Let's Talk Rear "LT"
Discussion in 'Long Travel Suspension' started by erok81, Apr 3, 2017.
  1. Oct 5, 2020 at 9:45 PM
    #261
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    It probably includes building axles, limit straps, trimming lower ball joint mounts, and bump stop extensions. I’d say generally it would include brake lines, as well as removal and reinstallation of your brakes and rotors. If you think you got robbed it was definetly on the big brake install. Unless it was for rear brakes or swapping in a sequoia master cylinder to complement the big brake kit they installed while put your suspension back together. I don’t see 5 hours in that. Maybe 1-2 at most.
    Bobby18 and tacotunner06 like this.
  2. Oct 6, 2020 at 12:54 AM
    #262
    1nonlygarcia
    1nonlygarcia Well-Known Member
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Pending prerunner long travel
    tacotunner06 likes this.
  3. Oct 6, 2020 at 8:22 PM
    #263
    WRDD Taco
    WRDD Taco Big Hobby Guy
    Jake
    Delco, PA
    ‘11 TRD Sport DCLB LT 1G3 Moto Express
    TC Mid Travel +2, TC SUA, king shocks, Swamp Donkey/Rigid lighting, Mechman alt, SOS/Boztek armor, ATH Fab tiedown, full active JL/Audiofrog sound system, NOICO sound deadening EVERYWHERE. Up next: roof/bed rack + dry storage, skids, bumpers, fiberglass, power wire upgrade + frame grounds, LTO battery swap, air compressor, on board pressurized water, powered cooler, suspension seats, frame reinforcement, solid motor/trans mounts.
    I had a talk with the sales guy over there and I think we both agreed that I paid a lot but there was a lot of work to be done. My truck went in there with 168,xxx northeastern miles so I’m sure it wasn’t easy pulling everything apart, finding and replacing hardware that was breaking left & right, etc.. All of my brakes and hardware were replaced/extended front and rear when it was in there. I do still need to do the master cylinder mod as the brakes don’t have enough bite although I do love the smooth, consistent, quite spongy yet powerful delivery of the 6 piston wilwood bbk.
    Again I must say Mainline Overland of West Chester, PA did a great job on the install and I would have rather overpaid to have the job done right than penny pinch and have it done poorly.
  4. Oct 6, 2020 at 8:33 PM
    #264
    glorifiedwelder
    jason
    Santa Clarita, ca
    Yeah a few seized alignment cam bolts can definetly make for a long day.
    desertjunkie760 likes this.
  5. Oct 6, 2020 at 9:24 PM
    #265
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It’s better to overpay when you get good work (which only time will tell unless you already know what to look for) than to underpay and have problems down the line.
    Hitstick likes this.
  6. Oct 7, 2020 at 9:41 AM
    #266
    DannyBFresco
    DannyBFresco King Taco
    Danny
    NorCal (Martinez) & LA
    06 Tacoma 4x4 TRD Sport SWB
    Baja Kits +2 LT, Kings, 35" Falken AT3s, SUA
    If you’re thinking about links, check out this thread about the dirt designs kit (start here and read on a bit). I’m still in the same boat as you. I have the total chaos mid travel SUA and am trying to decide what to do next now that I have a bedcage and 2.5x16” King triples
  7. Oct 7, 2020 at 9:51 AM
    #267
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    If you can afford it / build it, no reason why linking isn't the way to go if you are setup to maintain it. If you're a weekend warrior leafs will work. I suggest watching a bunch of youtube videos of trucks with each and look at how they perform and relate that to you and your expectations.
  8. Oct 29, 2020 at 8:52 AM
    #268
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Don’t go SUA. I did and not happy. Redoing it now, just pull the trigger from the start and save money.
  9. Oct 29, 2020 at 9:26 AM
    #269
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    All SUA kits don't work the same way and all trucks need to be set up for the function of the truck - doing due diligence is important especially since you're never sure if what people are suggesting will 100% apply for your specific likes.
    WRDD Taco and desertjunkie760 like this.
  10. Nov 7, 2020 at 1:14 PM
    #270
    1nonlygarcia
    ceasar
    Lemoore CA
    06 Toyota Tacoma
    Okay I’ve decided. I would love to go 4 link but I still would like to like get my truck pass smog and driver it every once in a while on the road. So I decided to go with a 3 link setup. Who makes these set ups? So far I know giant Motorsport and dirt designs does. Any other options out there?
  11. Nov 11, 2020 at 12:53 PM
    #271
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    @taco_sos is using RuffStuff’s 3 link setup
    https://instagram.com/taco_sos?igshid=1vgro5tjyl7se
    https://www.tacomaworld.com/threads/3-link-tacoma-prerunner-build-taco_sos.654010/
