Level it 1", 1.5"?
Discussion in '5 Lug' started by navin, Apr 13, 2014.
  1. Apr 13, 2014 at 3:40 PM
    navin
    navin [OP] Well-Known Member
    I see the 2.5-3" kits and the rear AAL to lift the whole truck. Is there a method to just raise it the inch it is off in front without going to the big 2.5" minimum style kit?
    Anyone know the ratio of actual lift from say a 1/2" strut top spacer? I could have a buddy machine out a custom set if I come up with a spec.
    Thanks.
  2. Apr 15, 2014 at 6:32 AM
    navin
    I guess nobody has played with this?
    Could a guy with a front lift do me a favor, can you post the actual height of the spacer above your strut and the true lift gained at the fender?
    Appreciate it!
  3. Apr 15, 2014 at 9:46 AM
    jtye
    jtye Well-Known Member
    DC
    08 Super White 5 lug
    Fog lights, fatbob's 5lug lift, Cragar 15x7, 31x10.5 Gen.Grabbers, Wet Okole
    why not just get the full leveling kit, i just saw a guy post up a fatbobs full lift kit new in box for 150? I'd imagine custom machining a small spacer would be almost the same price?
  4. Apr 15, 2014 at 9:51 AM
    T Fades
    T Fades Well-Known Member
    Simi Valley, CA
    '11 PreRunner V6 2wd DCLB
    Satoshi, debadged, rear view mirror bracket, tail gate hose clamps, trimmed mud flaps.
    Get 5100's for the front, set at .85".
  5. Apr 15, 2014 at 9:57 AM
    navin
    I don't need or want the full lift as I'm already on the edge of needing gears to use it as I need it on stock 215/70-15 tires.
    The $ isn't the issue, more just what I really want from the truck, and I can trim up a set of spacers for just about zero $ anyway. There isn't much to it if I can still use the stock studs. It would just be a round plate with 4 holes in it.
  6. Apr 15, 2014 at 9:58 AM
    navin
    Is this a coil over or an adjustable length strut?
  7. Apr 15, 2014 at 11:10 AM
    T Fades
    Simi Valley, CA
    5100's are the shock that goes in the coil. They are adjustable at 4 increments: 0", .85", 1.75", and 2.5".
  8. Apr 15, 2014 at 12:01 PM
    disc0monkey
    disc0monkey All right. I believe ya. But my Tommy Gun don't!
  9. Dec 24, 2014 at 12:48 PM
    navin
    Well, I built my own leveling kit. I bought a 3" front spacer off eBay, chopped the top n bottom plates off the center tube and spaced them apart with large nuts, welded in place, to create a 7/8" spacer. Bolted in, I got a 1.75" lift, bringing me right about a quarter inch or less higher than the rear. Close enough for me.
    I'm running 30x9.50 on stock steelies and love the extra clearance for my front hitch bike rack. I just adjusted the headlights, which was stupid easy.
    4.10 gears, might be a tad tall for my needs with the 30s but it'll do for now. I'd not try a second gear start but still better feeling than stock tires and 3.31 gears.
  10. Dec 24, 2014 at 12:50 PM
    navin
  11. Mar 7, 2015 at 8:35 AM
    personality
    personality New Member
    What's all that in the bed there?
  12. Mar 7, 2015 at 8:57 AM
    navin
    Aluminum ladder/kayak racks.
  13. Mar 8, 2015 at 9:56 AM
    navin
    I have a few thousand miles on this now. I didn't even need an alignment. Everything is wearing evenly, drives great. One thing I worried about was maxing out the alignment adjustments with a big spacer lift up front.
    Happy it is out of the weeds and not quite the neutered lil pup it started out as.
    4.88 gears and a Detroit True Trac are going in her next week as the 4.10 is just too tall for my tastes with the 30x9.5 tires. It feels like near stock gearing again. Gives me room for more tire down the road too.
  14. Mar 8, 2015 at 10:06 AM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    The problem with a leveling kit is the stock leaf spring will wear down over time... if you don't haul or tow you might be fine but if you do after a few years they sag real bad... Just something to keep in mind.....
  15. Mar 8, 2015 at 10:12 AM
    navin
    Good point. I was slightly low out back so I added a cheapo AAL, now it has very slight rake. Depending on how it holds up I'll probably replace the leafs at some point. See how long they last for now.
  16. Mar 17, 2015 at 10:48 AM
    Rolis12
    Rolis12 Well-Known Member
    Rolis12
    San Diego
    2015 5lug access auto
    Goodyear Wrangler TrailMark 31's. F.B's 2.75" spacer, TRD rear shocks, stub antenna, ripped out charcoal filter added AFE dry, Chrome grille, upgraded to SR5 sun visors, variable wipers, backup camera, HID DDM 35w 5000kv, ebay fogs w/yellow LEDs.
    Looks awesome navin.
    Is this the only way to lift just the front? I'm looking to level the front or go a bit taller than the stock rear height. With no lift in the rear.
  17. Mar 17, 2015 at 11:11 AM
    navin
    Thanks.
    I think on the 5 lug it is. The lift to spacer ratio is 1:2 so if you make a 1" spacer, you get 2" actual lift.
    With a few basic skills rebuilding an eBay spacer kit to your personal size is pretty easy. The size I made allowed the reuse of the supplied studs and everything bolted in great, any bigger and I'd have had to get longer hardware.
    No alignment either at this height lift, nothing is stressed out to max flex or anything. Subtle but effective. If I park next to a stocker its a nice difference.
  18. Mar 17, 2015 at 11:39 AM
    Rolis12
    Rolis12
    San Diego
    Thanks but looks like I'll have to learn to weld if I want that size spacer:-\ lemme know if you ever sell them :)
  19. Mar 17, 2015 at 12:54 PM
    navin
    If you have a grinder, the welding might cost you $15. It wasn't much but a zap to lock it together. Took all of three minutes to weld everything. Not precision work. Very simple stuff if you took it to a welding shop.
  20. Mar 17, 2015 at 2:17 PM
    Rolis12
    Rolis12
    San Diego
    I'll be googling tonight! Thanks for the info and I'll post any progress i make.
