level amount?
Discussion in 'Suspension' started by colinb17, Dec 9, 2009.
  1. Dec 9, 2009 at 10:02 AM
    colinb17
    colinb17 [OP] If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    I'm looking into leveling out my 2007 4x4 dc. weather i go the 5100 rout, spring rout, or somethign else, i was wondering what amount of lift i need in the front for a level ride.
  2. Dec 9, 2009 at 11:07 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    It depends on a few things, but typically about 1.25" in the front.
  3. Dec 9, 2009 at 11:12 AM
    tacoma89
    tacoma89 Money Pit
    Chase
    Richmond, Va
    08 sport dc lb
    Check build in sig.
    just measure the front and back and get the differnece and that is your magic number.
  4. Dec 9, 2009 at 11:14 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    thanks for the quick replies! i'll give it a measure, but it's good to know it should be between 1 and 2 inches
  5. Dec 9, 2009 at 9:30 PM
    spiceman
    spiceman Well-Known Member
    Hawaii
    '07 4x4 DC OR, Desert Sand Mica
    Window Tint, Sockmonkey bed decals, Eibach 1.6" coils, 5100s front (set @ .85) / rear
    The difference between my front and back is exactly two inches and I have an 07 DC 4x4 OR. I want to level as well and I am thinking of doing the Eibach Springs with 5100s up front set at 0 for 1.6inches of lift. I will place 5100s in the back as well so they all match. Has anyone else went this route????
  6. Dec 10, 2009 at 8:28 AM
    atmotocrosser
    atmotocrosser Well-Known Member
    Greg
    Conroe, TX
    I have a 2010 PreRunner Access Cab with the TSB rear springs and 5100s all around. I have the front set at 1.75" which gave it a nice raise but still has a little rake. I decided against the 2.5" setting because of the harsh ride comments I had heard as well as the possibility of not being able to get the alignment within factory specs using the stock UCAs.
  7. Dec 10, 2009 at 2:15 PM
    ToyTec Lifts
    ToyTec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    1.5 to 2 inches.
