Lets talk Gas mileage.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Aerose91, Aug 14, 2014.
  1. Aug 14, 2014 at 2:36 PM
    Aerose91
    Aerose91 [OP] Well-Known Member
    Connecticut
    07 TRD Sport 4x4
    Wondered if I could get some input. I have an 07 TRD Sport Access Cab 6 spd and I love it. Everything but the gas mileage. In the city I get about 15-16mpg and max 21 on the highway but sometimes as low as 19mpg.
    I'm considering getting a dual cab in the future (I would like to keep a red sport 6 speed) but am concerned about the mileage. Does anyone here have the v6 dual cab 6 speed that can weigh in?
    I sure wish they made hybrid or diesel tacomas. I'd be all over that.
  2. Aug 14, 2014 at 2:40 PM
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    6-speed has a really poor OD gear ratio. .85 vs .72 on the automatic. If you plan on driving fast the automatic is the better choice. Unfortunately.
  3. Aug 14, 2014 at 2:44 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    and even then.... 70+ mph your not going to hit +20mpg's ... your looking like 18-19mpg on the hwy at 70+ mph in my DCSB v6 auto 4x4 all stock.
    Drop that speed to 60-65 and your looking at 21-23mpg.
  4. Aug 14, 2014 at 2:44 PM
    Jester243
    Jester243 all I wanted was a god dang picture of a hotdog...
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    some of this, a little of that
    You are getting exactly what you should be.
  5. Aug 14, 2014 at 2:45 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    Click on my fuelly signature for all fill ups (over 200 by now)
    Currently (last two years) I have one size bigger than stock 265/75/16 all terrain tires on.
  6. Aug 14, 2014 at 2:46 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Sounds about right
  7. Aug 14, 2014 at 3:05 PM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    The 5 speed is slightly higher than the 6, with a .81 OD. Combined with my 3.31 final gearing comes to exactly 2,000rpm @ 60 mph which is great for freeway driving.
    Here are the 2014 Toyota mileage ratings for each transmission:
    21/25 (5-speed manual)
    18/20 (5-speed manual 4x4)
    19/24 (4-speed automatic)
    18/21 (4-speed automatic 4x4)
    16/21 (6-speed manual
    4x2/PreRunner)
    15/19 (6-speed manual 4x4)
    17/21 (5-speed automatic)
    16/21 (5-speed automatic 4x4)
    Greg
  8. Aug 14, 2014 at 3:06 PM
    Large
    Large Red
    20 mpg and complaining, there is no hope.
  9. Aug 14, 2014 at 3:14 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I know I'm getting what I'm supposed to, I don't over rev it, I just was curious how much it would would drop with the dual cab. Suprised the auto is so much better, damn.
  10. Aug 14, 2014 at 3:18 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    Damn, you're getting the same as I am basically. I thought there would be a bigger difference.
  11. Aug 14, 2014 at 3:21 PM
    T4RFTMFW
    I have dcsb prerunner with 4 banger and auto and average 22, highway trips 28. Worst tank 19
  12. Aug 14, 2014 at 3:26 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I have an 07 TRD Sport Access cab Automatic.... and although, I haven't checked it lately.... I get approximately 18mpg in summer and around 16mpg in winter (with mixed highway/city driving going 65mph on highway.
    I have noticed (and I don't know why) but when I take longer drives on backroads going 40-45mph - the truck gets the best mileage I've ever seen (over 20mph).
    The truck is rated for 16-18mpg.
  13. Aug 14, 2014 at 3:39 PM
    atk411
    atk411 Well-Known Member
    Anthony
    Orange County, CA
    14 TRD-S DCSB MGM PR
    INTERIOR: - Llumar ATC tint (f35/r5) - Dimming mirror (damnit Toyota) - Flyeyez V2W-1214 (RWR) EXTERIOR: - BPF Skid Plate - OEM Roof Rack - Redline Hood Struts
    14 Dbl Cab Auto, I'm getting what you see in my signature. But, that's with 80% of my daily commute stuck in LA traffic. I'm thinking I can easily hit 18/19 mpg if it was all highway.
  14. Aug 14, 2014 at 9:02 PM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    I didn't realize the dblcb would be practically the same. Thanks, guys
  15. Aug 14, 2014 at 9:29 PM
    kryten
    Canada
    I did not check the specs, but from what I remember there is only a couple hundred pound difference between AC and DC. (At least in comparison to DCSB which mine is.)
  16. Aug 14, 2014 at 10:02 PM
    tooter
    Greg
    Los Angeles
    Here's the 2012 curb weights. You're close. AC's and DC's are about 100 pounds difference.
    3,315 lbs. Base 4x2 Regular Cab 109.6 in. WB
    3,605 lbs. Base 4x2 Access Cab 127.4 in. WB
    3,700 lbs. Base 4x4 Regular Cab 109.6 in. WB
    3,785 lbs. PreRunner 4x2 Access Cab 127.4 in. WB
    3,705 lbs. Base 4x2 Double Cab 127.4 in. WB
    3,865 lbs. PreRunner V6 4x2 Access Cab 127.4 in. WB
    3,865 lbs. PreRunner 4x2 Double Cab 127.4 in. WB
    4,000 lbs. Base 4x4 Access Cab 127.4 in. WB
    3,950 lbs. PreRunner V6 4x2 Double Cab 127.4 in. WB
    3,975 lbs. PreRunner V6 4x2 Double Cab 140.6 in. WB
    4,075 lbs. Base V6 4x4 Access Cab 127.4 in. WB
    3,835 lbs. X-Runner V6 4x2 Access Cab 127.4 in. WB
    4,160 lbs. Base V6 4x4 Double Cab 127.4 in. WB
    4,220 lbs. Base V6 4x4 Double Cab 140.6 in. WB
    Greg
  17. Aug 14, 2014 at 10:04 PM
    T4RFTMFW
    Guy is a champion.
  18. Aug 15, 2014 at 7:40 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Ain't that much better seems like the only hit is in the city so much for better highway mileage with the higher gearing. Seems like the 6 spd. puts the RPM right in the sweet spot. I have never gone as low as 16 MPG even in the dead of winter granted there isn't much city where I live but short trips hit the mileage harder than city driving.
  19. Aug 15, 2014 at 9:32 AM
    Aerose91
    Connecticut
    07 TRD Sport 4x4
    What's the best rpm range for the 6 speed? In 5th or 6th gear
  20. Aug 15, 2014 at 9:36 AM
    worthywads
    7th if toyota would only make it.
