Leveling kit and TSB what size tires will fit?
Discussion in 'Wheels & Tires' started by rwcfrank, Nov 2, 2008.
  1. Nov 2, 2008 at 9:08 AM
    rwcfrank
    rwcfrank [OP] Well-Known Member
    08 SR5 Prerunner
    I have a 08 Double cab SB with a 2 inch front leveling kit and rear TSB what is the largest tire I can safely run without rubbing? I plan to use the stock rims...Thanks
  2. Nov 2, 2008 at 11:54 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    on stockers and a 2" lift u can safely run a 32" tire, but not going wider than a 265
