Letting some air out in tire help with pot hole bounce?
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Oct 27, 2011.
  1. Oct 27, 2011 at 2:16 AM
    prerunnerSD
    prerunnerSD [OP] "I Brake for Tailgaters"
    Northeast USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    Heard somewhere letting a lil air out of tire will help with going over train tracks and certain bumps. Kind of gives it a protective bounce? Any credence to this claim?
  2. Oct 27, 2011 at 2:32 AM
    supremetaco2
    supremetaco2 Well-Known Member
    concrete jungle, oahu
    04inacoma
    +hp, lifted, lights, dif breather mod, debadged, shorty antenna...
    Yes,,, less air = more tire comes in contact with the ground. therefore = slightly more forgiving ride.
  3. Oct 27, 2011 at 2:52 AM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Helium filled tires would have prevented both those accidents.
    People usualy only air down when off roading.
  4. Oct 27, 2011 at 3:10 AM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Fort Collins, Colorado
    bone stock / unmolested 04 2.7L
    Just keep them aired up enough to ensure even tread wear. But yes, it helps with less air, it allows the tread and sidewalls to flex. That's part of the reason we air down while off-roading.
  5. Oct 27, 2011 at 3:22 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Is it just me or does it seem like most of the time when you see crazy pics like above there are Fords in them?
    Freaky On Road Driving?
    Forgetting Our Right Direction?
    Fuck Off Regular Drivers?
  6. Oct 27, 2011 at 4:53 AM
    prerunnerSD
    Northeast USA
    haha LOVES IT
  7. Oct 27, 2011 at 4:55 AM
    prerunnerSD
    Northeast USA
    Nice build... Trust me with how every road is nearly always 'under construction' Everywhere you drive in Massachusetts you might as well consider it off road. So I'll take that as YES. How much air should I let out?
  8. Oct 27, 2011 at 5:01 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    For pavement driving, not much, it will prematurely wear your tires and hurt your MPG's. How much air depends on your tires, I wouldn't do anything drastic, maybe a couple lbs at most if you really feel the need. I'd imagine you should still be between 28 - 32 PSI for a double cab.
  9. Oct 27, 2011 at 5:03 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    +1
    Keep to door specs for best results, and get better glasses to spot the potholes:p
  10. Oct 27, 2011 at 5:05 AM
    prerunnerSD
    Northeast USA
    i'll try it a lil just to see.. just seems like it rides rough and dont wanna hurt anything. i have a lift and destination A/T p265/75 r16 tires
  11. Oct 27, 2011 at 5:06 AM
    Pugga
    Massachusetts
    F-150 Mod
    What pressure are you running in them now? P-rated tires shouldn't ride rough. It might not be your tires, what have you done to alter your suspension?
  12. Oct 27, 2011 at 5:15 AM
    prerunnerSD
    Northeast USA
    yes i have Front and rear Bilstein 5100's, Front Coilovers. Good suspension as far as I can tell.. maybe I'm just babying her... The roads here can be brutal as you know
  13. Oct 27, 2011 at 5:20 AM
    Pugga
    Massachusetts
    F-150 Mod
    I just wanted to make sure you weren't use a pre-load spacer which would cause it to ride like a dump truck! Sounds like you have a pretty decent set-up though. I'm assuming you're either from Western MA where a lot of roads have washed out or in Boston where the pot holes could swallow a small tank :cool: Personally, I've given up, I set my pressure where it should be, avoid the pot holes that I can and let the Billies absorb the unavoidable tank traps.
    EDIT: Don't worry about it, in a month or so the snow will fill in all the pot holes and the roads will be perfect!
  14. Oct 27, 2011 at 8:43 AM
    4Wheelin4Banger
    Randy
  15. Oct 27, 2011 at 8:46 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    2006 Toyota 4Runner SR5 V8
    The first picture looks like a Chevy s-10 and the second is certainly a Jeep, probably Liberty.
