leveling kit help!
Discussion in 'Suspension' started by gospurs21, Jan 14, 2014.
  1. Jan 14, 2014 at 11:40 PM
    gospurs21
    gospurs21 [OP] Well-Known Member
    Brownsville, Texas
    05 x2 Cab Texas Edition V6 prerunner, TRD
  2. Jan 15, 2014 at 6:28 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Bilstein 5100's set in the middle setting and call it good.
  3. Jan 15, 2014 at 11:10 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Why do you guys look at that crap on ebay? If you are planning on doing any off-roading with the vehicle, you want to avoid that "all top-spacer lift", as it can lead to suspension component failure down the road.
    What amount of lift are you hoping to go for?
  4. Jan 15, 2014 at 11:52 AM
    gospurs21
    Brownsville, Texas
    I just want a leveling kit, 2" front
  5. Jan 15, 2014 at 11:57 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    bilsteins, 2010 Tacoma 17" alloys w/265's, driveshaft mods, 1.25" hubcentric spacers.
    Bilstein 5100's set @ 1.75"
    Your front end will appreciate it...
  6. Jan 15, 2014 at 1:31 PM
    gospurs21
    Brownsville, Texas
    But i have really good shocks on rn, im on a budget lol i wanna spend around $250 max (including labor)
  7. Jan 15, 2014 at 1:45 PM
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    You have really good shocks :confused:
  8. Jan 16, 2014 at 1:34 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    what brand of shocks right now?
  9. Jan 16, 2014 at 1:41 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate.
    I wouldn't suggest a top spacer lift for anyone. However if all you do is 100% street driving and you just want to level the front end, I say go for it.
    Just don't come back here blaming us if you decide to take your truck off road a few times and shit snaps/breaks. You get what you pay for and that's exactly what you get with a cheap spacer lift.
    Good luck.
  10. Jan 16, 2014 at 6:49 AM
    bldegle2
    bldegle2 OldPhart
    San Francisco, Ca.
    2000 Prerunner TRD
    Either way here are some specs on the alignment, you have to ask, if they won't do it, go to another shop, there are techs in the business that will understand your request...
    Toe 0*
    Camber 0*
    Castor 2.5* if possible...
    Castor is the most important, it helps tremendously with steering wander, especially at speed...
    As far as off road goes, graded unpaved roads are fine, you want to do anything gnarly you might break something (most likely your shocks), and you will be exceeding your $250 quite quickly...
    Your present $250 might be just about what it is going to cost, hopefully you find a tech that will do the both install and alignment...
    GL
  11. Jan 16, 2014 at 7:36 AM
    Tacorriendo
    Tacorriendo Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    Spacers will deteriorate your springs exponentially (faster than normal). I had them while I was saving for bilsteins and 885's. In about three months, the springs sagged 1-1/2". So is your call. If your shock are fairly new, you could get the 885's instead and later get the bilsteins.
  12. Jan 16, 2014 at 8:06 AM
    Mr Salty
    Hermmy
    Lots of chrome
    These are spacers that go on top of the assembled strut simply pushing the entire assembly down. Not sure how this will deteriorate your coils any fast than usual. All it’s really doing is pulling from the available travel in the suspension essentially increasing the angle of both lower and upper control arms as well as drive shafts.
    And for the record eBAY crap is just as good as the crap (spacers) from any other off-road store. A spacer is a spacer and providing the material is adequate (grade of aluminum), dimensional specifications are accurate and hardware is equal to that of factory or better, what does it matter the brand and/or where you buy from.
    Not a fan of spacers at all especially with 4x4s, but they work just fine for a lot of people and as long as you’re not trying to gain too much lift from them they serve the purpose. Bilstiens 5100 actually compress the coils as the ring is moved up, this changes the way the coil responds under pressure and can result in a stiff ride. The plus is you’re not shoving your suspension down more than the factory assembled strut would allow.
    Honestly pic your poison but be modest in your approach (don't adjust the bilstiens to the 2.5 setting and keep the spacers under an 1").
    Just MO
  13. Jan 24, 2014 at 11:06 PM
    gospurs21
    Brownsville, Texas
    thanks alot guys for all the info!!! i usually do only street driving but do fish alot, i dont do major offraoding or anything (prerunner) but do some sand driving rarely on the beach and hit bumps here and there... but ill go the safer way most likely and get the bilsteins
