Let's see your silver 2nd gen taco
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bcmedic, Sep 18, 2008.
  1. Feb 1, 2019 at 4:13 AM
    #5641
    Billstacoma
    Billstacoma Member
    Bill
    Santa cruz Cali
    2006 Silver TRD Sport Tacoma
    5100 adjustable front shocks
    No not all just the 5100's and that's it.
  2. Feb 1, 2019 at 12:57 PM
    #5642
    Sully38
    Sully38 Active Member
    William
    2008 4 door Tacoma
    Absolutely love this truck.
    TMadTaco[QUOTED] likes this.
  3. Feb 1, 2019 at 1:04 PM
    #5643
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Pinch weld is more apt to cause issues than the cab mount if/when you flex the suspension. Cab mount rub makes noise. Pinch weld rub causes tire damage.
    I sweated BOTH before hand. Neither were as traumatic as I imagined.
    I cut my pinch weld off with a cut off wheel, then mig welded it....then sealed it. 2+ years ago/75k miles ago. No problems....no leaks.
    steveo27[QUOTED] likes this.
  4. Feb 1, 2019 at 1:10 PM
    #5644
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Biggest problem with 886s and 5100s is the rebound dampening is not well matched to that high of a spring rate. You can get a jackhammer effect. I did 887s (same rate as 885s just 5mm longer coil) when I added bumper/winch/skids. They gave me same ride height as 885s did prior to adding weight.
  5. Feb 1, 2019 at 3:46 PM
    #5645
    Billstacoma
    Billstacoma Member
    Bill
    Santa cruz Cali
    No that's it nothing special at all, I like the way it sounds going down the road, they will chew and spit out the mud that's for sure. Very fun I love my Taco.....
  6. Feb 2, 2019 at 8:54 AM
    #5646
    Mo Rutledge
    Mo Rutledge Member
    Morgan
    2006 Tacoma
    Blackoakled lights 3" Suspension Lift 33" Fuel Vectors Total chaos UCA Fox 2.5 coil overs Fox 2.5 rear Allprooffroad front/rear bumpers 5:29 nitro gears
    Need more snow!
    MotoEd, 13txtaco, Tacoma-Jack and 8 others like this.
  7. Feb 5, 2019 at 3:52 PM
    #5647
    drewbert41
    drewbert41 Well-Known Member
    Champaign, IL
    21 Cement DCSB 4x4 TRD OR
    put the rims on today
    MotoEd, 13txtaco, gravyboat and 3 others like this.
  8. Feb 5, 2019 at 7:03 PM
    #5648
    NamesDillon
    NamesDillon Well-Known Member
    Dillon
    2019 Off-road
  9. Feb 5, 2019 at 10:57 PM
    #5649
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    I’ll have to flex my set up out and see what happens. Everything fit without any modification. But I haven’t cycled the suspension completely yet.
  10. Feb 5, 2019 at 10:58 PM
    #5650
    steveo27
    Pittsburgh
  11. Feb 6, 2019 at 4:25 AM
    #5651
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    MotoEd, 13txtaco and bluezzy like this.
  12. Feb 6, 2019 at 5:46 AM
    #5652
    JakeSeig
    JakeSeig Well-Known Member
    Jake
    Georgia
    2006 TRD PreRunner
    Bilstein 5100's, 885, Deaver 1.5" AAL, 285/70r17
    Picking up some metal for the DIY bedrack!
  13. Feb 6, 2019 at 11:16 AM
    #5653
    Plucky was his name
    Plucky was his name Well-Known Member
    Carl
    Central East Texas
    2007 Reg Cab Taco 4x4 5-speed manual
    ARB Front Bumper, Wet Oakle Seat Covers, Aftermarket Stereo, OME suspension with Heavy Duty Dakar Leaf Springs
    She’s Silver, and very “regular”.
  14. Feb 6, 2019 at 8:23 PM
    #5654
    MethodMan11416
    MethodMan11416 Member
    Williamsport, PA
    2015 SR5 V6 Quad (Metallic Silver)
    2015 SR5. 3/2 Supreme Suspensions leveling kit, 17x9 Mayhem Warriors, 265 Duratracs and aftermarket running boards from eBayC135A7DF-7D1B-49D7-AC56-FF645CC43FE0.jpg
  15. Feb 7, 2019 at 2:01 AM
    #5655
    USMCtaco88
    USMCtaco88 Common sense isn't always a common trait
    My names Jeff
    Savannah, Georgia
    2015 Silver Sky DCSB TRD OR
    I did some stuff.
    So there was this puddle.... was a lot deeper than I thought :mudding:
  16. Feb 7, 2019 at 3:08 PM
    #5656
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    Any of you guys have Baja bumpers on your rig? I need an idea of what to get?
  17. Feb 18, 2019 at 12:42 PM
    #5657
    JakeSeig
    Jake
    Georgia
    2006 TRD PreRunner
    Update on the build
  18. Feb 18, 2019 at 12:44 PM
    #5658
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    What do you mean by baja bumpers?
  19. Feb 20, 2019 at 6:06 PM
    #5659
    Petit1989
    Petit1989 Well-Known Member
    2015 Tacoma trd
    Bilstein 5100s
    I’ll join to
    MotoEd, bluezzy and OverlAnderson like this.
  20. Feb 21, 2019 at 8:14 AM
    #5660
    jrow
    jrow Active Member
    Jerry
    Iowa
    2011 tacoma
    3 inch lift tires 275-85-18
