letting your truck warm up
Discussion in '4 Cylinder' started by darrinhutch, Sep 10, 2014.
  1. Sep 25, 2014 at 5:42 PM
    #41
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    ive always waited till 1/4 of the tank of gas was burned.
  2. Sep 28, 2014 at 10:54 AM
    #42
    2 wheel drive
    2 wheel drive Member
    Marietta, GA
    2001 Tacoma regular cab
    Autometer tach, spray in bedliner, sliding rear window, Sirius satellite radio
    I am really surprised that "modern engines" develop piston slap. I traded a '96 S10 because it developed piston slap at 30K miles. This slap lasted until the engine was at least part way warmed up. Last GM after years of GM vehicles.
    Is it because they use short skirts to reduce friction?
    Anyway, the reason I drive "gently" out of the lot is to avoid the slap. By the time I am out of the lot, wait for the light and am out on the road, usually in more traffic, the temp gauge has started to move and the slap is gone.
  3. Oct 1, 2014 at 1:44 AM
    #43
    n0ms
    n0ms Well-Known Member
    Angel
    San Diego
    1st gen i4 single cab 4x4
    Celica seats, Icon in rear and front with icon ucas, omd leaf springs, deckplate mod, lce header, Tundra brake swap.
    I still just wait till the idle drops down. Which is usually a minute or two maybe less, makes me feel better than starting and straight driving. :cool:
  4. Oct 1, 2014 at 2:57 AM
    #44
    DrFunker
    DrFunker Well-Known Member
    With the cold New England winter weather about to swoop down on us, I
    have a queasy feeling in the pit of my stomach. Why, you ask? Because
    every winter when my boyfriend and I get into my car, I start it, then
    I put the car in gear after about 30 seconds and drive off. This
    drives my boyfriend nuts, and I have to hear about "how bad it is for
    my car" to put it into Drive before it warms up. He will start his car
    and sit there for a good five to 10 minutes before he shifts into
    Drive. My question is this: Am I really doing harm to my car by not
    letting the engine run for 10 minutes? If not, how can I prove this to
    him? I found an article in The New York Times a couple of years ago
    that stated that nothing is gained by sitting in a freezing-cold car
    while the motor is running before you shift into Drive. He thinks that
    the reporter at the Times didn't know what he was talking about. But
    he just might listen to you if you say it's OK. Please help! It's cold
    here in Boston! -- Lisa
    RAY: How do you prove it to him, Lisa? Hand him this column and ask
    him to read the following aloud:
    TOM: Dear Lisa's Boyfriend: You have your head so far up your tailpipe
    on this one, it may be coming out your air intake.
    RAY: How's that, Lisa? Will that do it? You're absolutely right, as is
    the reporter from The New York Times. On modern, fuel-injected cars --
    basically anything made in the past 20 years -- you're not helping the
    car at all by warming it up for five or 10 minutes.
    TOM: On older, carbureted cars, that kind of extended warm-up can
    actually cause damage to the engine by diluting the oil with excess
    fuel. So it's even worse if you have a really old heap.
    RAY: But with modern cars, all you're doing with a long warm-up is
    wasting gas, increasing pollution, raising the temperature of the
    planet and making yourself 10 minutes late for your chiropractic
    appointment. The proper procedure is to start the car. If it starts
    and keeps running, put it in Drive and go. Go gently (don't back out
    of your driveway and floor it right onto a highway entrance ramp),
    because you'll be warming it up during your first few minutes of
    driving, but DO drive it.
    TOM: If it's bitterly cold out, like 10 or 20 degrees Fahrenheit or
    lower, you can let it warm up for a minute or two to allow the oil to
    thin out a bit and circulate completely. But other than that, if it
    runs, driving it gently is the best way to warm it up.
    RAY: So tell your boyfriend he not only needs to get off your case
    about this, but he needs to stop warming up the car himself.
    TOM: AND, to make up for all the misplaced grief he's given you over
    the years, he needs to start going to bed 10 minutes before you do, to
    warm up the bed for you on cold winter nights. That's a warm-up
    activity he can do that's actually useful!
  5. Oct 1, 2014 at 5:57 AM
    #45
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    The piston slap is caused by the hypertuetectic pistons that they started using way back in the early 70's. I made the mistake of putting them in my '73 Coupe DeVille engine when I had it rebuilt way back in the mid 90's. I though they were the shit without going to the expense of forged because they actually used them in the early 70's LT-1 Vette's. Back then they were starting to be used as a cheaper high performance piston that was stronger and handled heat better than a standard cast piston but were far cheaper than forged. I should have done my research better.
    Hypertuetectic pistons are far stronger than standard cast pistons but they are brittle and the horror stories about them over the last 20+ years are endless. Especially when used in race motors or hot rods that are run hard. They do have a shorter skirt and I believe a higher silicon content mixed into the aluminum. Unless the piston to cylinder wall clearance and rings are all set up just perfect you get piston slap until the piston warms up enough to expand and fill the gap.
    My Caddy has had what I "think" is piston slap since the engine was rebuilt and recently developed a cold knock I believe is a piston. I won't know until I tear it down which will be a while. Still runs and idles like a new car once it's warmed up though. It takes a loooong time to get all that cast iron and those huge pistons up to temp especially in the winter.
    The whole reason behind the idea of hypertuetectic pistons was to get a better bore, piston/ring seal for better emissions but as it turns out it just cost 10's of thousands of people some very expensive headaches and a whole lot of oil consumption.
    While the piston slap really doesn't hurt anything eventually the piston can cock in the bore just a little too much some day and boom. That's the end of your engine which is why I made the post earlier about driving off with a cold engine while the pistons are slapping away. That's just asking for trouble. All that being said, you can have piston slap and the engine can still last 300,000 miles.
  6. Oct 1, 2014 at 6:01 AM
    #46
    TRVLR500
    Wyoming
    I do the same thing although I don't let it warm up for very long. Just until the idle drops down to 1000rpm or just below. I have to agree with what others have said here as far as the newer cars are concerned. As far as something like my Cadillac is concerned the NY Times is full of it. I've let that thing warm up for at least 10 minutes before I put it into gear and when it's -10 it idles for at least 15 or 20 before it gets to 180 degrees. For the last 130,000+ miles. I had an oil analysis done on it after 5000 miles on the same oil. There was NO fuel dilution.
    As far as taking advice from the New York Times on how long I should warm up my engine, especially my old relic Caddy. Well, that is the LAST publication I'd take any advice from especially on that subject. I'd bet 90% of the people that work there take the subway or a cab and don't even own a car. I won't even go into their wacked out views on pretty much everything including a phony energy shortage and phony climate change that has never existed along with their dislike for the automobile and our freedom to drive where we want when we want in general.
    That's all I'll say on that subject.
  7. Oct 3, 2014 at 10:18 AM
    #47
    2 wheel drive
    Marietta, GA
    I could not agree more! Agrees with my theory about people who live on bodies of land surrounded by water or "ring roads".
    And thanks for the detailed explanation. Interestingly, the slap appears more pronounced when the engine is soaked at 30 to 40 degrees. The few days we have had sub freezing weather during the day (here in Atlanta), I did not hear the slap. Must have something to do with the different coefficients of expansion for aluminum and cast iron.
    The truck is garaged - I baby it - so no problem in the morning.
  8. Oct 4, 2014 at 11:03 PM
    #48
    TRVLR500
    Wyoming
    That's bizarre. Usually the colder it gets the worse the piston slap is or at least it lasts a little longer. I don't know the make up of the pistons in the Toyota's but the ones GM was using for a couple of decades not only slapped a lot but they also caused the engine to use, not burn a ton of oil. Like a qt every 1000 to 1500 miles. A lot of those engines still lasted 200,000+ miles though. Some, of course, blew up.
    My old Caddy is like that thanks to those damn hypertuetectic pistons. It has always used a qt every 1500 miles or so but it runs like a brand new car. Even with the bad cold knock it has developed once it warms up it runs like a new car. As a matter of fact it idles smoother than my Taco does.
  9. Oct 4, 2014 at 11:49 PM
    #49
    kyleTRDtaco12
    kyleTRDtaco12 Well-Known Member
    Kyle
    New Jersey
    2012 Toyota Tacoma Base DCSB 4x4 V6 6MT (202)
    TRD Cat-Back Exhaust TRD Sport Package Springs & Shocks (Front Linear Coil Springs, Rear TSB Leafs) Front & Rear Toyota/Bilstein 40mm Shocks) Silver Toyota 16" SR5 Wheels with 265/70/16 BFGoodrich Rugged Trail T/A Tires w/ Locks OEM Black-Chrome Housed Headlights (SR package) OEM TRDpro Grille Insert RokBlokz Rally MudFlaps w/ Stamped Logo OEM 'TRD Sport' Bedside Graphics TRD QuickShifter w/ TRD Shift Knob Hawk HPS Front Brake Pads w/ Brembo Blank Rotors OEM Front Aluminum Skid-Plate eBay TRD seat covers Rear Diff. Breather Mod A/C Drain Extension Mod OEM Fog Light Kit OEM Intermittent Wiper Switch OEM Bed D-Rings OEM Bed Mat OEM Door Sill Protectors Blacked-Out Badges (from Xrunner 205 Black Sand Pearl) Pop & Lock Tailgate Handle TruXedo TruXsport Roll-Up Tonneau Cover AVS BugFlector II Front Bug Guard AVS In-Channel Window Vent Visors TRD High Pressure Radiator Cap Stubby Radio Antenna Ultra-Gauge EM v1.2 w/ Windshield Mount BullaCulla 7-Pin Relocation Bracket Misc. Stickers
    YES, I DO , i always let the truck get to, minimally to the C mark on the temp gauge , but usually one mark over the C almost all of the time no matter what, then i drive gingerly until the needle gets to the middle and then just drive normally after that.. i mean, i never romp on my truck anyway, but i always let it warm up, yes.
  10. Oct 5, 2014 at 5:58 PM
    #50
    TRVLR500
    Wyoming
    I pretty much do the same thing. I don't romp on it constantly but a few times a week I take it up to 4000-4500 rpm and ring it out a little.
  11. Oct 6, 2014 at 12:51 AM
    #51
    kyleTRDtaco12
    Kyle
    New Jersey
    True that, they say thats good to do every now and again, get some of the carbon build up out lol
  12. Oct 6, 2014 at 5:42 AM
    #52
    darrinhutch
    darrinhutch [OP] Well-Known Member
    darrin
    VA
    83 toyota pickup
    Lift with springs, BFG KM2, yeasu ham radio, custom flat bed, browning shift knob, tools box, mag lite, seat and steering wheel cover
    yeah i run my truck hard like every 2 or 3 weeks. but i dont run it hard for long. shift thru 2 gears about 4000 rpm. thats the hardest i ever run it.
  13. Oct 6, 2014 at 6:07 AM
    #53
    gearcruncher
    Canadain bumper technician
    This thread is weather specific .
    Just this morning I had to run the truck for 15 minutes before I even considered trying to move it .About two feet of snow this morning and she wont grab 4x4 until the front axle spins for 10 minutes .
    Any sooner than 15 minutes , the auto transmission clunks into forward gear , I have no power steering whatsoever , all 4 tires have flat spots and I can only see out the window through a 1 inch clear spot on the window .
    The command start works great but the heated seats dont warm up with the command start , only with the ignition key .
    And it,s not that cold yet hehehehe.
    In a week or two , When its 50 below zero again, I will be programming the command start to run the truck every 3 hours leaving both block heaters plugged in while the truck runs
  14. Oct 6, 2014 at 6:16 AM
    #54
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Good because that make no sense.
  15. Oct 6, 2014 at 6:32 AM
    #55
    roverskunk
    roverskunk New Member
    Maine
    95 Tacoma 3.4l 5spd 33s
    Bilstein 5100/OME 882, rear long aal, all-pro u-bolt flip and weld on shock mnts, pro comp shocks, 33" General Grabber, Addicted offroad front bumper, xrc8 winch, amazon special synthetic rope, lockright rear locker, OME spring hangers, magnaflow ss cat,
    I only let mine warm up if there is frost on the windshield. Sometimes until it's gone or until I remember that I'm supposed to go somewhere. A few times I've let it run all night just to make sure I can get to work in the morning.
    If it's not cold, I run it "easy" until the fan disengages then generally drive the pee out of it.
  16. Oct 6, 2014 at 6:41 AM
    #56
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    :confused: Not sure if serious.
  17. Oct 6, 2014 at 7:19 AM
    #57
    tacomathom
    tacomathom Well-Known Member
    Tom
    It's not new, it's not Mexico
    That's fine for you, but I prefer not to waste fuel like that. A modern vehicle warms up faster being driven gently for a few blocks. If I can see out the windshield, I drive normally.
  18. Oct 6, 2014 at 2:47 PM
    #58
    Yotabilly
    The Bluegrass
    The owner's manual for my 2011 Ford Ranger said 30 seconds, any longer and you're just wasting fuel.
  19. Oct 6, 2014 at 5:06 PM
    #59
    91r100gs
    91r100gs Understand the Voice Within
    Dan
    Kansas City area
    '08 Impluse Red SR5 I-4
    Factory bed mat, TacomaWorld.com sticker, EGR In-Channel Vent Visors, AFE ProDryS drop in air filter
    AMG, I am going to have to agree with FoMoCo on this one. The world is surely about to end.:D
  20. Oct 6, 2014 at 7:38 PM
    #60
    TRVLR500
    Wyoming
    He very well may be. They do that in Wyoming sometimes. I've seen Ford F350's out in the Walmart parking lot idling while they go in shopping for an hour. In Alaska they never shut the trucks off out on the pipeline. They run 24/7. In some parts of the country and the world you have no choice if you want to go where you want to go when the time comes.
