Let's talk recovery
Discussion in 'Off-Roading & Trails' started by Mxpatriot, Jun 8, 2010.
  1. Mar 5, 2011 at 12:41 PM
    #41
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    lets talk about where my ground anchor is:D
    remember me
  2. Mar 6, 2011 at 4:28 AM
    #42
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    Tow cable, as in slow steady pulls with no shock/static pull... sure
    Recovery strap, as in shock load/dynamic pull, absolutely not.
    I'd say you'd still be better off with a chain or a strap depending on which you're going for, and no cable at all.
    A good link on vehicle recovery
    http://www.gmfullsize.com/forum/showthread.php?t=75056
    A lot of good information, some is more towards actual rigging but it all is still good info, albeit a bit dry at times
    http://www.pirate4x4.com/tech/billavista/Recovery/
    Here is what can happen the minute you disregard safety
    Women's arm torn off in tow mishap
    A tip to make using a shackle easier. Tighten all the way, and then turn back 1/4 - 1/2 of a turn. This will keep the shackle pin from tightening on you, requiring a tool to remove. Never use a shackle to join straps in a dynamic pull.
  3. Mar 6, 2011 at 11:47 AM
    #43
    anormis
    anormis Well-Known Member
    Anthony
    St. Charles MO.
    BarcelonaRed 2010 D.C V6 4.0 Liter 4x4
    Hunter trucks brush guard, pcd performance chip, tailgate theft mod,blacked out badges, painted engine cover, black tail lights, modded mud flaps, painted black grill, seat belt beep mod, rear TSB!.yellow fogs red led map lights. Painted switches black, painted hood scoop, black center console and overhead console. Black wheels! Red calipers.
    yes only as a tow cable not anything with shock or jerks. but just something that i can put some pressure on to do a steady pull. in little cases where you are near a solid service. but thanks for the advice. but i have thought about breaking and all that stuff with shock value. good looking out though
  4. Mar 6, 2011 at 3:53 PM
    #44
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    :thumbsup:
  5. Mar 9, 2011 at 11:43 AM
    #45
    claw
    claw Well-Known Member
    Cam
    Bozeman MT
    2010 Access Cab, 4 Banger
    Tonneau cover, bed lights, fog lights, VHF radio
    Myself and two buddies were out in a Jeep a few springs ago. Got stuck in a snow field with nothing to winch to in any direction! Started trying to dig ourselves out and found that we were in at least 10 feet of snow!! We found a 2 foot boulder, dug a nice deep hole for it, tied an old tow strap around it and buried it. Instant anchor! and rolling back on 20 minutes later.
  6. Mar 27, 2011 at 8:49 PM
    #46
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    07 Tacoma 4x4 SR5 V6 Off Road
    Lift,Winch,Shell,Light Bar,Siren,Radio's
    This is some of the stuff I carry in my truck.:)
  7. Mar 27, 2011 at 10:13 PM
    #47
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    Chainsaw... hell yes. I know some guys locally who carry them. One said he cut down a tree, turned it into planks and used the boards to extract his truck.
  8. Mar 28, 2011 at 4:12 AM
    #48
    brutalguyracing
    F.U> GUYZ
    broken mods
    to bad you dont have a ground anchor......:rolleyes:
    why you have 6 snatch blocks???
  9. Mar 28, 2011 at 10:17 AM
    #49
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    Yes a three Stinger Ground Anchors on 60" High Lift's would be nice to have! ;)
  10. Mar 28, 2011 at 11:25 AM
    #50
    92LandCruiser
    Nevada
    Cummins, tons, 40s
    rigging up reverse pulls maybe?
  11. Mar 28, 2011 at 11:31 AM
    #51
    RedTaco2134
    RedTaco2134 Well-Known Member
    Scott
    Portland, Or
    08 Long Bed TRD Sport
    295/70/17 Cooper STT Pro, Revtek 3" lift. TSB rear and Blistein 5100's http://www.cardomain.com/ride/3097063
    Wow, that is some recovery gear! Just a thought/tip, put your hood up on your truck while winching. I see the strap laying over the cable in case it ever broke, but if it kept coming at your truck, the hood will take the cable instead of the windshield.
  12. Mar 28, 2011 at 12:05 PM
    #52
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    Yes good idea! I now only have synthetic rope on my winch's for more safety.
  13. Mar 28, 2011 at 12:13 PM
    #53
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
    Yes. & sometimes get a big mechanical advantage. When my 15,000lbs winch is working hard.
  14. Mar 28, 2011 at 4:56 PM
    #54
    brutalguyracing
    F.U> GUYZ
    broken mods
    dont let oz see you have a jumper pack:eek:
  15. Mar 28, 2011 at 5:50 PM
    #55
    MrFastLayne
    MrFastLayne Mr SGA
    Layne
    Lincoln Ca,
