Leveling kit experience vs lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Redtaco777, Jun 11, 2025.
  1. Jun 11, 2025 at 12:14 PM
    TheWildMan
    TheWildMan Well-Known Member
    3rd Gen 23 Tacoma OR
    Scrubbed some tires, and knocked a dent out.
    Guess you didnt know that shits "cool"!!
    To each their own I guess.
    2015WhiteOR[QUOTED] likes this.
  2. Jun 11, 2025 at 12:14 PM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Nilight makes other lights.. but at the same time do you really want to put a $35 spacer lift on your $30k+ truck?
    I wouldn't. Look into a Bilstein lift for something budget
  3. Jun 11, 2025 at 12:17 PM
    Redtaco777
    Redtaco777 [OP] Well-Known Member
    NC
    Uni-filter Mod
    What about the rough country 2” spacer
  4. Jun 11, 2025 at 12:18 PM
    fatfurious2
    David
    Ashburn, VA
    Almost all spacer kits will be the same, unfortunately. It probably doesn't matter on the brand
  5. Jun 11, 2025 at 1:25 PM
    Dbelle
    Dbelle Well-Known Member
    Maine
    '13 TRD Sport AC
    yes. Do you want to be ~ 1 or 1.5 higher in the front that’s really all it’ll come down to.
  6. Jun 11, 2025 at 1:30 PM
    Redtaco777
    NC
    Uni-filter Mod
    Sorry can you explain the difference between 1 and 1.5
  7. Jun 11, 2025 at 1:32 PM
    Redtaco777
    NC
    Uni-filter Mod
    I wish I could find a high quality brand that sells 2.5 spacers with a lifetime warranty like rough country .. RC only has the 2”
  8. Jun 11, 2025 at 1:56 PM
    Dbelle
    Maine
    '13 TRD Sport AC
    Those are just estimates. Basically the ass end of your truck right now probably sits somewhere between 1-2” higher than the front. You’d have to measure it to get the specifics of your truck to truly know how much higher you’ll be in the front after installing spacers.
    Both the 2” and 2.5” spacers will make your front end sit higher. How much higher is only going to be a .5” difference between the two kits.
  9. Jun 11, 2025 at 2:00 PM
    Saskabush
    Saskabush Well-Known Member
    Adam
    Saskatchewan, Canada
    2013 TRD Sport
    Elka 2.5" DSC w/ Deaver Stage 1, Archive Hammer Hangers, SPC UCAs, Timbren bumps, TRD baja wheels, 265/75r16 Wildpeak AT4W, Greenlane Sliders, Warn slimline bumper, N-Fab spare tire box mount.
    High quality =/= Rough Country. Also you are shopping for a chunk of metal... What kind of warranty do you think you need for that? I can assure that if that breaks, the cost to replace it will be the least of your worries. And no warranty is going to cover collateral damage.
    Also https://accutuneoffroad.com/articles/why-are-tacoma-spacer-lifts-so-bad/
    It's really not a good idea to use that big of a spacer. 1/2" max (gives 1" lift) or you're going to have problems.
  10. Jun 11, 2025 at 2:04 PM
    Dbelle
    Maine
    '13 TRD Sport AC
    Agreed. I think the 2 and 2.5 OP is talking about are lift height from the spacers, not spacer thickness. Good info though.
  11. Jun 11, 2025 at 2:10 PM
    Saskabush
    Adam
    2013 TRD Sport
    Fair. But it's a 2:1 ratio. So to get even 2" lift requires a 1" spacer. The UCA and CV axles can only droop an extra 1" max. When you add spacers, you are also increasing the extended length of the shock which means more droop. Therefore 1/2" spacer is the max before your CV joints start binding and the UCA starts making contact with the coils at full droop.
  12. Jun 11, 2025 at 2:47 PM
    Dbelle
    Maine
    '13 TRD Sport AC
    completely agree with you. I wouldn’t/didn’t go for a spacer lift personally.
  13. Jun 11, 2025 at 4:35 PM
    TacoTuesday1
    FL
    I have not used a leveling kit or RC. Because it is bad. So no.
    That is lifting the front. Improperly.
    To raise a Tacoma's suspension you use a taller spring designed to do that, and shock/strut designed for that.
  14. Jun 11, 2025 at 4:36 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Yes, a 1" spacer in the front will give you 2" of lift.
    I wouldn't go any higher, to keep the CV axles and boots happy.
    Then... research ECGS bushing.
  15. Jun 11, 2025 at 5:54 PM
    #35
    RockinU
    RockinU Well-Known Member
    Texas
    .5
  16. Jun 11, 2025 at 6:55 PM
    #36
    Redtaco777
    NC
    Uni-filter Mod
    so you think a “2.5 front lift is too much ?
  17. Jun 11, 2025 at 8:26 PM
    #37
    Redtaco777
    NC
    Uni-filter Mod
    Guys I’ just measured my truck… from the tire to the body ..
    Rear is 7.5 in
    Front is 5 in ..
    Even a 2.5 front spacer might not even give me a higher front end
    a 2 inch spacer is literally not even enough to level it out
  18. Jun 11, 2025 at 10:58 PM
    #38
    Redtaco777
    NC
    Uni-filter Mod
    I heard getting the ECGS bushing is good.. you think I’d be okay doing this mod and having a 2.5 inch spacer lift in the front
  19. Jun 12, 2025 at 2:21 AM
    #39
    Dbelle
    Maine
    '13 TRD Sport AC
    2.5” of factory rake seems off but maybe your front end is sagged. Like others have mentioned, you’re not going to want to go more than 2.5” of lift, unless you want to start playing with UCAs.
  20. Jun 12, 2025 at 7:57 AM
    #40
    Saskabush
    Adam
    2013 TRD Sport
    :facepalm:
    RockinU likes this.
