Leveling 2012 Tacoma TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Sprt Taco, Feb 12, 2016.
Should I do this?
  1. Yes, leveling your truck is an economic way to make your truck look and ride better.
    87.5%
  2. No, save your money and get a 3" lift.
    0 vote(s)
    0.0%
  3. Other, see comment below:
    12.5%
  1. Feb 12, 2016 at 6:58 AM
    TRD Sprt Taco
    TRD Sprt Taco [OP] Well-Known Member
    2012 Tacoma TRD Sport White DCLB
    Center caps for wheels LEER 100XQ topper
    BLUF: I want to put a 3" lift on my truck, but a good one is expensive. I'm thinking that leveling the truck will be a more economic and practical option.
    So right now my truck has a very noticeable slope to it. The back end sits about 1.5" higher than the front. It doesn't look bad by any means, but I think it would look much better if the truck was leveled. So here's what I'm thinking:
    I'm thinking I buy new shocks for my truck (upgrade from Bilstein 4600 to 5100 adjustable shocks). And then later I can buy new coilovers, add-a-leafs, and possibly UCAs. Here are the parts I'm thinking about:
    this shock set
    https://bilsteinlifts.com/shop/toyo...ht-adjustable-5100-front-and-rear-5100-shock/
    or this shock set (adjustable rear shocks)
    https://bilsteinlifts.com/shop/toyo...lstein-5100-0-2-5-front-0-1-rear-lift-shocks/
    with these coilovers
    https://bilsteinlifts.com/shop/toyo...-shocks-for-03-09-4runner-07-09-fj-05-tacoma/
    and this bushing kit
    https://bilsteinlifts.com/shop/toyota-fj-cruiser/front-shock-replacement-bushing-washer-kit/
    or this front shock/coilover kit
    https://bilsteinlifts.com/shop/toyo...adjustable-coil-over-kit-with-bilstein-5100s/
    with these rear shocks
    https://bilsteinlifts.com/shop/toyota-tacoma/2005-2015/rear-bilstein-5100-shocks-2005-toyota-tacoma/
    or these adjustable rear shocks
    https://bilsteinlifts.com/shop/toyo...unner-2wd-bilstein-5100-0-1-rear-lift-shocks/
    I have a few questions:
    Has anyone done this or something similar, and what were the results?
    What are people's opinions on Bilstein shocks? Is there something better? Are these good bang for the buck?
    If I'm just leveling the truck, do I need new UCAs for the front? At what point are new UCAs recommended?
    With these Bilstein shocks could I level it now and turn it into a small (1-1.5") lift later?
    Thanks for your help guys!
  2. Feb 12, 2016 at 12:02 PM
    Toy1985gc
    Toy1985gc Well-Known Member
    G
    2020 TRD Sport 4WD DCLB Tech Pckg Cement
    3 & 1 leveling kit 32 BFG KO's x17 Method Roost wheels/ TRD Skid
    I'm happy with just doing the leveling kit. Installed a 2.5 leveling kit and now running 32's with no issues.
  3. Feb 12, 2016 at 12:23 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    Maybe shop around a bit more and learn more about what it is you are buying and what folks on here normally pay for those items. There are many options as far as leveling kits go, explore those options and compare pricing. There are several vendors on here who would be happy to help with this.
    Oh and the 1st and 2nd links are basically the same exact shocks. One indicates a part number that is the RCD branded Bilsteins, the others are just the Bilstein part numbers. They are the same exact shock with the only difference being the valving, which there so little difference you wouldn't be able to feel it. Don't pay more for one part number over the other, that wouldn't really make sense.
    Also rear shocks are not adjustable, the height mentioned (0-1") are what the shocks will accommodate rear lift wise.
    Best of luck
  4. Feb 12, 2016 at 12:24 PM
    TRD Sprt Taco
    Roger that. Thank you!
  5. Feb 12, 2016 at 6:50 PM
    Jrozz
    Jrozz Well-Known Member
    Jonathan
    Colorado
    08 Acc TRD offroad
    truck comes with a rake for a reason. do you tow or haul significant loads in the bed?
  6. Feb 12, 2016 at 9:02 PM
    TRD Sprt Taco
    not very often.
  7. Feb 13, 2016 at 8:18 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Check my lift build in my signature- Adding a AAL might be a good way to go for you-Removing the overload spring would level the truck in my scenario. I used a longer AAL for a smother ride. Now my shocks had plenty of life in them however if you have some miles on yours then you may want to replace them and that makes going with 5100 series more appealing.
  8. Feb 13, 2016 at 10:07 AM
    Jrozz
    Jonathan
    Colorado
    08 Acc TRD offroad
    i took out the over load spring and did the wheelers progressive leaf pack, i think you would like that ride
