Let's talk batteries
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Wixo, Feb 27, 2019.
  1. Jun 8, 2020 at 7:53 AM
    #81
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
  2. Jun 8, 2020 at 9:32 AM
    #82
    adk_tacoma
    adk_tacoma Well-Known Member
    Joe
    Waterford, NY
    2016 quicksand tacoma sr5
    Westin outdoors man winch brush guard, custom switch board, Custom machined tow hooks, 255/85/r16 tires, trd shocks and struts, oba in bed cubby, ladder rack, JDUB skid plate
  3. Jun 8, 2020 at 11:47 AM
    #83
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I believe they do. One of the reasons I steered away from them.
  4. Jun 8, 2020 at 12:07 PM
    #84
    adk_tacoma
    Joe
    Waterford, NY
    Hmm. What will happen without the charger?
  5. Jun 8, 2020 at 12:10 PM
    #85
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    the memory of the battery would get stuck at around 80%.
  6. Jun 8, 2020 at 12:25 PM
    #86
    thedriza
    thedriza Well-Known Member
    Portland, OR
    2017 Tacoma DCSB
    5.29 gears, OME HD lift, OVTune
  7. Jun 8, 2020 at 12:35 PM
    #87
    adk_tacoma
    Joe
    Waterford, NY
    Then its probably too late for my battery. It was bought for a '05 dodge dakota in 2012, out lasted that truck and was stuffed into my '16 taco in 2017 when I added the winch from that same dodge.
    shakerhood likes this.
  8. Jun 8, 2020 at 12:37 PM
    #88
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    maybe, maybe not...you could try a deep discharge on the battery then put it on a charger and see what happens...truth be told, you probably won't notice a difference between a 100% charged and 80% charged AGM, until you start discharging it on a regular basis.
  9. Jun 9, 2020 at 3:36 AM
    #89
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    Tuned, geared, armored, BP51s...
    I have 2x odyssey pc1400 g35s. I use a duralast agm charger from AutoZone and it seems to work great. Why do we need a specific odessy charger?
    And now that VF has allowed us to alter the alternator settings, my truck charges them at 14.5-6v
  10. Jun 9, 2020 at 4:04 AM
    #90
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    AGM is the way to go, You can get a good AGM for $150.
    https://www.walmart.com/ip/EverStart-Platinum-AGM-Battery-Group-Size-24F/286630898
    Wixo[QUOTED][OP] likes this.
  11. Jun 9, 2020 at 4:16 AM
    #91
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
  12. Jun 9, 2020 at 5:45 AM
    #92
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I’m concerned that on long trips, charging the battery at high voltage for long periods will actually overcharge them. At some point they get full and they need to be on a float charge at around 13.6-13.8v. Otherwise you can damage them by overcharging.
    b3itz[QUOTED] likes this.
  13. Jun 9, 2020 at 6:03 AM
    #93
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I don't disagree with you.
    Quick update - i've had my VF altered tune running @ 14.5-6v for about a week with some normal puttering around town - i probably burned a half tank of gas.
    My batteries were at 95% this morning rather than the 85-90% previously from the stock 13.5v.
    I'm wondering about getting some $30 solar AGM charger, and a small thin panel for my roof rack - that way the batteries almost always stay 100%.
    Meanwhile, i'm going to email Odessey and ask about constant charge rates. I didn't do enough homework before i did this :)
    doublethebass likes this.
  14. Jun 9, 2020 at 6:09 AM
    #94
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    how are you measuring the battery charge percentage?
    I think I’m going to keep mine as-is and just put my charger on it once a month, now that I’ve already bought it. The aux battery is on a redarc bcdc so i know it’s being charged properly.
  15. Jun 9, 2020 at 6:13 AM
    #95
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    I just hooked up my AGM charger and it said 95% and started charging it to 100%. I don't have a really good way to read the batteries besides that.
    I also use a bluetooth monitor https://www.amazon.com/gp/product/B07TJ2GYJL/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 paired to my android phone, but i'm pretty sure the percentage is calibrated for Lead Acid, and not AGM because it always says 100% until i start drawing from it.
  16. Jun 9, 2020 at 6:32 AM
    #96
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    Let us know what they say :thumbsup:
  17. Jun 9, 2020 at 7:22 AM
    #97
    adk_tacoma
    Joe
    Waterford, NY
    What is the full charge voltage?
  18. Jun 9, 2020 at 8:17 AM
    #98
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
    12.84v or higher
  19. Jun 9, 2020 at 8:21 AM
    #99
    b3itz
    b3itz Camp Life
    Northern KY
    2016 MT OR DCSB
  20. Jun 9, 2020 at 9:30 AM
    #100
    SRBenjamin
    Benny
    This is BS! My AGM has been in about 6 months, the voltage on the battery when the truck is off, reads 13.1 volts That's more than full.
    Update, I've found in very cooled temps(sub freezing), the stock system needs at least 90 minutes to get a full charge.
