Leveling Kit height for 285/65 R18
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cdav313, Dec 31, 2017.
  1. Dec 31, 2017 at 7:20 AM
    Cdav313
    Cdav313 [OP] Member
    2017 Black TRD Off-Road
    Hey guys.
    I just purchased some new XD rims and 285/65 R18 nitto ridge grapplers. Next thing I have to do is put a leveling kit on my Tacoma.
    I have a 2017 TRD Off-Road.
    I have been leaning toward just the 2.5 leveling in the front but my question is do you think the tires will rub?
    Should I get 3 in the front, 1 in the back?
    I figured someone would probably have more experience than me! Any advice would help thanks!
  2. Dec 31, 2017 at 8:46 AM
    eldedo
    eldedo voted most likely eaten by a bear
    Mojave Desert
    '16 DCSBOR 4X4
    2888/5100/Dakars 285's/Camburgs
  3. Dec 31, 2017 at 8:48 AM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    Use the search button in TW
  4. Dec 31, 2017 at 8:57 AM
    Tacoaric
    Tacoaric Well-Known Member
    Dallas, Texas
    King Ranch F250 Powerstroke
    Depends on offset of the wheels more than likely
  5. Dec 31, 2017 at 9:12 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    backspace and offset are a factor, so is caster and lift. chances are a cmc and moderate trimming for those. however if you go 265/70/18 the width changes to 10.4, so cmc and trimming will be minimized.
  6. Dec 31, 2017 at 9:19 AM
    Tacoaric
    Dallas, Texas
    Also can’t do a 9 inch wide wheel on a 265. Caster can be corrected with a good alignment.
  7. Dec 31, 2017 at 9:30 AM
    eldedo
    Mojave Desert
    '16 DCSBOR 4X4
    and a pair of UCA's depending on amount of lift.
  8. Dec 31, 2017 at 10:03 AM
    Cdav313
    Cdav313 [OP] Member
    Cool thank you. I have been trying to do as much research as i can here.
  9. Dec 31, 2017 at 11:53 AM
    woohoo_tacos
    woohoo_tacos Well-Known Member
    Atlanta
    2017 TRD off-road 4x4
    3” lift 285/70-17 TRD PRO wheels 17x7
    I run 285/70/R17 and it comes close to rubbing on a 3 inch lift so you might need to do some cutting and possible Cab Chop
    Cdav313[QUOTED][OP] likes this.
