Level suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Slade1, May 4, 2021.
  1. May 4, 2021 at 6:26 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    Hi Need some advice I have decided to use Bil 5100"s front and rear measured 35 inch front... 36 inch rear If i set the 5100 at the one inch slot it will be same as rear
    if all as it says. Now if i want to raise it to 2 inch what will I need in rear to keep it level besides the 5100"s any advice appreciated The PDf service manual i found here is great Thks
    2020 SR5 4X4
  2. May 4, 2021 at 6:28 PM
    Bishop84
    Bishop84 Well-Known Member
    1" block in the rear works perfect with 5100's.
    If you want a stiffer spring, an add-a-leaf will give you 1" as well.
    71tattooguy likes this.
  3. May 4, 2021 at 6:32 PM
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    I suggest add a leaf
  4. May 4, 2021 at 6:33 PM
    shotgunbilly420
    You get more purpose from a aal haul a little more or better ride when loaded I have a aal in my tacoma does great haven't hit the bump stops . When I was stock with a my camping gear I would always hit the bump stops
    Stocklocker and 71tattooguy like this.
  5. May 4, 2021 at 6:36 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    This ^^^^^
  6. May 4, 2021 at 6:58 PM
    Slade1
    Slade1 [OP] Member
    Mitch
    2020 Tocoma Sr5 4x4
    None yet
    Thanks for all the good responses, and 1 opinion
    shotgunbilly420 likes this.
