Lets talk EBC Brakes and Rotors
Discussion in 'Arizona' started by 2ndGenJonny, Sep 26, 2013.
  1. Sep 26, 2013 at 11:28 AM
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member
    Jon
    Hades, AZ
    2015 Silver Sky Metallic DC O/R 4x4
    Starting to do the research on new brakes for my truck and wanted to see if any of you are running this combo from EBC or if you had any other suggestions. I want to "upgrade" and get some better stopping without spending the $$$$ to get new calipers.
    I spoke with EBC directly after calling a few local carriers because the local guys didn't know jack about these products or could give me a part # :(
    EBC had me call Place for Brakes out of FL and these guys were quick to fire off answers to my questions. Here is what Ive got so far. I included initial pricing, I have NOT done any other searching for the best prices... YET :D
    For my application they recommend the:
    PADS
    Yellow Stuff Sport Brake Pads #DP41657R $138.49
    ROTORS
    OEM solid disc #UPR7237 $140.30
    *OEM direct replacement
    USR Slotted #USR7237 $207.52
    * according to the dealer, these will work well with the yellow stuff pads. The only part he made sure to tell me is that when mud gets on the rotors I will need to be sure to rinse down the rotor to prevent any mud from baking into the slot. This isn't a big deal because I typically rinse off my truck after wheeling anyway due to the heat out here. When it comes to turning them he said that Pep Boys has the right lathe to turn these come maintenance time.
  2. Sep 26, 2013 at 9:06 PM
    AZHornet
    AZHornet Well-Known Member
    Michael
    Scottsdale AZ
    White Tacoma 4x4 AccessCab
    You throw steel lines into your setup with Blue Dot brake fluid? I believe Im running a similiar setup to you on my '02..EBC Yellow with Powerslot rotors and steel lines. My buddy had it setup this way when I bought it. I will find out and let you know.
  3. Sep 26, 2013 at 9:08 PM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2015 Tundra Double Cab
    Kings:Camburg:BFG
    Brembo Rotors with Hawk pads here
  4. Sep 29, 2013 at 8:08 AM
    2ndGenJonny
    Jon
    Hades, AZ
    Yea man, let me know. Last night I was out on the trails and my brakes are definitely lacking. This also has to do with the ABS engaging way too much.
    Its an expensive upgrade, but I think Ill end up starting with the pads/rotors. I can look into researching lines as well.
  5. Sep 29, 2013 at 9:57 AM
    TheRedHorseman
    TheRedHorseman Well-Known Member
    If ABS is activating, your brakes aren't lacking at all.
  6. Sep 29, 2013 at 10:18 AM
    2ndGenJonny
    Jon
    Hades, AZ
    On the road, I agree that ABS is working and needed.. But off road this is different. I want to lock up and dig in. While at speed down a wash where its bumpy you can tap the brakes and you can actually hear the ABS engage and the truck is much slower to stop.
    check this out
    http://www.tacomaworld.com/forum/2n...kill-switch-mod-05-offroad-easy-way-pics.html
  7. Sep 29, 2013 at 10:25 AM
    TheRedHorseman
    An ABS kill switch will fix that problem. But since your brakes can lock up, you don't have a braking power problem overall.
  8. Sep 29, 2013 at 10:40 AM
    2ndGenJonny
    Jon
    Hades, AZ
    The whole purpose of this thread is to learn what other TW folks have done and this morning I was enlightened by the ABS kill switch. I also know that I can change to a different pad and see some increase as well. The slotted rotors are probably overkill, its not a race truck. My brake job will be soon so I will keep digging.
    Thanks for your input man.
  9. Sep 29, 2013 at 10:47 AM
    TheRedHorseman
    Different pads will make a far bigger difference than different rotors as far as brake performance goes. Your average set of pads are meant for long life at the expense of stopping power. Things like the EBC pads are made for high stopping power at the expense of long life.
    I'd save the money and run regular rotors with good pads personally. That money could be better invested in steel lines and good fluid.
    The ABS kill is a no brainer for sure. I was really happy to pop the hood on my truck when I bought it and see no ABS lurking under the hood.
  10. Sep 29, 2013 at 10:48 AM
    fenderpicks
    fenderpicks Well-Known Member
    I too am looking for good set of of pads and rotors....
    But i definitely dont want slotted rotors... i prefer blanks.
    EBC makes a extra duty light truck brake pads.... Will those be better than the RED STUFF?
    It is hard to believe pep boys know these stuff....
    At least my local pep boys hire all dumb asses
    PS: In my experience.... installing SS lines doesnt really help much
    And changing them out is annoying, and there is always a chance of stripping out that NUT on the hardline.
    Besides on the Tacoma, it is hard line to rubber then another hard line to the calipers.
    So i cant see THAT big of a difference if u change out that rubber section of the line.
    Other cars is just Metal line to RUBBER LINE connecting to calipers, and i didnt notice a jack difference after switching to SS lines
  11. Sep 29, 2013 at 11:15 AM
    TheRedHorseman
    Flare nut wrenches are your friend.
  12. Sep 29, 2013 at 11:32 AM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I put on brembo solid rotors and ebc greenstuff pads. Much more stopping power but a lot of brake dust. No squeal or shake or anything.
  13. Sep 29, 2013 at 11:32 AM
    2000GTacoma
    Snow Hill NC
    x2
  14. Sep 29, 2013 at 12:02 PM
    2ndGenJonny
    Jon
    Hades, AZ
    I think I will end up turning my current rotors and trying the Yellow Stuff Pads and see how it goes until the next brake job. I'm going to do the ABS switch in the coming weekend for sure.
  15. Sep 29, 2013 at 9:17 PM
    cytocycle
    cytocycle Well-Known Member
    Scottsdale, Arizona
    Expedition Build - 2012 TRD Off-Road
    ARB Front Bumper with fogs, TJM 9,000 synthetic rope winch with Pro-Link, AllPro Bolt on Sliders with fill plates, Asfir Aluminum Front Skid, Mid Skid, Gas Skid, Transfer Skid, AllPro Shackle flip kit with Timbern, CBI HC rear Bumper, Rigid Mesh Grill with 20" LED bar, White Sport Grill Opening, ARB Dual Compressors and 2 gallons of air tanks for air tools, Dakar Leaf Pack, RadFlow 2.5" Extended travel Coilovers- front & rear shocks with res, front sway bar delete, Camburg UCA's, Stainless Steel Brake Lines on all wheels fixed mushy brakes, UltraGuage
    1) Put Stainless Steel Brakelines on before you do pads.
    2) Flush your brake fluid every two years!
    When you stomp on the brakes the rubber lines flex and you get spongy braking..... They are pretty cheap and biggest improvement in my opinion due to better feel and therefore modulation control.
  16. Sep 30, 2013 at 6:56 PM
    AZHornet
    Michael
    Scottsdale AZ
    I have installed steel lines in every car i have owned and to me its the biggest bang for the buck....sticking with stock size but upgraded components along with steel lines will mean no fade..ever. I am actually dreaming of the TRD Big Brake Kit for the last generation Tundra (I have an '02)...my concern (in addition to the cost), is they would be TOO good...ie lock up at a moments notice.
    :D
  17. Oct 11, 2013 at 11:46 AM
    jdavis92
    jdavis92 Well-Known Member
    Flagstaff, AZ
    05 Tacoma V6 SR5 Package #8 Debadged
    URD TCAI, aFe 2.5" exhaust, UltraGauge, Weathertechs, Wet Okoles
    Thread revival.
    Looking for a pad/rotor kit and some shoes for the back.
    Anymore thought other than what has been offered above?
    Thanks
    Jeff in Flagstaff
  18. Oct 11, 2013 at 12:25 PM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    16 Tundra TRD PRO
    I highly advise AGAINST putting stainless lines on the TRD off-road version as they are hydraulic assisted. It will no longer allow for a linear braking feel and will cause your wheels to lock up earlier which is dangerous. The TRD off-road braking system is designed for certain line pressure which stainless lines will increase too drastically. Similar to 4Runner's, GX470's etc.
  19. Oct 11, 2013 at 2:54 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    Eep, after looking at those EBC rotors... I wouldn't use them (slotted ones). Any rotor that has the slot go to the very edge is extremely dangerous under heavy breaking. It causes a weak point, and in autocross/street cars anyway... they're known to explode under heaving constant use.
    Personally I'd stick to just doing drilled rotors, if going that route. But, I have no experience on the taco other than stock rotors and the duralast ones (which surprisingly, do just as well thus far).
  20. Oct 11, 2013 at 3:31 PM
    lemons
    lemons LOCO 4X4
    Virginia
    07 TRD DC Offroad 4X4
    Icon coil overs W/King 14 inch 700lb springs and super bump bump stops, Allpro Expo leaf springs, Allpro Ubolt kit W/timbren Bump stops, Dif Drop Kit, Magnaflow Cat-Back Exhaust, Badges painted Rust-Oleum bed liner, Color Matched TRD Sport Grill W/Grille Craft Insert, TRD seat covers, Weather Tech Floor Mats, Flyzeye's , fog light anytime mod, ABS Off mod, ATO skid plates, ATO rear H/C bumper, BAMF sliders w/kick out, CBI front bumper, Engo 10000lb winch, Rigid D2 foglights, Piaa 510 fog lights, cobra CB w/firestix antenna, AFE snorkel
    Auto Anything has the Yellow stuff Pads for $131.00 with free shipping. Plus if you have bought stuff from them before they send you a discount code. So I got mine for $111.83 with free shipping. I go to Auto Anything for most of my normal replacements because their prices are good and they have free shipping. You can't beat that.
