Let's talk Icon's new Delta Joint
Discussion in 'Suspension' started by 12TRDTacoma, May 12, 2017.
  1. May 27, 2020 at 4:17 PM
    #281
    kurts74
    kurts74 Well-Known Member
    Flagstaff, Arizona
    2nd Gen 4-door longbed
    ICON Mid travel set up with Hard candy shell
    Been a long time since anyone has done an update on how the DJ's are holding up...so how are they holding up? Any cons?
  2. May 27, 2020 at 4:18 PM
    #282
    12TRDTacoma
    12TRDTacoma [OP] Powered by Ford, GM, VW, and Mercedes
    Rob
    Concordia
    Boosted
    They are holding up stellar on mine. I don't know how many miles I've put on them since install, but zero issues, zero abnormal noises. Now my LCA uniballs... I hate these junks.
    Gingerbeard Man likes this.
  3. Jun 15, 2020 at 11:48 PM
    #283
    DavesTaco68
    DavesTaco68 Well-Known Member
    North Thompson, BC
    2013 Tacoma TRD
    - ICON UCAs, BP51/Kings, SCS wheels, 285s, Leer 100XR canopy. Greenlane aluminum winch bumper, Smittybilt X20 winch. Trying Falken AT3w now, Really like BF KO2s.
  4. Jul 25, 2020 at 8:40 AM
    #284
    knarliman
    knarliman Member
    Iman
    2019 trd offroad
    Baja upgrade fox dsc and icon full kit
    Is this an extended travel cause I need that bypass
  5. Oct 27, 2020 at 4:36 PM
    #285
    jp_flynavy
    jp_flynavy IG: @TrailLimoOverland
    2015 Tacoma DCLB
    Installed the delta joints on my TC uppers. We’ll see how they do. Hopefully, last a lot longer and perform better than my standard uniballs.
  6. Oct 27, 2020 at 5:25 PM
    #286
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Who are you talking to? You might want to tag them so they can answer you. Lol.
  7. Oct 27, 2020 at 5:27 PM
    #287
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Just an update: Have been running this setup close to about a year now. Zero issues or noises from it. I wish they made lower retros because for the uppers they absolutely rock.
  8. Oct 27, 2020 at 7:14 PM
    #288
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Dirt King used ball joints in their new redesigned lowers now
  9. Oct 27, 2020 at 7:27 PM
    #289
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I know they did. It was recommended by them to me that I not switch over or do any sort of general work to do a conversion over to a ball joint due to my setup.
  10. Oct 28, 2020 at 8:24 AM
    #290
    SilverSurfer
    SilverSurfer Well-Known Member
    Mark
    Los Angeles
    2013 4X4 LT
    Did truck height stay the same after install? Wondering if taper size is different on the delta joint vs T.C spacer.
  11. Oct 28, 2020 at 8:30 AM
    #291
    jp_flynavy
    2015 Tacoma DCLB
    Visually it appears the same. I honestly couldn't tell the difference.
    SilverSurfer[QUOTED] likes this.
  12. Oct 28, 2020 at 9:03 AM
    #292
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Yes it does. The Delta joint does not affect lift, that part to play is for the coilovers.
  13. Oct 28, 2020 at 9:45 AM
    #293
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    When I had mid travel setup ages ago moving from Spc to Icon UCA's had a slight change in ride height reason I asked. Depending on the taper in the uca that goes into the spindle it does change height slightly, not noticeably though.
  14. Oct 28, 2020 at 9:53 AM
    #294
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Gotcha. The taper of the Delta joint is right in line with the height of the misalignment spacers that are provided by TC and Dirt King.
  15. Oct 28, 2020 at 10:03 AM
    #295
    SilverSurfer
    Mark
    Los Angeles
    2013 4X4 LT
    You guys changing em without taking out the UCA? Sure it can be done with the Icon tool just need clearance.
  16. Oct 28, 2020 at 10:20 AM
    #296
    12TRDTacoma
    Rob
    Concordia
    Boosted
    There was NO way I was going to pull out the UCA. I did it all on the truck without the Icon specific tool. It was as simple as a ball joint swap out.
  17. Oct 28, 2020 at 10:32 AM
    #297
    JeffRoyJenkins
    JeffRoyJenkins Essentially Non-Essential
    Jeff
    Lake Stevens, WA
    2024 F-150 XLT PowerBoost
    There is no way mine would've come out on the truck. It took all my little 6k bench top press had in it even after soaking with WD40 and torching the hell out of it to get one of them to break free.
  18. Oct 28, 2020 at 12:24 PM
    #298
    jp_flynavy
    2015 Tacoma DCLB
    Yikes. I took mine off the truck but to get the old ones out all it took was a vice and a big impact socket, a few wacks with a hammer and they came out no issues.
    Delta joints went in smooth too.
  19. Oct 29, 2020 at 6:01 AM
    #299
    JeffRoyJenkins
    Jeff
    Lake Stevens, WA
    It might have been the fact that mine were about 5 years old with 60k+ miles on them. Or the fact that they were bone dry between the uni-ball and UCA like they hadn't even considered maybe putting a drop of antiseize or some kind of dry film lube on there when they were assembled.
  20. Oct 29, 2020 at 8:33 AM
    #300
    12TRDTacoma
    Rob
    Concordia
    Boosted
    To be fair here, that sort of stuff requires no lube or sort of grease when initially assembling it or pressing in. That is applicable only in your dry states, like non rust belt, non coastal vehicles. In the areas I mentioned, all bets are off.
