Leveling kit experience vs lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, Jun 11, 2025.
  1. Jun 11, 2025 at 10:03 AM
    Redtaco777
    Redtaco777 [OP] Well-Known Member
    NC
    Uni-filter Mod
    Hey guys I think I made up my mind on just leveling out my truck with a 2” RC leveling kit instead of spending so much on a lift since I’m doing it just for looks no off roading..
    can I just install the leveling kit by itself without having to do anything else or do I need after market control arms etc??? I know I might have to align it but am I missing something…
    What are the pros and cons of a leveling kit over a lift ?
    Can you share your experience and set up if you have used a leveling kit before ?
    thanks
    2015WhiteOR likes this.
  2. Jun 11, 2025 at 10:09 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    You should be fine without a UCA swap. As far as doing more depends on you (nothing required, you already know you need an alignment). I have a severe case of "while I in there".
    Leveling kit is sales people talk for a specific type of a lift.
  3. Jun 11, 2025 at 10:37 AM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    Do you regularly tow/haul? It is my understanding that rake helps in those cases so that you aren't doing a carolina squat and pointing your front end up toward the sky while pulling weight.
  4. Jun 11, 2025 at 10:39 AM
    Redtaco777
    NC
    Uni-filter Mod
    No I don’t regularly tow or haul I kinda like the Carolina squat just a little bit lol .. I want the front to be raised just a little bit higher than the rear
  5. Jun 11, 2025 at 10:40 AM
    Redtaco777
    NC
    Uni-filter Mod
  6. Jun 11, 2025 at 10:47 AM
    Dbelle
    Dbelle Well-Known Member
    Maine
    '13 TRD Sport AC
    Clapped out on spacers heck yea
    Naveronski and clenkeit like this.
  7. Jun 11, 2025 at 10:49 AM
    Redtaco777
    NC
    Uni-filter Mod
    wym lol
  8. Jun 11, 2025 at 10:51 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  9. Jun 11, 2025 at 10:53 AM
    Redtaco777
    NC
    Uni-filter Mod
    Nah I don’t wanna lift I just wanna add a leveling kit .. If I add a “2 or “2.5 I’m it’ll look slightly lifted in the front
  10. Jun 11, 2025 at 11:00 AM
    Dbelle
    Maine
    '13 TRD Sport AC
    im just messing with you. I believe they call it “bro lean”, when you are nose high. Just put spacers in the front. If it’s too much, put some in the rear too. It’s a non functional lift for mostly looks. I’ve never done it but have heard reports of decreased ride quality.
    What is the condition of your current suspension? I took mine to 145k and it was time to replace, therefore I just went full suspension lift. If yours is worn, you may consider saving for a new suspension, and achieve the 2” in the front that way.
    And also, I may be wrong, but I think 2” would put you ~1” higher in the front than the rear. Again depending on the shape of your current suspension, your rear leafs may be sagged, and you may sit higher than expected up front
  11. Jun 11, 2025 at 11:13 AM
    Redtaco777
    NC
    Uni-filter Mod
    my truck has 78k miles currently so I don’t really think the suspension is too worn also I wouldn’t even know how to tell to be honest… but I definitely wanna sit higher in the front should I go for the “2.5 or 2” spacer to achieve this ?
  12. Jun 11, 2025 at 11:16 AM
    Dbelle
    Maine
    '13 TRD Sport AC
    I believe most leveling kits are a 2/1 meaning 2” up front and 1” rear to achieve a leveled stance. I would assume that 2” in the front would make you sit higher in the front.
    bkhlrTaco's likes this.
  13. Jun 11, 2025 at 11:24 AM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    The turd gen, at least, has a 1" factory rake.
    Adding 2.5" will leave you 1.5" higher in the front.
    Unless o.p adds an aal or a 1.5" rear block.
  14. Jun 11, 2025 at 11:25 AM
    bkhlrTaco's
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    I have some 2.5" front blocks and 1.5" rear blocks that I'm not using anymore.
    https://www.extremeterrain.com/mammoth-tacoma-25-in-front-leveling-kit-tt6067.html
    Supreme Suspensions - 1.5" Rear... https://www.amazon.com/dp/B00IMOM1JE?ref=ppx_pop_mob_ap_share
  15. Jun 11, 2025 at 11:34 AM
    jjsinaz
    jjsinaz Well-Known Member
    Jim
    Sun City West, AZ
    2023 TRD Sport DCLB Ice Cap 4X4
  16. Jun 11, 2025 at 11:50 AM
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    I've got 2.5 spacers front with a 2inch add a leaf rear and I've never had an issue, slightly larger tires.
  17. Jun 11, 2025 at 11:51 AM
    Redtaco777
    NC
    Uni-filter Mod
  18. Jun 11, 2025 at 11:59 AM
    Redtaco777
    NC
    Uni-filter Mod
    I have a 2nd gen so I’m guessing 2.5 spacers might be enough for me to sit just a bit higher in the front.. would you guys recommend me to get after market control arms as well
  19. Jun 11, 2025 at 12:02 PM
    Gen3TacomaOBX
    Gen3TacomaOBX Well-Known Member
    S
    2018 Tacoma DCSB SR 4x4
    Bilstein 6112 front / 5100 rear (extended) shocks, Headstrong AAL, Firestone airbags, 4.88 gears, OME Carrier bearing drop kit, Aluminum 1/4" skids (engine to transfer). Custom sliders (1.75" HREW tube w/ 3/16" base plates). Custom front bumper and high clearance rear bumper (1/4" steel plate, 1.75" tube.) Apex 5500 winch w/synthetic line (36lbs) and required accessories for an underpowered winch (snatch blocks and extra line.) Tekonsha P3 brake controller, remote start, any-time-backup camera w/ front facing camera, Leer 100R shell (w/e-track single slot tie-down mounts for removable Yakima EasyTop.) Cat shields by CaliRaised. Husky liners, window tint, heated seat (passenger only.) Relentless bed rail brackets with QuickFists (shovel/axe/fire extinguisher.) Hondo Garage Un-holey vent mount. Anytime rear with front facing camera. Billet front seat risers. Viair 88p. 265/75r16 Goodyear Ultra-terrain tires.
    Spacers sound fine for your expectations. Like others have said.. you're going to have a Carolina Squat (Bro Lean) if you merely add 2" to the front.
    If you're not off-roading are hauling heavy items then the inexpensive spacer/block kit for front and rear posted above is probably a decent fit.
  20. Jun 11, 2025 at 12:07 PM
    Redtaco777
    NC
    Uni-filter Mod
    So just by adding the “2 RC SPACER I’ll be more raised in the front than the rear ?
