Leveled first gens with 33s?!
Discussion in '1st Gen. Tacomas (1995-2004)' started by G59, Mar 4, 2017.
  1. Jun 6, 2019 at 3:29 PM
    #61
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Gotcha. Yea that rub isn't too bad at all.
    I'm sure you'll discovery any trimming that needs to be done when you take it offroad and stretch its legs.
    Thanks for checking. Sounds like I shouldn't have too many issues with the 16x8's with 4" BS I have coming next week :fingerscrossed:
    eforayter[QUOTED] likes this.
  2. Jun 6, 2019 at 4:26 PM
    #62
    eforayter
    eforayter Well-Known Member
    1st Gen Xtra Cab
    No problem dude, post some pics when you get em on!
  3. Jun 6, 2019 at 4:30 PM
    #63
    betterbuckleup
    Ian
    Concord, CA
    I definitely will. I'll throw it up in a few of the threads and my build page.
    Got the rubber all ready to go
  4. Jun 6, 2019 at 4:31 PM
    #64
    eforayter
    1st Gen Xtra Cab
  5. Jun 7, 2019 at 7:12 AM
    #65
    VA_Taco
    VA_Taco Well-Known Member
    Chino
    Virginia
    2012 TRD Sport 4x4
    6" w/35's
    Here's mine
  6. Jun 7, 2019 at 7:41 AM
    #66
    seen20
    seen20 Well-Known Member
    Sean
    2000 3.4 Ext Cab 4x4 5-speed
    Adventure build
  7. May 10, 2020 at 12:01 AM
    #67
    dpw
    dpw Well-Known Member
    Dave
    805
    '03/4wd/Xtra/TRD
    Digging up a dated threat I know. It seems to be the most recent on the subject but somebody kick me to a more recent one if it's out there.
    I'm really liking the 33's on the 1st gen. I'm considering it myself as my current tires are worn and I have a nice set of 285/70 R17 on TR beadlocks that I took off my FJ62 that are just taking up space in my garage. I wish I hadn't taken them off but that's another story,,,,
    My '03 tacoma is currently sitting stock on 31". I didn't see any talk of folks with 33's on 17in wheels, but I did find this video of a Prerunner with 17in wheels (https://www.youtube.com/watch?v=fKq98ItnCy0) Not sure what backspacing/offset they are running but I like the look of how it sits.
    Anybody else running 17"wheels with 33s"? If so, what lift/suspension do you have or would recommend? I would like to keep it as low as possible but functional as well.
  8. May 10, 2020 at 2:04 AM
    #68
    Logans2001
    Logans2001 What’s crackin’
    San Diego, CA
    2001 v6 4WD auto
    I have 285/70/R17 with only Bilstein 5100s and they only rub the frame if cranked alllll the way. You’ll have to do a pinch weld mod but that’s not hard. They actually didn’t rub at all for the longest time until I replaced my LCAs recently so now they barely do when cranked for some reason.
    Planning on getting the full OME setup this summer though, hoping that helps since my coilovers/leaf springs have 265k on them.
    dpw[QUOTED] likes this.
  9. May 10, 2020 at 2:20 AM
    #69
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Just because someon asked.. 285-70-17's. Icon's and j59's in the back.. About 2 inches over stock maybe less.I have a lot of backspacing. I only rub the front of the rear fender when the tires droop.
    dpw likes this.
  10. May 10, 2020 at 6:58 AM
    #70
    dpw
    Dave
    805
    '03/4wd/Xtra/TRD
    @Logans2001, Thanks! Looks sharp. What kind of backspacing & offset do you have? Also, do you carry a spare?
  11. May 10, 2020 at 7:24 AM
    #71
    dpw
    Dave
    805
    '03/4wd/Xtra/TRD
    @chrslefty, Thanks... I just took a glance at your build--I'm going to enjoy going through that later. Well done on your setup, looks great too IMO.
    What's a lot of backspacing?(maybe I'll find that in your build post..) The wheels I'm thinking about trying to make work have a Backspacing of: 4.5" and Offset: 4.5mm (negative).
    chrslefty likes this.
  12. May 10, 2020 at 8:00 AM
    #72
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
    There 17x9 with 3.5 or -25 backspacing . Which I guess isn't a lot by some standards. They sure were a pain to make fit. Lol
  13. May 10, 2020 at 10:38 AM
    #73
    Logans2001
    San Diego, CA
    2001 v6 4WD auto
    I’m honestly not sure. Trying to figure it out
  14. May 10, 2020 at 12:05 PM
    #74
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    285's on an 8" wide wheel with 4" of BS, -12mm offset. I have King COs set at ~2.5" of lift in the front. A typical mid-travel setup.
    Slight rub on the passenger side frame rail at full turn.
    It is important to point out that adding lift alone will not eliminate tire rub. With a 285 wide tire, a stock BS wheel will rub on the UCA. But moving the wheel outboard will change where the wheel arc is. A significant amount of 'massaging' will have to be done to the pinch weld on the back side of the front wheel wells regardless of how much lift you add.
  15. May 13, 2020 at 8:05 PM
    #75
    xtwillie
    xtwillie Well-Known Member
    Kevin
    03 Tacoma
    I went with a 3 inch level kit front kings and rear ome new leaf springs
  16. May 14, 2020 at 12:29 PM
    #76
    Beater_Bimmer
    Beater_Bimmer Well-Known Member
    San Francisco, CA
    2002 Tacoma 4x4 DCSB
  17. May 14, 2020 at 9:17 PM
    #77
    Captainkyro
    Captainkyro Well-Known Member
    Christian
    2003 silver Tacoma trd
    How are you liking the camper ?
  18. May 15, 2020 at 10:51 PM
    #78
    Beater_Bimmer
    San Francisco, CA
    It’s awesome so far! only had it a few weeks and still working on a light build out for future adventures.
  19. Jun 22, 2020 at 6:06 PM
    #79
    dpw
    Dave
    805
    '03/4wd/Xtra/TRD
    Thanks for the info... I'm thinking about putting these wheels/tires (link) on my 1st Gen and just trying to understand what it'll take. I'm looking at this for a few reasons; mainly because I haven't been able to sell them for a reasonable price but also because I'm in need of new tires. Having a bit more off-road capability is a plus as well.
    Sounds like some coilovers and rear lift would be required. I'm sure my '03 stock suspension is in need of some attention by now anyways so it's not like I would be replacing anything new.
