Level or a slight rake?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Deathbysnusnu, Nov 6, 2013.
Suspension: Flat or Rake?
Poll closed Dec 6, 2013.
  1. Rake
    93 vote(s)
    62.0%
  2. Flat
    57 vote(s)
    38.0%
  1. Nov 11, 2013 at 12:02 AM
    YotaOverAll
    YotaOverAll Backyard Performance
    Jessie
    Panama City, FL
    02 Prerunner SR5
    3" Toytec spacers, Bilstein 5100s in the back with add a leaf and overloads removed.
    My truck is not used as a truck so I took my overload leaf out to level it with the add a leaf
  2. Nov 13, 2013 at 8:16 AM
    WhiteTacoma09
    WhiteTacoma09 Well-Known Member
    Curt
    Florida
    09 Prerunner access cab
    ZXE Headlights Drop in k&n filter Kobalt slim toolbox Tinted 17" FJ trail edition wheels OEM foglights 265/70/17 BFGs AVS vent visors Pioneer AVH-X1500DVD
  3. Nov 13, 2013 at 3:59 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    I always thought rake described higher front and jacked described higher rear nevermind:D
  4. Nov 13, 2013 at 8:19 PM
    TnRedNeck721
    TnRedNeck721 Nick Namer
    Zach
    TN
    07 TRD off road 4WD
    kinda surprised by the pole... I thought a lot more would say level.
  5. Nov 14, 2013 at 6:02 AM
    Deathbysnusnu
    Deathbysnusnu [OP] Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Same here. I like a little rake, but thought most would say level.
  6. Nov 14, 2013 at 4:57 PM
    REEFDUP
    REEFDUP Well-Known Member
    Ron
    Gulf Shores,ALABAMA
    04 TACOMA 4DR 4WD V6 AUTO
    Pro Comp,Rock Stars/ BFG Rugged Trail
  7. Nov 14, 2013 at 5:06 PM
    adrenalinejunkie
    adrenalinejunkie Well-Known Member
    seth
    Washington
    2001 tacoma SR5 TRD 4x4
    definitely rake. when you are hauling a load not only will your truck look "stupid" IMHO, but if you hit highway speeds with your truck in bro squat mode, your truck is much less aerodynamic and you can lose notable fuel economy depending on how much bro squat you have.
  8. Nov 14, 2013 at 6:43 PM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Oh no, lower fuel economy! Right.
  9. Nov 14, 2013 at 6:58 PM
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    idk if the aerodynamics is going to effect it as much as have less weight on front wheels and in turn less steering control and could cause you to wreck. Thats what i’d be worried about more than fuel. also even having a heavy tongue or bed weight will do this no madder what. but the lower the rear and high the front the worse it’s going to be. also you are more likely to hit the bump stops or even ride on them.
  10. Nov 14, 2013 at 7:15 PM
    adrenalinejunkie
    seth
    Washington
    great points! i drive A LOT of highway miles so unfortunately milage is kind of important to me. although i bought a truck knowin what i was gettin into..
  11. Nov 14, 2013 at 7:56 PM
    Frkypunk
    Frkypunk "Death is what you make of it."
    Timmy
    Woods of P.A.
    2010 Tundra limited,2015 Highlander limited, Prius(commuter)
    Got the gas mileage down to 13mpg! Modification complete
    Rake ....because I use it as a truck....it is level when I put stuff in it.
  12. Nov 15, 2013 at 5:00 PM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
  13. Nov 16, 2013 at 1:38 AM
    jathomas437
    jathomas437 Well-Known Member
    Angleton, TX
    1999 Tacoma SR5 Xtracab V6 4x4
    Slight rake, about an inch higher in the rear.
  14. Nov 16, 2013 at 10:24 AM
    scocar
    scocar Patron of the Farts
    I'd agree with the slight rake. If you replace a rear pack, or do an AAL or whatever and kill your brain forever to get it level, that pack/leaf will eventually settle a bit and guess what...
    Also, if you start adding a few things here and there, a bed mat, a cap, a tool box...it will start bringing it down faster.
    Towing, even more.
    If I did mine over, I likely would have gone with Dakars (2.25) rather than the Wheelers 5-pack (1.5).
    Like Boone said, you can do additional bags or Timbrens or whatever and dial it for specific loads, but that is also more effort and cost.
    And yes, whenever you lift at all, you should adjust headlights to keep them out of the eyes of oncoming drivers (and so you can see better).
  15. Nov 16, 2013 at 11:07 AM
    #35
    TnRedNeck721
    Zach
    TN
    07 TRD off road 4WD
    ^^ one thing great about some of the newer tundras is they have a knob Inside to adjust the head lights. Great for towing heady stuff you can angle them down more or less when you need to.
  16. Nov 16, 2013 at 5:01 PM
    #36
    yoterdude
    yoterdude Well-Known Member
    Jared
    Athens, AL
    2000 Taco SR5 TRD
    Aero Turbine 2525, Aero tip, AFE Dry Pro S filter, deckplate mod, TRS Morimoto Mini H1 projectors, TRS xBLed angel eyes, Vent visors, Blacked out tail lights, LED turn signals, 10w LED auxiliary reverse lights, 20in LED light bar, OTRATTW switches, LED interior lights, Blue needles, front Bilstein 5100s, Eibach coils, Bilstein 5100 rear shocks, OMD leaf spring mod, Trail Gear low profile bumper, Black grill, JVC KW-HDR81BT head unit, Husky Liners, 5% tint all round, 50% tint on windshield with 9 inch strip, front Wet Okoles, stickers, and a rubber ducky on the antenna :D
    My vote went for level because I'm not a fan of the rake. I'm not apposed to the "bro lean" or what its called here "doggin" lol, heck my truck sits a little higher in the front anyway.
  17. Nov 16, 2013 at 5:47 PM
    #37
    scocar
    But when you have a load in the bed, its not raked, assuming you use your truck as a truck, of course.
  18. Nov 16, 2013 at 5:49 PM
    #38
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Trucks are supposed to have some rake
  19. Nov 16, 2013 at 5:50 PM
    #39
    Frkypunk
    Timmy
    Woods of P.A.
    You will see why we like a rake .....when you get a job ...
  20. Nov 16, 2013 at 6:07 PM
    #40
    OKJC
    OKJC Well-Known Member
    Justin
    NWArkansas
    '10 SC 4x4 TRD Sport
    I have a job. You know, not all jobs require you to tow or haul things. Especially in your own personal vehicle. That being said, in my personal life I rarely load up the bed and only tow a trailer 3-4 times a year max. I like the look of level so I will likely go that route.
