*Lets See Your Spindle Lifts*
Discussion in 'Suspension' started by THROUGHITALLDUDE, Mar 24, 2010.
  1. Dec 9, 2011 at 5:34 PM
    #281
    hudhawk
    hudhawk #texasforever
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    All-pro 3" standard leaf pack with billies set at .85 and you should be perfectly level.
  2. Dec 9, 2011 at 5:37 PM
    #282
    jbtacoo9
    jbtacoo9 ****&&***
    jay
    san clemente CA
    2011 prerunner dclb debaged lifted
    camburg spindle lift with 285/70/17 on method 303's satoshi grill bilsteins set at .85 2 jl 10" subs behind back seat dark tint all around
    i wanted it to sit just a little bit higher in the front would it be too much with all pro 3" and billies at 1.75?
  3. Dec 9, 2011 at 5:39 PM
    #283
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Nice looking ride man I would go with the All Pro leaf pack but im not so sure about settin the billys at 1.75 I would keep them ware there at.
  4. Dec 9, 2011 at 5:39 PM
    #284
    jaw154
    jaw154 Well-Known Member
    Jared
    CA
    2016 Quicksand TRD Off road
    Soon...
    Eh i wouldn't do that with a spindle lift. Just keep them at .85 :thumbsup:
  5. Dec 9, 2011 at 5:40 PM
    #285
    LarrysWorld
    LarrysWorld 05 Taquito
    Larry
    Rialto, CA
    05 Tacoma Reg Cab
    2in front lift HIDs 15" Steelies
    I'm new to this Spindle lift, my truck is completely stock. What exactly is a spindle kit?
    Sorry guys for sounding like an idiot haha
  6. Dec 9, 2011 at 5:40 PM
    #286
    Manwithoutaplan
    ID
    here is my spindle lift :D
  7. Dec 9, 2011 at 5:42 PM
    #287
    jbtacoo9
    jbtacoo9 ****&&***
    jay
    san clemente CA
    alright thanks hopefully il get those all pros pretty soon!
  8. Dec 9, 2011 at 6:36 PM
    #288
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    What size tires? ^
  9. Jan 19, 2012 at 7:36 AM
    #289
    BlueSteel
    BlueSteel Well-Known Member
    James
    Houston, TX
    2009 Magnetic Grey TRD Sport
    Well I have got most of the suspension on but I'm just waiting on my Fox CO to come back in the mail. I had a small leak on the hose fitting at the flange nut. I had to send it back to ORW to get the compression back. The TC LCA install created a little more fabricating on the Camburg Spindle Lower ball joint bolts (needed to be shortened). And, I had to weld in a spacer for the bump stop.
    I have to say that the rear stock brakelines were hell to install. Toyota over tightened the fitting and the flange on the stock lines would not come loose. I eventually just took a cutting tool and cut the stock hose fitting and had to pry it off. The front extended brake lines that JP sells here needed to be notched more with a cutting tool to accept the stock bracket mounting plate.
    All in all the setup looks great...pics to come!
  10. Jan 19, 2012 at 7:46 AM
    #290
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
  11. Jan 19, 2012 at 7:47 AM
    #291
    yosh2000
    yosh2000 Well-Known Member
    CO
    '17 Tundra CM 5.7
    ummmm....there are all kinds of pics in this thread....bro...!!
  12. Jan 19, 2012 at 7:55 AM
    #292
    BlueSteel
    James
    Houston, TX
    I can take some pics of what I was talking about later this evening. My truck is still sitting over at my uncle's shop on jack stands. I just need to bleed the brakes, finish painting the front calipers, and get the CO back on. The Fox CO is suppose to be back Saturday.
  13. Jan 19, 2012 at 8:03 AM
    #293
    hudhawk
    Hudson
    California
    TRD Off Road
    Rust, lots of rust
    Ummmm thanks, I know that, I was referring to the post directly above mine. But thanks for your concern.
  14. Jan 19, 2012 at 8:14 AM
    #294
    kinkrider101
    santa barbara
    wheels and tires
    When you p ull the front lines doesn't a ton of fluid gush out? Or does it slowly drip?
  15. Jan 19, 2012 at 8:24 AM
    #295
    BlueSteel
    James
    Houston, TX
    It isn't that much fluid but it will drip a small amount to stain your concrete and get on your LCA's/bumpstop. It is a good idea to a have a drip pan or a leftover coffee container to catch the residual fluid. I would have some cleaner or degreaser on hand to wipe off any brake fluid on painted surfaces because it will eat through it if you left it there overnight.
  16. Jun 20, 2012 at 5:30 PM
    #296
    senor taco
    senor taco ROLLIN ON RUST
    Monterey Bay, Ca
    O7 Tacoma PreRunner SR5
    17in fj cruiser wheels satoshi grille with devil horns emblem Single in double out 50 series flowmaster with stainless tips Kenwod ddx512 double din touch screen DVD reciver with a single Rockford fosgate 12 in sub with an alpine amp tinted tail and third break light silverstar head and fog lights k&n drop in Billy 5100's on all 4 corners with a 2"AAL
    I just ordered some maxtrac spindles. I'm thinking of replacing my stock coils w/OME 883's w/5100's set at 0. Do you guys think I'll have major BRO lean with just my 2' aal?:confused:
  17. Jun 20, 2012 at 9:39 PM
    #297
    mrw3685
    mrw3685 Well-Known Member
    TX by way of KS
    08 Prerunner TRD
    Maxtrac Spindles, Bilstein 5100s all around, set at .85, Allpro Expedition Leaf Pack, Procomp 7036 17x9, w/Nitto Trail Grappler 285/70/17, Extended Steel Braided Brake Lines, Red-Line Hood lift, Relocated Trailer Connection, Trimmed Front Fender.
    Yes, Allpro Expedition Leaf Packs will leave you perfectly level with Maxtrac Spindles and 5100s set at .85, anything less in the back and you'll have bro lean.
  18. Jun 27, 2012 at 11:19 AM
    #298
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    Anybody in here have a longish term review of the all pro expos? I see a lot of y'all are running them
  19. Jun 27, 2012 at 11:30 AM
    #299
    tacomonazul
    tacomonazul Well-Known Member
    Luis
    SOCAL
    07 DCSB LT/4LINK
    http://www.tacomaworld.com/forum/2nd-gen-builds/227832-my-never-end-build.html
    I want new spindles that arent for liftin just that are longer, any recommendation?
  20. Jun 27, 2012 at 11:32 AM
    #300
    imsikotic
    imsikotic If u cant stand behind our troops. Stand in front
    Randy
    Temecula, Ca
    06 TRD Sport DesertRunner
    4" Camburg Race Spindles and Icon 2.5" ext travel Coilovers in the front for about 5"of lift and for the rear All-Pro 3" leaf pack and Fox 2.0 Resi's converted to piggyback and custom valved by DownSouth Motorsports. 17x9" KMC XD Addicts w/ 4.5 inch Backspacing and -12 Offset. Wrangler Duratracs 285/70/17. K&N CAI, Exhaust, Carriage Works Billet Grill, Custom Bed bar with ProComp fog lights,DirtKing Fabrication front bumper w/ 3 HID converted Hellas, Demello rear PreRunner bumper, Tinted windows, Full System w/ 2 10s, Garmin 265WT, ClearHLM. Theres more I just cant think of it right now.
