leveling kit help
Discussion in '4 Cylinder' started by conmag, May 16, 2012.
  1. May 17, 2012 at 9:07 AM
    TMW
    TMW Well-Known Member
    Tom
    Bakersfield, CA
    04 Tacoma 4x4 SR5
    Light bar and bumper guard, 3/16 steel skid plates for engine, tranny and transfer box, OME 881 springs with 5100 shocks at mid clip. AAL in rear. Positraction rear diff.
    The spacer (or a 5100 shock set for more height) gives you more lift because of the location of the strut assembly in relation to the control arm/wheel assembly. The strut is closer to the frame so a 1 inch rise there results in a 2 to 2.5 inch rise at the wheel. Think of a teeter-totter, at the center it moves very little compared to the end. It's all a matter of where the strut mounts to the lower control arm.
  2. May 17, 2012 at 5:54 PM
    Canes58
    Canes58 Well-Known Member
    Pensacola
    09 RC 4x 5spd
    magnaflow - k&n - fact alum wheels - back up mirror - intermit wipers - JVC 800 w/focal 165's - oem fogs - 5100's fr & rear.
    Funny thing this site. I just got my 5100's in today and was wondering how to ask which "ring" to use to get 1.75. And here it is. Voila. Thanks guys.
  3. May 17, 2012 at 6:08 PM
    TacoDawgfan
    TacoDawgfan Hunker Down You Hairy Dawg!
    Georgia
    2011 Silver 4x4 TRD Sport w/JBL
    5100's at 1.75, Rear leaf TSB, Moto Metal 951 16x8, BFG TKO2 265/75/16, AFe Stage 2 CAI w/pro dry filter, Kenwood DDX374BT installed with Idatalink Maestro kit, Access Loredo tonneau cover, N-Fab steps, Tinted windows, EGR in channel vent visors, UGA drink coasters in the front cup holders, and a Graco car seat in the back seat
    OP consider the fact that your truck is a 4 cylinder therefore being lighter, you might want to stay at the .85 setting. I'm wanting to do mine but have read conflicting stories on here about the 1.75 setting being nose high unless you have the rear tsb or an aal. And that is with the heavier V6. Plus pending the weight difference, it might make your's ride rougher with less weight. Maybe some with the 4 cylinders can give better input on this?
  4. May 17, 2012 at 9:23 PM
    conmag
    conmag [OP] occasional
    Buffalo, NY
    2013 AC 4cyl 5sp 4x4
    makes sense...hate to sound stupid but being new to this...what exactly is the rear tsb? also i was interested in this setup because i wanted to keep stock wheels and tires and not have to modify anything else or possibly have any negative side effects to the stock parts of the truck...that being said does the rear tsb or aal take it to another level where ill be needing UCA's or making things out of wack and damaging other parts?
  5. May 18, 2012 at 3:11 AM
    TacoDawgfan
    Georgia
    Rear tsb (technical service bulletin) is basically the same thing as an aal (add a leaf) which lifts the rear and strengthens the rear leaf springs. It's a common problem on these trucks with the stock leaf being weak. Toyota may or may not perform the tsb for you, not sure if it's available on the 12's yet. Not sure just how much it lifts the rear, maybe a half inch or so after it settles. Search rear leaf tsb on here and you will learn all about it. But for my truck being a V6 DC it's my understanding that with the rear leaf tsb and 5100's set at 1.75 mine would be level, (I know some on here have this set up) but w/o the tsb I would want to stay at the .85 setting. But I did the floor jack trick in my garage and it looked to be level at about 1 3/4 inches of lift so I'm trying to figure out which setting I want before/if I get the 5100's.
  6. May 18, 2012 at 4:34 AM
    Canes58
    Pensacola
    09 RC 4x 5spd
    After reading about the weight issue with the four cyl me thinks the .85 will be the way to go. I'll keep you posted.
  7. May 18, 2012 at 7:12 AM
    Rmesa1
    Rmesa1 Well-Known Member
    No tsb for 2012 my v6 dcsb came with the updated leafs from the factory
  8. May 18, 2012 at 1:44 PM
    TacoDawgfan
    Georgia
    I'm not sure how much weight difference there is but was a thought.
    I thought it was only the Canadian trucks that came with the 4 leaf?
  9. May 18, 2012 at 1:53 PM
    TacoDawgfan
    Georgia
    So is that the same as the TSB? Just wondering if they sit even higher in the rear?
  10. May 18, 2012 at 2:28 PM
    friction
    friction Well-Known Member
    Charleston, SC
    '08 4X4 RC SR5
    Regular cab here and I am at .85 which is just shy of level (sig pic is before 5100s though).
  11. May 18, 2012 at 6:26 PM
    conmag
    Buffalo, NY
    yea mine is the basic 4 banger access cab 5 speed 4x4...only 3 leafs on mine...starting to feel like the best course of action is the 5100 up front and the add a leaf in the rear, only thing i have read on here is that some people have had issues with the toyo tech AAL...and to go with the wheelers 3 leaf pack? any input on that?
  12. May 18, 2012 at 6:28 PM
    conmag
    Buffalo, NY
    so the TSB is something the dealership does kinda like a recall? or you have to go ask for it?
  13. May 18, 2012 at 6:35 PM
    TacoDawgfan
    Georgia
    You have to go in and complain about your truck riding rough while loaded basically, then they may or may not approve it. Some have gotten it done easily and some had no luck from what I've read. Spend some time searching on here about it and you will find out. It will stiffen up the ride though.
    I want to have mine done partially for the lift but also for the sagging while loaded. I've had mine almost on the bump stops a few times with very little weight and it bothers me.
  14. May 18, 2012 at 6:45 PM
    conmag
    Buffalo, NY
    thanks for the info...my buddy is the one of the F and I guys at the dealership i bought it from so ill see if i can squeeze a favor out of him...it amazing how helpful people are on here and how much info and research you can get done with little effort its great haha
  15. May 19, 2012 at 4:47 AM
    #35
    alexander323bc
    alexander323bc Well-Known Member
    Eric
    Buffalo New York
    4cyl access cab
    I had the TSB done on my 4cylinder last month. Back is now sitting exactly 3 inches higher than the front. I measured from the inside of the fender to the wheel cap and ground. Both measurements gave me a 3 inch difference. ( wheel wheel to the center cap of the tire and from ground to the inside of the fender). I do have a hard cover on the back on the truck. I Just ordered the 5100's now debating the 1.75 or .85 setting. If the ride is going to be worse than stock at 1.75 i might just set them at .85
  16. May 19, 2012 at 1:58 PM
    #36
    conmag
    Buffalo, NY
    where in buffalo do you live i live in south buffalo...also what year is your truck id be very interested to see before and after u do the 5100...which dealership did u go to? i go to basil toyota in lockport
  17. May 19, 2012 at 2:00 PM
    #37
    conmag
    Buffalo, NY
    i have read on here that some people have had issues with the toyo tech AAL...and to go with the wheelers 3 or 4 leaf pack? any input on that?
  18. May 19, 2012 at 3:53 PM
    #38
    silverback
    silverback Well-Known Member
    central CA
    2006 Prerunner SR5
    painted door handles, bilstein 5100's front and back, K&N air filter. Precision power component speakers and Kenwood deck.
    Ive got the 5100's all 4 corners. Set at 1.75 in the front. Perfectly matches the back end height. I have not noticed any ride difference since they have been installed. Ill have to get a few pics up because the one my profile is stock.
    I was also able to stuff 255/75/17 with Fj cruiser wheels. looks good I think.
  19. May 19, 2012 at 4:58 PM
    #39
    Canes58
    Pensacola
    09 RC 4x 5spd
    I just bought FJ wheels, was wondering about the 15mm spacing. Will this set my tires out more or in?
  20. May 19, 2012 at 8:06 PM
    #40
    conmag
    Buffalo, NY
    yea def post a few pics when u get a chance
