Leveling kit on off-road 2016 Taco?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by johnwhips, Aug 28, 2016.
  1. Aug 28, 2016 at 3:08 AM
    johnwhips
    johnwhips [OP] Active Member
    Anyone, put a 2" leveling kit on their off-road 3rd gen taco to allow for bigger tires? If so what size tires did it allow for (without rub of coarse). Also, since the 3rd gen OR tacos already have a 1" lift, by putting a 2" leveling kit, do you only have a net gain of 1"? Thanks guys.
  2. Aug 28, 2016 at 4:27 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    265/75 will fit with no mods.
  3. Aug 28, 2016 at 10:43 AM
    amxguy1970
    amxguy1970 Well-Known Member
    Tyler
    Texas
    1st: Nope, no one has ever done that, care to be the first?
    2nd: Search will answer probably the most common question on the forums.
    3rd: Huh? You don't take off the OR suspension, install the basic suspension then add the 2 inch lift, you add it on top of the stock set up. So a 2 inch lift is 2 inches higher than stock regardless or OR or Sport or SR5, ect...
    Tyler
