Lets talk EBC Brakes and Rotors
Discussion in 'Arizona' started by 2ndGenJonny, Sep 26, 2013.
  1. Oct 11, 2013 at 3:38 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    I'm running the ebc stage 5 and I would definitely appreciate the links to exploding ebc slotted rotors.... Not being sarcastic, I'm on my phone and headed to the docs, and would like to read up on this when I'm in the waiting room.
    I've heard for many yrs that its the crossdrilled rotors u must worry about due to cracking.
  2. Oct 11, 2013 at 6:13 PM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I didn't say anything about the EBC rotors themselves, just that similar style rotors that are slotted to the edge have been known to explode under heavy breaking conditions (namely track) which wouldn't be too drastically different from off-road abuse I'd think. The link was on 3si.org a long time ago, a member there had it happen to them personally on their vr4. I'm not gunna go digging for it though lol.
    Just a word of caution is all. They'll probably work perfectly fine, but knowing its' a weak point... I personally wouldn't run them myself... is all.
  3. Oct 11, 2013 at 6:23 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'll look into it I guess when I get home.
    I'd def like more info about slotted rotor issues.
  4. Oct 11, 2013 at 6:27 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2015 DC 4x4 base model
    Husky liners, Toyo Open country AT2
  5. Oct 11, 2013 at 6:32 PM
    TACO TX
    Kelly
    Denison ,Texas
  6. Oct 11, 2013 at 6:40 PM
    AZHornet
    AZHornet Well-Known Member
    Michael
    Scottsdale AZ
    White Tacoma 4x4 AccessCab
    Not sure where you getting that from...I have had them on both my '09 and '02 Taco's with TRD Offroad package with zero problems...in stopping power, modulation (on road or off)...
  7. Oct 11, 2013 at 7:01 PM
    2ndGenJonny
    2ndGenJonny [OP] Well-Known Member
    Jon
    Hades, AZ
    2015 Silver Sky Metallic DC O/R 4x4
    I have the rear lines and ordered the fronts last week. I should be installing them this coming Friday. I have also bypassed my ABS with a switch.
    I dont need pads for awhile yet but I will be bleeding down the whole system with the line swaps. I will post my results then. :D
  8. Oct 14, 2013 at 9:20 AM
    05TacoRunner
    05TacoRunner You say tomato.......... I say fuck you!
    Peoria, Az
    Aftermarket nuts and bolts
  9. Oct 14, 2013 at 10:23 AM
    signalbobby
    signalbobby Well-Known Member
    Robert
    Arizona
    16 Tundra TRD PRO
    Personal experience and experience from other owners.
    ultimately it's up to you, but after i installed stainless lines on my 4Runner that had the similar braking system as the off-road, i removed it as it was dangerous under panic situations. The brakes become alot more touchier and on/off than having a linear braking pressure.
    In crotch rocket terms, its like having a 19 x 18 master cylinder vs a 19 x 20.
  10. Oct 14, 2013 at 10:36 AM
    2ndGenJonny
    Jon
    Hades, AZ
    HAHAHAH!!
  11. Oct 14, 2013 at 11:52 AM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Really?
    I've had my ss braided lines for probably 4yrs now, and I actually run my truck (for the last two yrs) with my ABS OFF all the time.
    Truck stops just fine.. I've never accidentally.locked the wheels up.
  12. Oct 14, 2013 at 12:34 PM
    2ndGenJonny
    Jon
    Hades, AZ
    I appreciate the spirited replies and all of the help. I will have the lines done Friday (Thanks to Jason) and will let you guys know how different it is.
  13. Oct 26, 2013 at 12:05 PM
    2ndGenJonny
    Jon
    Hades, AZ
    Jason comes though yet again and helps me make the modifications to my brake lines. I had purchased lines that are 3" over stock. We ended up having more than enough line at full droop so we removed some of the line and made a few small bends to get the angles correct. Ive been driving on it for about 100 miles now and there is a considerable difference in the pedal pressure and how the truck is stopping.
    We will be taking the trucks out next weekend for further testing and I will report back at that time
  14. Oct 29, 2013 at 3:27 AM
    TRON_
    TRON_ The Game Has Changed
    Stefen
    Tucson, AZ
    2016 TRD Pro Tundra
    IG: st3f3ns OverlandBound1235 R.I.P. Rinzler
    Now I need to do this! After bleeding my rears my brakes have become super spongy! But I'm way overdue for some extended SS llines front and rear
    Chephie likes this.
  15. Nov 18, 2013 at 6:57 AM
    #35
    bowhun2r
    bowhun2r Well-Known Member
    Scott
    Steeler Nation
    17 D-Cab TRD OR
    I PM'd Justus a while back on his setup (EBC Stage 5 setup). Also have the SS lines, however I've yet to get them installed.
    After 200 miles of easy braking the EBC Stage 5 setup now has much improved feel and stopping power over stock. I've just now started to hit the brakes harder and there is definitely much more of a bite than the stock setup. I was also getting a slight vibration on my stock rotors when slightly hitting the brake pedal. The original setup had 27K miles on them and I still had pad left, but the rotors were a bit warped.
    There is much more brake dust with the yellow pads. Can't tell on my setup since I have the anthracite FJ SE wheels, but one swipe with my finger on the wheels shows a lot of dust.
    I also used the DIY links on this site to do everything myself. Took a bit longer than the stealership, but my wheels are also not torqued over 130lbs.....and it was pretty easy to do.
    Interesting I opened the bleeder to take the pads out and the color of the fluid was a bit darker than what was in the reservoir. Bled both sides until I got a nice light gold color out of the bleeders and refilled the reservior.
    Love this site for info like this. And thank you Justus for the great recommendation on Stage 5 setup.
  16. Nov 18, 2013 at 7:09 AM
    #36
    2ndGenJonny
    Jon
    Hades, AZ
    Nice looking set up man! You still have a sway bar???
    I forgot to report back after I went wheeling on this thread. The combined steel lines with the abs kill made a huge difference! I've done about 80 miles off road and loved every min. Not one peep from my abs and not one scare that I couldn't stop. At this point I'm going to wait for my pads to wear completely before I look towards a new pad. I will not be going with drilled/slotted rotors though.
  17. Nov 18, 2013 at 7:27 AM
    #37
    bowhun2r
    Scott
    Steeler Nation
    17 D-Cab TRD OR
    Thanks. Your truck is pretty sweet as well.
    Yes...still have the sway bar as the majority of time I spend is back-n-forth to the airport.
    Hoping to get the SS lines installed next weekend and bleed the remaining fluid through the system. Should be good for another few years.
  18. Nov 18, 2013 at 7:49 AM
    #38
    2ndGenJonny
    Jon
    Hades, AZ
    There are some mean curbs to crawl at the airport :D
  19. Nov 18, 2013 at 8:21 AM
    #39
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    I'm glad ur happy with the setup, and happy u were aware that the braking becomes better after a few miles. Sorry to not inform you well enough about the dusting, I based it off of looks and not by wiping my finger across the rims. I guess it is hard to tell on some rims.
    At least there's a couple of us with these now and its not just my sole opinion, and u have shown that I may have underestimated the dusting, so thats good.
    I've noticed that even tho these are not drilled (I'll never run cross drilled), the black coating comes off the face quickly (no surprise at all because thats normal) but the dimples catch a little dust and LOOKS like a cross drilled rotor. Just something I like.
    They morph from black face and brushed slots and dimples, to brushed looking face with dark dimples. From what I can see in the dimly lit garage, the hat is still black tho
    Happy braking gentlemen, and as always feel free to shoot me a PM anytime.
  20. Nov 18, 2013 at 8:42 AM
    #40
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    didnt see this when I posted earlier with my phone........ ur rotors had arrows?!
    NICE!
    heres mine out of the box................. no arrows
