letting your truck warm up
Discussion in '4 Cylinder' started by darrinhutch, Sep 10, 2014.
  1. Sep 11, 2014 at 12:08 PM
    w.adventures
    w.adventures Adventure is out there
    Nowheresville, SC
    2005 Lexus GX470 Family Hauler
    Start it and go. Winter time I park in the garage so there is no waiting for anything to melt/defrost.
  2. Sep 11, 2014 at 12:36 PM
    Mr. Pick
    Mr. Pick Well-Known Member
    Middle TN
    '12 AC, SR5, 2.7L, Auto
    I start it up and go, but I always drive easy out of the neighborhood and for the first couple of miles after that.
  3. Sep 11, 2014 at 6:18 PM
    weezer
    weezer Well-Known Member
    southeast
    tacoma 4x4
    Bilstein 5100 shocks, OME lifting springs, Ivan Stewart 16x8 wheels, AT tires
    only takes about 30secs-1min to go to closed loop in the summer here in alabama.
    winter time maybe 2-3 min tops. that's even if it's 0 degrees outside.
    usually in winter i just crank it and turn defrost heat on high until i can see out the window and then i go. this is with frost or snow or whatever. takes about 5min tops for all of it to be melted.
    in winter i always aim the 2 outermost vents towards the side windows. heat blows out of these when in defrost mode so they melt the side windows and rear window while the dash vents melt the windshield.
    if it's a big snow which is about 6"-12" down here then of course scrape the window first with one of those ice/snow things. :D
  4. Sep 12, 2014 at 11:25 AM
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
  5. Sep 12, 2014 at 11:36 AM
    Navelfunk
    Navelfunk Well-Known Member
    Phyllis
    WA
    '03 DC SR5 V6 4x4
    Cap, incorrect rims & tires, stereo...
    Because it's an old habit, I let it warm up for about 2 min. I let every car do that pretty much...
  6. Sep 12, 2014 at 12:56 PM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    Like many on here, I let the idle come down and then drive gently until the temp gauge is normal, then I *can* hammer it if I want or need to. But I usually don't hammer it. Lots of articles on the internet explaining modern motor oil lubrication, fuel injected engines, emissions controls (cats, 02 sensors, etc). There's just no need to warm up unless the conditions are very cold and the vehicle is kept outside. Now *wanting* to warm the car up, that's a different story and purely a matter of preference.
  7. Sep 15, 2014 at 2:51 PM
    JcDillon
    JcDillon Well-Known Member
    Somerville, Tn
    2012 access cab taco
    Bed Lights, Camper Shell w/ led light strip, HUWMS, K&n 63 series CAI, mbrp s5326al exhaust, ride rite dual control airbags.
    Tony: what years is your truck and is your remote start a OEM or aftermarket?
  8. Sep 19, 2014 at 7:58 AM
    2 wheel drive
    2 wheel drive Member
    Marietta, GA
    2001 Tacoma regular cab
    Autometer tach, spray in bedliner, sliding rear window, Sirius satellite radio
    In the summer I usually let it warm up while I am removing the sunshade, etc. Maybe a minute so I start to get cool air from the A/C.
    In the winter, even though I use Mobil 1 5W-30, I get piston slap when it has sat out all day in 30 to 40 degree weather. So I usually let it warm up for about a minute, then drive very gently out of the parking lot. Noise disappears after about 2 to 4 minutes. Only hear the noise under moderate load.
    It is an '01 with about 74K miles.
  9. Sep 19, 2014 at 8:01 AM
    NorthwestCruiser
    NorthwestCruiser Well-Known Member
    Brian
    Snohomish, WA
    1996 Land Cruiser
    Custom 3 link, 40's etc..
    I found I get better mileage if I let it warm up instead of taking off. From my house to the gym not letting it warm up I get about 15ish, letting it warm up I get 20ish. But yes I always let it warm up and never hammer it
  10. Sep 19, 2014 at 9:17 AM
    tooter
    tooter play every day
    Greg
    Los Angeles
    2012, std cab, 5 lug, 2.7, 5 speed
    Built for maximum low end torque, tooter II.VII intake manifold spacer, LCE long tube header, Injen long tube intake, 2,900 rpm torque peak.
    Because I live in a generally warm climate, there's no need to wait to warm up the engine...
    ...however I never lug the engine (high load at low rpms) when it's warming up, and will let it rev more freely in a lower gear rather than load the engine in a higher gear.
  11. Sep 21, 2014 at 2:29 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I've never owned anything as new as this 2004 Taco up until now so I've always let everything warm up. With the Taco I still let it warm up usually until the needle hits the first mark.
    The problem isn't whether or not the oil is getting to everything. That happens pretty quick. The problem is that putting a load on the crank, pistons and everything else without the oil at least warm isn't a good idea in my book. Not to mention the fact that pistons and everything else along with the aluminum head all expand and contract as the temps change and the clearanaces really aren't where they should be until everything is heated up.
    I let mine warm up even when it's 100 degrees outside. 100 degrees isn't hot to an engine. The only reason everyone is so weird about idling is because they want to save fuel. That, I could care less about. It's the engine I care about.
    All those metal parts are far happier when the oil is at least close to operating temp and everywhere it needs to be. It is true though that it takes about 20 minutes to get oil up to operating temp. It lags quite a ways behind the coolant temp.
  12. Sep 21, 2014 at 2:34 PM
    TRVLR500
    Wyoming
    If you're got piston slap which so many newer vehicles have the last thing you should do is take off before the slap stops. That is a big no-no. You're engine will last close to forever with piston slap but putting a load on it with pistons slapping isn't a very good idea.
  13. Sep 22, 2014 at 2:45 PM
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    It's 2014, the engine & drive train warm up faster during normal driving.
  14. Sep 23, 2014 at 9:35 AM
    TRVLR500
    Wyoming
    That's true. I just don't think it's a good idea to put a load on any engine until it has at least warmed up a little. No matter the year there are still metal parts sliding against each other and oil doesn't lubricate the best until it reaches normal operating temp.
    I am aware, however, that these newer engines are designed so it isn't necessary to warm them all the way up before you drive off.
  15. Sep 24, 2014 at 8:36 AM
    #35
    FTD
    FTD Well-Known Member
    Never. An 8-cylinder takes a minute or so to get going. Not a four.
  16. Sep 24, 2014 at 6:59 PM
    #36
    Indy
    Indy Master of all I survey.
    Big difference between driving and an actual "load". Oil doesnt have to be at optimum temp, its doing everything it needs to do way before its warm, unless youre sitting overnight in20 below temps. Just dont go nuts and bouncing off the rev limiter.
  17. Sep 25, 2014 at 9:45 AM
    #37
    OahuGrown88
    OahuGrown88 Well-Known Member
    NC
    BFG AT 265/75R16. ARB Bumper. OME 886 w/ Dakar Leafs. Warn M8000. PIAA Fogs. SEO Synthetic winchline. Leer 100R. Thule Tracker II.
    Prefer to let mine warm up a for about a minute or so. RPMs usually sit around 1500 when I first start it up. Once I see/hear it drop to around 900/1000 RPM I begin driving.
  18. Sep 25, 2014 at 4:05 PM
    #38
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    At 70K and 6.5 years the number of times I let mine idle more than 30 seconds, I could count on one hand. Mine idles until this first indication of the idle dropping. Anything more and we are dumping more raw fuel into the oil past the rings than necessary, and that thinning of the oil film on the upper cylinder wall is what causes wear. The quicker the engine warms the sooner the air/fuel ratio gets to normal. A engine warms much quicker driving it gently under 2K RPM. My engine uses no oil and makes no strange sounds. If below 0° F I will let it run for about a minute. Rarely happens around here, and usually my truck comes out of a heated garage in the morning.
  19. Sep 25, 2014 at 4:36 PM
    #39
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    We use 5W30 oil for a reason the 5W lubes every thing during start up it's pour temp is very low like -40C. If my oil light is out it's time to move the engine will warm far quicker and it will be in closed loop far faster, they are very few people that live on an entrance ramp to the highway by the time you get there it's warm enough to hit the road. An engine has no feelings it does not feel pain.
  20. Sep 25, 2014 at 5:38 PM
    #40
    tacomathom
    Tom
    It is not necessary to warm up the engine in your Tacoma at all. If your engine has oil pressure you can drive normally, regardless of the lube oil temperature.
