Leveled Tacoma Tire Dilemma
Discussion in 'Wheels & Tires' started by sdixon86, Nov 19, 2012.
  1. Nov 19, 2012 at 6:47 PM
    sdixon86
    sdixon86 [OP] Well-Known Member
    05 Tacoma 4x4 Double Cab
    3inch Lift, Rims, Grille
    I am wanting to know what people have experienced with a leveled truck on their tire sizes… I have a 2005 Double Cab 4x4 and it has a Skyjacker leveling kit on it.
    Right now I have 16x9 Moto Metal wheels with 285/75r16 Nitto Terra Grapplers and it is almost time for new tires so I am debating on going down to a 265/75r16 (can I go this small with a 9” wide rim?). I am probably going to go to a Goodyear Duratrac, and I want to be able to have some suspension flex and not rub as much and that is why I considering a smaller rubber.
    Anyone have any suggestions, thoughts or opinions of a leveled taco with the 265/75r16 rather than a 285/75r16?
  2. Nov 20, 2012 at 2:13 PM
    Discount Tire
    Discount Tire Tire & Wheel Specialists Vendor
    Arizona, USA
  3. Nov 20, 2012 at 2:24 PM
    TeamLombardo
    TeamLombardo WE'VE LANDED ON THE MOON!
    Tony
    El Paso
    '12 DCSB TRD Off-Road 4x4
    OME 886x, OME Trim Packer, OME Shocks, Dakars, Toytec Shims, LR UCAs, CB Drop, Demello Sliders, Pelfreybilt Plate Bumper, Warn VR8000-s, RI 20" LED, RI Duallys, TRD Exhaust, Weathertech Liners, SS Brake Lines Front/Back, BHLM, Anytime Fogs, CV Boot Mod, 20% Tint, Stubby Antenna, Salex Console Organizer, Derped Grill/Badges
    Where do you rub exactly?
  4. Nov 20, 2012 at 2:25 PM
    CanisLupus
    CanisLupus Member since 2011
    Stokesdale | NC
    ‘19 Honda Civic Hatchback
    265/75/16 would look pretty small on a 3'' lift. Would probably help with MPG's, rubbing, and weight though.
  5. Nov 21, 2012 at 4:57 AM
    sdixon86
    It rubs the cab mount and the front inner fender dispute removing quit a bit of plastic. The thing I don't like is when I am turning an go over a decent drop the suspension flexes and rubs really bad... I measures the height of the tires right now since they are almost shot and the height is about 31.75" tall so if I got some duratracs, I wouldn't think the height would be much different going to a 265
  6. Nov 21, 2012 at 5:01 AM
    WhiskeyDeltaTango
    WhiskeyDeltaTango Resident Redneck
    Will
    Braselton, Georgia
    Dirty Black Taco
    ARB Bull Bar, ProComp 9" lights, Dual Hella aux backup lights, WARN VR10000, OME 886x, Dakar Leafs, UWS Low Profile Toolbox, Kicker CVT10, Kicker 750.1
    255/85/16 is what i run with a OME 3". Only very slight rubbing on the cab mount at full lock, full flex. only downside is limited tire choices
  7. Nov 21, 2012 at 5:21 AM
    BORNWILDGUY
    BORNWILDGUY Well-Known Member
    Rich
    Florida
    2020 TACOMA TRD SPORT DCLB LIFTED W KDMAX-PRO XT TUNE
    FULLY LOADED WITH THE TECH PACKAGE, LEATHER, JBL SYSTEM W UPGRADED JBL SPEAKERS IN AL DOORS AND SUB, LED HEADLIGHTS, MOONROOF, EXTANG FULL TILT COVER, NFAB SIDE STEPS, OEM ROOF RACK, TRD PRO TAILS, COLOR MATCHED TRD PRO GRILL WITH WHITE RAPTOR LIGHTS, 15% TINT ALL THE WAY AROUND, TINTED WINDSHIELD 50%, BILSTEIN 6112'S W 650# SPRINGS AND 1/4 SPACER, ICON LEAF SPRINGS W 5125 REAR SHOCKS, WELD LEDGE 6 WHEELS 18 X 9 -12 W 275/65R18 TOYO AT III LOAD C TIRES
    Take off your front Mud flaps
  8. Dec 6, 2012 at 5:37 PM
    sdixon86
    The mud flaps are gone now, but the 285's that i have now still rub the inner fender if they are turned and i have some suspension flex. I am just wonder what a 265/70r17 or a 265/75r16 would look like, because I think they would perform better off road.
  9. Dec 6, 2012 at 8:39 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    265/70/17 is stock sport size.
    Are you running UCAs? They have a pretty profound effect on rubbing, FWIW
    Do a cab mount chop and be done with it.
  10. Dec 6, 2012 at 8:49 PM
    jermoids
    jermoids Well-Known Member
    Jeremy
    Winnipeg, Manitoba, Canada
    2021 TRD Sport
    17x9 Fuel Mavericks +1 offset 265/65/17 duratracs NFAB Epyx step sides AVS hood protector Thule xsporter pro rack Weathertech floor liners Tacoma rubber bed mat
    265/65/17 is the stock size, i moved up to 265/70/17 with zero rub but im still using the stock wheels.
  11. Dec 9, 2012 at 8:04 AM
    sdixon86
    Is yours leveled or is that stock ride height?
  12. Dec 9, 2012 at 8:20 AM
    jermoids
    Jeremy
    2021 TRD Sport
    my truck has 5100's @ 1.75" with a 1" block in the back
  13. Dec 31, 2012 at 12:16 PM
    sdixon86
    I still haven't pulled the trigger on new wheels and tires yet... I'm looking at a 17x8 pro comp series 5001 black wheel with 265/70r17 Duratrac or an 18x9 black xd crank or xd monster with a 275/65r18.
    I'm leaning towards the 17" pro comp 5001 with c load range duratracs for the better MPG and better ride quality than an 18" wheel and tire combo but I'm still not sure how it'll look with my lift.
    I need some opinions...
  14. Dec 31, 2012 at 2:22 PM
    BORNWILDGUY
    Rich
    Florida
    Both will give you a good ride just depends on what you like. One tire you may want to consider is the toyo at II since you like an agressive tire. They actually are lighter than the dura tracs , come in load range c and also come with a 65k warranty. Just look on treaddepot.com and they will give you all the specs to include weights etc
  15. Jul 15, 2013 at 1:40 PM
    sdixon86
    Anyone have photos of a 3" lift with 265/75r16? I've seen plenty of the threads but I am still trying to convince myself one a 32" or 33" tire?
  16. Jul 15, 2013 at 9:45 PM
    Penz83
    Penz83 Well-Known Member
    05 Tacoma pre runner dbcb short bed
    I'm running 265/70/17 on 17x9 pro comp wheels. Grabber AT2's. 2.5" in front 2" in rear. I like the way it looks and rides. ImageUploadedByTapatalk1373949936.594088.jpgImageUploadedByTapatalk1373949951.213870.jpg
  17. Jul 15, 2013 at 9:48 PM
    Penz83
    To answer your question more thoroughly, putting a 265 tire on a 9" wheel is completely dependent on what the tire manufacturer lists. I know some 265 a/t tires list only up to 8.5" wheel.
  18. Jul 16, 2013 at 4:22 AM
    sdixon86
    That does look good! Do those tires look "ballooned" at all on a 9" wide wheel?
  19. Jul 16, 2013 at 6:36 AM
    Penz83
    I would not say ballooned, I would say more like full. I like the way it looks. ImageUploadedByTapatalk1373981773.111951.jpg
    I'll try to get some better side profile pictures.
