Leveling kit advice
Discussion in '1st Gen. Tacomas (1995-2004)' started by CTchambers040, Mar 20, 2015.
  1. Mar 20, 2015 at 9:51 AM
    CTchambers040
    CTchambers040 [OP] Member
    Alabama
    1998 SR5 4wd
    Alright so I'm new to TacomaWorld and new to a Tacoma. I've had my 98' for over a year now and I have been in love with it since the day I bought it. Now I've got a little money saved up and I'd like to put a little love into my ride. I thought about a 2.5" front end leveling kit. What do ya'll think about leveling kits and if you like them could you suggest a brand or a certain kind? Thanks I'm advance!
  2. Mar 20, 2015 at 9:52 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    ** in advance, sorry. hah
  3. Mar 20, 2015 at 10:24 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    Wheelers offroad
  4. Mar 20, 2015 at 10:27 AM
    Aw9d
    Aw9d That one guy
    I was thinking 'sound advice' was going to be an audio thread.....
  5. Mar 20, 2015 at 10:44 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    Sorry about the mix up guys! I do a moderate amount of off roading, no rock climbing, and I'm looking to spend 150-250. Is there anything decent I can buy with that kind of money?
  6. Mar 20, 2015 at 7:19 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    More info about your truck will help. 4x4? 5 lug or 6 lug?
  7. Mar 21, 2015 at 1:30 PM
    CTchambers040
    Alabama
    1998 SR5 4wd
    1998 SR5 V6 4X4 6 lug
  8. Mar 21, 2015 at 8:21 PM
    Digiratus
    Roaming the PNW
    The RedHead
    As mentioned, spacers and blocks are tempting and most likely could be done within your budget but the problem really is your stock suspension is worn out. A spacer lift is a temporary solution at best because your springs are worn out.
    The good news is, there quite a few options available to you for a 6 lug 4x4 1st gen but you are going to have to spend more than $250 to do it.
  9. Mar 24, 2015 at 7:11 PM
    lshouse35
    lshouse35 Active Member
    Lawrence
    Havelock nc
    04 tacoma 2.7
  10. Mar 26, 2015 at 4:34 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    Okay thanks for helping!
  11. Mar 26, 2015 at 5:07 AM
    Big Sur
    Big Sur Member
    2nd the Quicklift - picked up a set from AZN for $260 and am satisfied; they replaced spacers and the truck rides much better and sits level now.
  12. Mar 26, 2015 at 9:50 PM
    Logger
    Logger out for a rip are ya bud?
    Sam
    '13 TRD OR Double Cab
    Not sure about that Rancho lift, it isn't adjustable and maxes out your upper ball joints. Do a quick search on them.
  13. Mar 27, 2015 at 7:17 PM
    Digiratus
    Roaming the PNW
    The RedHead
    It really depends on how much lift the rancho setup gives. If the OP stays true to his original goals, no more that 2.5 inches of lift, and does not use an extended travel shock, he will not put too much pressure on the stock upper bj.
    It is important that any lift allow plenty of down travel and up travel.
  14. Mar 28, 2015 at 6:42 AM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    Op were you located I got revtech leveling kit that's used Id let u have
  15. Apr 9, 2015 at 8:51 AM
    CTchambers040
    Alabama
    1998 SR5 4wd
    I'm just North of Birmingham, AL
  16. Apr 9, 2015 at 5:57 PM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    I'm in nc man the rancho quick lift won't put any stress on your bj I put it on with 9000 series rear shocks and it the bees knees in my opinion
  17. Apr 19, 2015 at 12:20 AM
    Cinchman19
    Cinchman19 Active Member
    Mark
    Las Vegas
    2001 2wd prerunner v6 Tacoma
    So how is the ride quality? Did you need to put an AAL in back for your 1st gen?
    And other little things I should know before just slapping them on? Thanks
  18. Apr 19, 2015 at 11:01 AM
    lshouse35
    Lawrence
    Havelock nc
    04 tacoma 2.7
    It rides great I put new 9000 series shocks on the rear no added leaf just stock height in the rear my front bumper is heavy to make it compress a little it sets level .... No diff drop needed stock uca my ball joints are in no way getting over stressed I like it a lot looks really good with 31 inch tires
  19. Apr 20, 2015 at 11:10 PM
    Cinchman19
    Mark
    Las Vegas
    Sweet yeah I really think the rancho lift will be good to level it out and give me a little clearance. I just want it to perform well and give me a great ride.
  20. Apr 21, 2015 at 2:56 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
