Let's talk Bathrooms!!
Discussion in 'Off-Topic Discussion' started by Janster, Mar 23, 2010.
  1. Nov 22, 2010 at 2:18 PM
    #81
    mntbiker2008
    mntbiker2008 First I derp.. then I herp
    Aaron
    Cincinnati, OH
    93 Pick up 4x4 (sold), 10' Mazda 3
    i poop and shower in mine.... :cool:
    thats all.
  2. Nov 22, 2010 at 3:35 PM
    #82
    surfsupl
    surfsupl Well-Known Member
    Gregg
    WestCoast
    I DONT CARE IF IT'S A RE-POST
    Rear Diff Breather~ 5100's ~Fog Light Anytime~Tint~TRD Seat Covers~Weather Tech's~Pioneer H.U.~Lift~Eibach Springs~LED's......blah...blah...blah
    Looks good................I like your sink/cabinet combo...........
  3. Nov 22, 2010 at 3:38 PM
    #83
    mntbiker2008
    Aaron
    Cincinnati, OH
    x2. looks real good. I helped my step dad do a complete gut/re build.... it totally sucked but it was worth it in the end. plus you learn a lot as you go.
  4. Nov 22, 2010 at 3:39 PM
    #84
    surfsupl
    Gregg
    WestCoast
    I wish more people would do shut off valves like that........when I get around to doing my house I will do the same w/most or not all of the plumbing
  5. Nov 22, 2010 at 4:09 PM
    #85
    Janster
    Janster [OP] Old & Forgetful
    Jandy
    Lancaster, PA
    Very nice! Our tile design will be similar to yours with straight (12") tiles on the bottom with border and diamonds (6") above it and bullnose. We're not going to the ceiling - just to keep costs down. That sink/cabinet is nice!! That's a hellish amount of work!!! But definately worth it in the end!!
  6. Nov 23, 2010 at 4:37 AM
    #86
    84Hilux
    84Hilux Well-Known Member
    Gary
    Vancouver, Canada
    09 SR5 Access Cab V6 4X4
    Stock Fog Lights, Camera Mirror, Arrow Canopy, Lighted 4x4switch, Weathertech Mats (Black), Wet Okoles- Black/Charcoal, Alpine CDA117 Headunit/ Alpine PDX4150 Amp/Alpine PDX M6 Amp/ Hybrid Legatia SE Components/ JL 10W6V2 Subwoofer/ Prototype MR Marv Sub Enclosure
    I worked for 12 years in the plumbing wholesale industry. I think it has already been mentioned that frameless tub and shower doors are not really frameless- they just have no frame around the glass panels. The tile guys have already given good advice about sealing your grout to reduce staining/mildew. An important consideration is the type of backing board under the tiles. Use water repellent green board drywall or the newest thing seems to be cement board to stop mold growth if any water gets behind the tiles. Regarding whirlpool tubs- Acrylic is the best because if it gets scratched, the color is the same all the way through the material (not white underneath like gelcoat fibreglass). Insulation under the tub is useful so the tub holds its heat for longer. As far as fixtures- chrome is the most durable finish! If you go for a more exotic brass or brushed texture- be sure to never use ammonia based cleaners on it. These finishes are covered with clearcoat and can be damaged by harsh cleaners. Also, it is worth spending a little extra for pressure balanced valves. These valves have max temp control settings and are built to compensate for people flushing toilets etc. in other parts of the house. They also usually have integral stops to allow you to shut off the water to the valve for maintenance. Excellent brand names- Moen,Kohler,Delta,American Standard,Grohe. Also, don't scrimp on your tub waste and overflow assembly- it is hard to get at for maintenance and is a common source of leaks.
  7. Nov 23, 2010 at 12:21 PM
    #87
    surfsupl
    Gregg
    WestCoast
    You certainly know your shit!:thumbsup:
  8. Nov 23, 2010 at 6:50 PM
    #88
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I would do this if using unfaced batt insulation but it looks like Kraft faced batt was used. I wouldn't want to risk the chance of trapping moisture between a vapor barrier and the Kraft faced paper.
  9. Nov 23, 2010 at 8:13 PM
    #89
    Janster
    Jandy
    Lancaster, PA
    That's the original insulation that was under the drywall. I have no idea what it is (and have no clue about all that stuff anyway :confused:). We're leaving it there....as is.
    That is an outside wall - however, it's aside the attic that's above the garage. So, it's not a main exterior wall.
  10. Nov 30, 2010 at 4:22 AM
    #90
    Janster
    Jandy
    Lancaster, PA
    Some updated picts. The bottom half of the tile is done. The top half (diamond design) will be the hardest. Amazing how the tile makes the tub area look smaller. Perhaps its because of the darker color?.
  11. Dec 1, 2010 at 7:35 AM
    #91
    Janster
    Jandy
    Lancaster, PA
    Thanks!!
    I can't believe that I posted this back in March. Procrastination big time!!
    He should be grouting on THursday and then start working on the floor/vanities.
    Aside from that...I had a guy come over to do a 'go-over' on our propane furnace. What I thought was just a maintenance call turned out to be a fiasco. Currently the furnace is unusable and the guys been replaceing this part, that part, and it still isn't working right. WTF? Not a good time for all this shit to come together!!
    (sorry, just a vent!).
  12. Dec 1, 2010 at 3:12 PM
    #92
    Janster
    Jandy
    Lancaster, PA
    It's electric. The propane furnace is our supplemental heat. We normally have it set to run the propane furnace when the temp outside is 40degrees or lower. It's been doing a good job keeping the house warm so far (Thank God) - although only a couple days/nights where its been in the 20's.
  13. Dec 2, 2010 at 3:34 PM
    #93
    Janster
    Jandy
    Lancaster, PA
    Just in case anyone is still reading....
    I think I'm in love! I was somewhat worried about how everything was gonna look (grout colors/etc). But now after seeing it, I am totally excited and love it!!
  14. Dec 11, 2010 at 5:07 PM
    #94
    Xewkija631
    Xewkija631 Well-Known Member
    LI,NY
    2011 BLACK DC TRD OFF ROAD
    Very nice, however I would have gotten a nice steam room with shower and river rock floor =]
  15. Dec 26, 2010 at 7:26 AM
    #95
    Janster
    Jandy
    Lancaster, PA
    Thought I'd make a final post (for the most part). The bathroom is 95% complete with a few minor things left - touchup, hardware, window treatments, blinds, & decorating kinda stuff left.
    We have two vanities that are identicle but I didn't take pictures of the other one. The bathroom turned out GREAT!! Cost a little bit more than we expected, but we're happy its finally done. Our installer guy/friend, did a great job!! We'll probably hire him back again when we're ready to re-do the kitchen!
    Here are the old picts:
    http://www.lieblweb.com/Temporary/Bathroom/old/
    Here are the new picts:
    http://www.lieblweb.com/Temporary/Bathroom/new/
  16. Dec 30, 2010 at 8:13 PM
    #96
    MattN03
    MattN03 Well-Known Member
    Bluegrass State
    SOLD: 07 DC 4x4 TRD Off-Road
    20% window tint, beep mod, hardwired V1, TSB springs, AVS Bugshield-21803, USA Spec PA15, OEM Tacoma scuff plates, Weathertech mats, Truxedo LoPro, TRD skid, GY Duratrac's 265/75/16 C Range, locker mod (switch method)
    Great job! If you don't mind me asking, about how much does a renovation like that cost?
  17. Dec 31, 2010 at 5:21 AM
    #97
    Janster
    Jandy
    Lancaster, PA
    Thanks!
    I don't have exact details....but I'd venture to say around $10K. Half the cost was in Labor ($35 an hour for our installer).
    Obviously, you can do this A LOT cheaper and by doing the work yourself. Considering the circumstances - we wanted this done as soon as we could. You can go inexpensive or rippin expensive. We didn't skimp but we kept it affordable for us (we're not picky but like to have nice things). We learned a lot....should've done this, should've done that.... but now we know.
    I'm super happy with it. It's the most 'modern' part of our house right now. Kitchen is next (next couple years). I think we'll do the kitchen completely on our own. :thumbsup:
  18. Dec 31, 2010 at 6:39 AM
    #98
    MurphMan
    MurphMan Senility Rocks!
    Murph
    Maine
    '08 Tacoma TRD Sport
    * AFE Stage 2 XP CAI System * Westin Platinum Series Black Step Bars * TruXedo Lo Pro QT Soft Roll-Up Tonneau * Dee Zee Heavyweight Truck Bed Mat * WeatherTech Extreme-Duty Floor Liners * WeatherTech In-Channel Window Visors * Sony Xplod CDX-GT81UW Receiver * Sony Xplod 2-way speakers * Boss Audio BASS600 Amplified Subwoofer * Billet Grille Mod
    Looks great! I've gotten some great ideas following this thread. Thanks for sharing.
  19. Dec 31, 2010 at 8:02 AM
    #99
    Janster
    Jandy
    Lancaster, PA
    While I've got some of you 'tile' gurus around..... I'm really interested in how to clean or what cautions I need in cleaning this new tile.
    Previously, I had the glossy colored ceramic (?) tile you see in every bathroom. It would get coated with soap scum and I'd use soap scum cleaners & a sponge.
    This new tile is porcelain with Bostik True Color grout. The tile looks like stone and is not glossy (stone feel). I'm not even sure I'll notice soap scum building up on it.... ?? When I get a chance, I'll try to find manufacturer recommendations. Just thought I'd ask everyone here.
  20. Dec 31, 2010 at 10:51 AM
    #100
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Nice colour combo Janster . Your installer did a good job of wrapping the diamond pattern around the corners .
