
  10. Jan 28, 2022 at 9:18 AM
    #50
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    I want to wire it up like yours because I want to make the led last longer I hear it goes bad. How is your holding up
  11. Jan 28, 2022 at 9:27 AM
    #51
    Midnight Blue
    Ben
    SoCal
    About a year ago, maybe a little more, one of the in-line components in the wiring for one of the halos went bad (I believe they're in line resistors). I emailed Retrofit Source, they warrantied it by sending me new wiring. So, the halos themselves are still going strong and perfect, as is the rest of the headlight setup.
  12. Jan 28, 2022 at 2:13 PM
    #52
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    Did you have to unseal the light to fix it? I’m thinking about using the same shroud as you
  13. Jan 28, 2022 at 2:18 PM
    #53
    Midnight Blue
    Ben
    SoCal
    No, it was just the wiring / wiring components. Since the halo its self was fine no unsealing needed
  14. Jan 28, 2022 at 2:20 PM
    #54
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    If you ever find the wiring notebook somewhere for the switch back please let us now. Thanks
    pinktaco808 likes this.
  15. Feb 1, 2022 at 8:47 AM
    #55
    TacoFergie
    Iowa
    If you want the switchback to function then you have to disable the DTRL circuit by cutting the wire or depinning it, it's on here somewhere. Then for the WHITE illumination wire you have to connect that to an ignition source that is on when the key is on using a fuse tap. A relay isn't necessarily needed as the the fuse tap is fused and switchback's run very low amperage. The AMBER illumination wire you simply tap into the blinker wire from each side.
    This is from another member here that does retrofits that may help you make the process a little easier.
    https://kustom54lighting.com/05-15-Toyota-Tacoma-Retrofit-Install_p_357.html
  16. Feb 1, 2022 at 8:58 AM
    #56
    Midnight Blue
    Ben
    SoCal
    What he is referring to is to have the halo's function as I have mine in that they are illuminated white for DTRL's, flash amber for turn signal then turn off when the headlights turn on. That's where the need for a relay comes in. Also, my truck did not have DTRL stock, so I didnt have to mess with disconnecting that which is why it was not part of my wiring job.
  17. Mar 16, 2022 at 8:53 AM
    #57
    Midnight Blue
    Ben
    SoCal
    Cleaning my workbench yesterday I found the wiring notes. This is specifically how I used the relay to run the halos such that they turn on when the key is turned on (switched ignition source) and turn off when I turn the headlights on, then turn back on when I turn the headlights off.
    12V relays are a standard part and all 5 terminals are specifically named, as such these notes will work for any standard 12V relay:
    Pin 30: switched source
    Pin 85: chasis ground
    Pin 86: headlight source / signal
    Pin 87: not used
    Pin 87a: halo 12V supply
    Hope this helps!
    Heres a quick pic of the where / how I mounted the relays. The orange one is the Morimoto relay that comes with the morimoto wiring kit for the headlights, then the relay for the halos
  18. Apr 5, 2022 at 4:08 AM
    #58
    BuildbyBarz
    Johnny
    SrQ 941
    14 MGM DCSB
    thank you
  19. Apr 5, 2022 at 4:49 AM
    #59
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
    Stupid question but I’m going to ask, is it ok to run your halos/demon eyes while headlights are on?
  20. Sep 29, 2022 at 4:16 PM
    #60
    20somethingwidataco
    20somethingwidataco Yes, my avatar is a real car.
    Will
    Washington State
    2008 AC TRD SPORT M/T
    ACLB 6 SPEED: Suspension: Bilstein 6112s (3rd perch) (F) Taco Lean Spacer Bilstein 5160s (R) TSB Leaf Pack Wheelers Offroad 3 leaf progressive AAL Wheelers Superbump Front Duro Bump U bolt flip kit Duro Bump progressive bump stop 3rd gen TRD offroad sway bar Wheels and Tires: Summit Racing Wheel Dakars (Polished Silver) 285/70r/17 Goodyear Wrangler Duratrax (Load D) "Performance": AFE CAI with custom powdercoated white filter cover MagnaFlow Performance Series Exhaust URD Cam gears XTP Intake Manifold Spacer OTT Torque Tune Brakes: Stoptech Slotted Rotors Stoptech Sport Ultra Composite Brake Pads Wheelers offroad SS brakelines (Front) Interior: Kenwood DD headunit Oem Subaru Kicker Tweeters Alpine 6x9 (Front) & 6.5 (rear) (With Taco tunes speaker mounts) Alpine 500 watt amp Sound Deadening (Doors, Rear "wall", Roof) ODI Rouge Shift Knob Weather Tech Mats Painted/wrapped trim pieces Console Safe Console Vault Gridx Organizer Ram Phone Mount Meso Customs dual color map lights Meso Customs dual color dome light Wet Okole seat covers (Black) Wet Okole center console cover (Black) 1" Seat Raisers (Driver & Passenger) AJT Designs climate control and 4x4 knobs Back Up Camera Lighting: Retrofits (Mini H1's, RGB Halos, 5500k Bulbs)(Lenses wrapped in self healing PPF) Diode Dynamics SS3 Max SAE (Yellow) Diode Dynamics SS5 Pro (Yellow) Driving lights (ditch lights) Anytime fog mod Rigid Industries E series 32" Combo bar (spot/flood) Diode Dynamics XPR Reverse Lights Diode Dynamics XP80 turn signals LED brake, parking lights and license plate lights Armor: Apex All Pro sliders BPF steel skid plate Bigass Trailer Hitch Camping/Storage: Leer canopy LED interior lighting Sleeping platform (Storage underneath) Removable snowboard Yakima mounts Extra D rings in bed (6 total) Custom Powder coated white snow shovel with custom bedrail mounts Amazon special Traction Boards Hi Lift 48" Jack with custom Rail mounts to accommodate my sleeper set up Other: All pro Bed Stiffeners Relentless Fab tailgate panel TRD sport graphics (Turd Gen spec) Anti Sun glare hood scoop wrap (Satin Black) Custom FleeBay grille 4 Hella supertones ECGS needle bearing Many Patches BPF shackle mount (With smittybuilt shackle) Tinted windows (Front/Rear + Full canopy)(18%) Meso Customs gasshole AVS inchannel window visors Diff Breather Kit 2012-2015 Oem Turn signal/folding mirrors (w/ sequential signals) 2012-2015 Oem LED taillights Full Size (285/70r17) spare DIY Larger Engine Splash Guards DIY Vipercut TRD radiator cap
    Bump, I'd like to see more. Thinking about going the LED route to clean up the wiring mess
