Level it up
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacomoMoto, Oct 6, 2011.
  1. Oct 6, 2011 at 6:13 AM
    TacomoMoto
    TacomoMoto [OP] Well-Known Member
    Miami
    09 SR5 Sport 6speed 4.0L
    If I put 3 inch spacers in the front of my truck, do you think that would be too much lift or will the truck sit level ? I measured the difference between the tire and the fender antheirs a 3 inch difference from the front of the truck VS the back of the truck.
  2. Oct 6, 2011 at 6:18 AM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    Just do 5100's. It is actually cheaper than a real quality spacer. Better ride, overall a better choice.
  3. Oct 6, 2011 at 6:20 AM
    TacomoMoto
    Miami
    Shocks will lift the truck ?
  4. Oct 6, 2011 at 6:21 AM
    TacomoMoto
    Miami
    I forgot to add that I have 3 inch spacer kit and it was free ..
  5. Oct 6, 2011 at 6:21 AM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    If the spacer itself is 3" it will give more than 3" of lift. Search 5100s
  6. Oct 6, 2011 at 6:22 AM
    raswank
    Rick
    Auburn,Ma
    Yes they are adjustable. Get them at Downsouthmotorsports.com. Do you have the rear spring TSB? If you do set them at 1.75 and you should be about level. You don't need new coils, upper control arms. Nothing
  7. Oct 6, 2011 at 6:30 AM
    TacomoMoto
    Miami
    Can I run spacers and the 5100's ?
  8. Oct 6, 2011 at 6:33 AM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    NO!!!!!!!!!
  9. Oct 6, 2011 at 6:33 AM
    raswank
    Rick
    Auburn,Ma
    Nooooooooooooooooooo
  10. Oct 6, 2011 at 6:35 AM
    BigBiscuit
    BigBiscuit Well-Known Member
    Mass.
    2010 TRD Sport DCSB MGM
    Do some reading on leveling your ride here before throwing those free spacers in your truck. There are better options as previously mentioned.
  11. Oct 6, 2011 at 6:35 AM
    TacomoMoto
    Miami
    I guess that's a no... What would happen ?
  12. Oct 6, 2011 at 6:36 AM
    k9cop
    k9cop if your not the lead dog, the view never changes
    Farva
    Hogwarts
    10 tacoma dbl cab trd off road prerunner
    CST 3.5" spindles, King 2.5 rr ,All Pro Expo's, Ext. Billy 5100's rear, Ext rear All Pro brake lines, LR UCA's, debadged, Cobra 29,2ft firestick, satoshi by jim, ARB front bumper, Smittybuilt xrc8 winch, wethatecs, bhlm also by jimbob, belgium malinois and German Shepherd in bed
    even tho the spacers are free...it will cost you more in the long run.
  13. Oct 6, 2011 at 6:36 AM
    raswank
    Rick
    Auburn,Ma
    To much lift, really put a hurting on your c.v. joints. Plus you would probably never get it aligned. Ball joint issues.
  14. Oct 6, 2011 at 6:37 AM
    TacomoMoto
    Miami
    Thanks for all the info
  15. Oct 6, 2011 at 7:14 AM
    2.7bluetaco
    2.7bluetaco Well-Known Member
    jacob
    middlesex,nc
    06 SR5 tacoma 2.7
    trd door stickers k&n cold air intake projector head lights 40 series flowmaster exhaust system nitto terra grappelers 265/70/16 billet grille
    3inch spacer will b more than level u will have to lift the rear end to with a add a leaf ir block kit
  16. Oct 6, 2011 at 7:34 AM
    TacomoMoto
    Miami
    By how much do you think an inch or 2 ?
  17. Oct 6, 2011 at 7:37 AM
    raswank
    Rick
    Auburn,Ma
    All I can tell you is go to the suspension section and type in 5100's a wealth of info
  18. Oct 6, 2011 at 11:05 AM
    chadderkdawg
    chadderkdawg Don't ask questions you don't want the answer to..
    Des Moines, Iowa
    09 FX4 F150
    about an inch
  19. Oct 6, 2011 at 12:58 PM
    TacomoMoto
    Miami
    What's so bad about the spacers ? Just out of curiosity
