Let's Talk Sliders - Weld vs. No Weld
Discussion in '3rd Gen. Tacomas (2016-2023)' started by erok81, Nov 11, 2016.
  1. Nov 11, 2016 at 12:23 PM
    erok81
    erok81 [OP] Well-Known Member
    Imposter
    A couple questions on the subject.
    1. Who makes a weld on slider for a 2016 access cab? I could have sworn I saw a post from one of the vendors saying to use their previous model weld on sliders and they work (or it could have been just for pricing). But I can't find that post.
    2. The main reason I'm looking at weld on (besides being cheaper) is weight. Once I've added both bumpers, sliders, my bed rack, my RTT, that's a lot of weight. So I am trying to keep that down. Does anyone know what kind of savings you end by not doing bolt on? I suppose if it's less than 50 pounds the ease of bolt on might start to look better. I guess there's also the strength aspect, but once one properly attaches the bolt on ones, they seem to be just as strong.
    For my truck, I'm looking for the kick out and fill plates. Also up as high as possible.
  2. Nov 11, 2016 at 12:37 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    Don't worry about the added weight. Its below the center of gravity from all the weight you added above it. It will help you more than hurt you. With bolt on sliders you will have less issues with warranty problems should there be problems later down the road. Welding on high strength steel frames is a big no, no.
    Getting what you want is not a big issue but it depends on where you live and how much you have to pay for shipping.
    I used Avid for my bolt on sliders with kick-outs and no filler plates on my 2016 Access cab.
  3. Nov 11, 2016 at 12:42 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Relentless Fab, All Pro, Mobtown Offroad all should have 2016 sliders.
    While you're researching I highly recommend knowing the differences between HREW and DOM.
    Also, from most opinions on here, if you plan on slamming on those sliders, then weld-on is the only way to go.
    Keep in mind I don't own sliders so I'm just going off the majority of opinions that I've seen on here. Hope this helps.
    Mobtown Offroad and Dalandser like this.
  4. Nov 11, 2016 at 12:46 PM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    I really like the look of mobtown offroads bolt on sliders, they look great, have kick outs and fill plates, make them for the access cab, and are strong. When I get the coin, these will be the first major mod I do. I think @Aussiek2000 has these exact sliders on his AC and they look great.
    Mobtown Offroad and boynoyce like this.
  5. Nov 11, 2016 at 12:50 PM
    JoeRacer302
    JoeRacer302 Well-Known Member
    Joe
    Pasadena, CA
    2016 DCSB OR MT Inferno
    Front: 5100's @ 0.85 Rear: 1/2" spacers 265/75r16 on RAY10
    I think Mobtown is running a 20-25% discount until the end of the month.
  6. Nov 11, 2016 at 2:03 PM
    erok81
    Imposter
    I'm not necessarily worried about up high weight, it's just the total weight I'm adding. Between the sliders. bumpers, winch, rack, tent, gear, suspension, I'll probably be nearing 800-900 extra pounds. So anything I can do to reduce that will help (weld on sliders, aluminum bumper, etc).
    See these are all bolt on from what I can find. Looking at all of those brands, the bolt on bracketing system seems like it would add a lot of weight. I plan on using them. Last time I was Moab I had some pretty close calls where those sliders would have been handy any closer.
    I know the differences as well. My last 4x4 was a 1 ton Jeep with 39's. Cage, sliders, bumpers, etc. Many things made from tubing. A lot of the stuff I made/had made with HREW that didn't need a lot of strength and DOM where I needed that l extra strength.
  7. Nov 11, 2016 at 2:46 PM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    It probably was 4xinnovations. I reached out to them to see if their weld ons would fit the 3rd gens and they did.
    http://www.4xinnovations.com/2005--2016-Access-Cab-Tacoma-Rock-Slider_p_73.html
    I have a set of their weld on sliders for my quad cab with a kick out but no fill plate.
    Since they're weld on you can angle them as high as you want. I set mine to have about 14 degrees incline. Mine are welded together and painted up now, just haven't finished installing them.
  8. Nov 11, 2016 at 3:36 PM
    vale46
    vale46 Well-Known Member
    FL
    2017 TRD Pro
    :spy:
    BarberRider likes this.
  9. Nov 11, 2016 at 3:48 PM
    BarberRider
    BarberRider Merit Badges: Scuba Cliff diving Mirror Awareness
    Fletch F. Fletch
    Trussville, AL
    1974 Dodge Monaco
    It's got a cop motor, a 440-cubic-inch plant. It's got cop tires, cop suspension, cop shocks. It's a model made before catalytic converters so it'll run good on regular gas.
    Rossi is the king. screw MM
  10. Nov 11, 2016 at 4:27 PM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Bolt on for the win. Easily removed for repairs, trade in etc., and just as strong
    TACOVRD likes this.
  11. Nov 11, 2016 at 4:29 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    Check out sos concepts, bolt on or weld on, kick or no kick, fill plates or not. Black friday sale coming soon :thumbsup:
    AmorPatriae likes this.
  12. Nov 11, 2016 at 4:33 PM
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    Can you jack a truck using bolt on?
    JimboAnz likes this.
  13. Nov 11, 2016 at 4:34 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Yes
  14. Nov 11, 2016 at 4:36 PM
    dYL0n
    Dyl0n
    New Orleans, LA
    This is the only thing I'd see myself getting sliders for. No heavy off roading here.
    JimboAnz[QUOTED] likes this.
  15. Nov 11, 2016 at 4:36 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Sliders were my first armor, i said that too :thumbsup:. Sliders are the gateway drug :D
    Now this
  16. Nov 11, 2016 at 4:39 PM
    digitaLbraVo
    digitaLbraVo Derka Derka
    Covered in stickers and chrome stick-ons for extra horse torques and foot powers. Icon sticker gets me tons of travel, dozens of milimeters.
    Unless it's "true no drill" bolt on, drilling the frame instantly voids your warranty. Welding and cutting off/repainting welds is a lot easier to cover up than added holes are.
    DustStorm4x4 and JimboAnz like this.
  17. Nov 11, 2016 at 4:40 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Sos are true no drill, as are several others i beleive
  18. Nov 11, 2016 at 4:41 PM
    digitaLbraVo
    They don't have any pictures of the actual mounting face of the sliders, I'd never touch them.
  19. Nov 11, 2016 at 4:43 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    They usually use holes made for factory side steps and maybe a few other random ones that are there from the factory.
  20. Nov 11, 2016 at 4:44 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Ok, i dont understand your comment though. Theres solid options out there is all i am gerting at
