Leveling Kit or 3 Inch Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TRD Sprt Taco, Oct 16, 2016.
Lift or Level?
  1. 3-4 Inch Lift
    6 vote(s)
    50.0%
  2. Leveling Kit
    6 vote(s)
    50.0%
  1. Oct 16, 2016 at 6:32 AM
    TRD Sprt Taco
    TRD Sprt Taco [OP] Well-Known Member
    2012 Tacoma TRD Sport White DCLB
    Center caps for wheels LEER 100XQ topper
    I have a 2012 DCLB TRD Sport and am looking to level it out or give it a small lift. Obviously, a leveling block in the front is the cheapest option. Does it have any downsides like handling? If I get a lift kit, I am thinking 3-4 inches. At what point do you need to start looking at new Upper Control Arms? My budget would be $1500-2000. What lift kits would you recommend in that price range? Thank you for your help!
    ChadsPride likes this.
  2. Oct 16, 2016 at 6:59 AM
    ChemDawg
    ChemDawg Well-Known Member
    Maine
    2005 sr5 4x4
    Lots of threads on this topic.
    Just keep in mind the more you lift the bigger the gap :rofl:
  3. Oct 16, 2016 at 7:02 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Does your budget include wheels and tires? ..I assume not but just asking.
    At 2.5" and above you need UCAs.
    My .02 cents, do it once and do it right the first time; buy once cry once :thumbsup:
  4. Oct 16, 2016 at 7:05 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    See my link for lifting with spacer to save money. If your shocks are tired then look at the 5100 shocks for lift-no reason to use spacers on a tired suspension
  5. Oct 16, 2016 at 7:48 AM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    2 grand will get you a 3" lift on bilsteins, uca's, a single or 3 leaf AAL and maybe decent sized tires. There won't be a lot leftover for tires though.
  6. Oct 17, 2016 at 12:30 PM
    JStiner
    JStiner Well-Known Member
    11 MGM 4x4 4.0 double cab
    KO2s (32s) with 2inch level
    What size tire are you planning on?
  7. Oct 17, 2016 at 12:40 PM
    oldtoyotaguy
    oldtoyotaguy Well-Known Member
    Peter
    Ontario, Canada
    2018 4 Runner ORP
    Stock but with a Warn 10s winch Used to be a lightly modded Tacoma
    Tacoma's look good with 2-3" lift IMHO. They're a small truck and their proportions are improved when they come up a bit. If you keep a lift moderate, you'll avoid a world of trouble with alignment and vibrations. Buy the best stuff and do it right, and you will maintain the value and integrity of the truck.
  8. Oct 17, 2016 at 12:49 PM
    Clearwater Bill
    Billy
    Largo Florida
    Is the lift for looks or function?
    If function, spend more, enjoy more. Geekhouse23 has it right. Once and done. Personally I'd choose the 2-2.5 range to minimize issues.
    If it's just a looker, well, there will be lots of folks around telling you how wonderful their bargain gear is, that pre-loaded springs function/ride fine, and blocks are as good as sliced bread.
    Just remember how you use the truck 80% of the time. Don't ruin that by building for the other 20% of what you might do someday.
    ChadsPride, Mitch76 and geekhouse23 like this.
  9. Oct 19, 2016 at 10:10 AM
    Mitch76
    Mitch76 Well-Known Member
    Mitch
    San Angelo, TX
    2021 F150 STX 4x4 5.0
    275/65-20 Cooper Discoverer XLT. Borla XR1.
    Not sure if that's an original quote or borrowed from someone...but it's one of the best I've ever heard!
  10. Oct 24, 2016 at 9:51 AM
    TRD Sprt Taco
    Thank you all for the replies!
    If I'm honest with myself, the looks. But I do want it to be functional (I.e. Added ground clearance and suspension travel.)
    Budget does not include wheels and tires. Those are for a later date. Right now I've got the stock 17 inch TRD Sport wheels with 265/70/17 Bridgestone Dueler A/T. They are an inch larger than stock (~31.5 inch diameter). In a perfect world, I'd have a set of the fake Toyota beadlocks in black.
    Agreed!
    33s
    If it was just a 1.5-2inch lift, would you need new UCAs?
    Thank you!
  11. Oct 24, 2016 at 10:49 AM
    geekhouse23
    No.
  12. Oct 24, 2016 at 10:55 AM
    Donttellsean
    Donttellsean Well-Known Member
    Sean
    DCSB White 4x4
    If your budget is that high, I'd skip the spacer. I am putting spacers on because I don't have a higher budget right now. If you decided to do spacers, I read a lot of bad things, but just add a bigger bump stop and you should be okay.
  13. Oct 24, 2016 at 11:11 AM
    PoweredBySoy
    PoweredBySoy Well-Known Member
    Jesse
    Minnesota
    2013 DCSB SR5
    There's a whole lot of ground between "leveling kit" and "4 inches of lift". So I guess you need to decide on what you want.
    imo tires do a lot more for the look of a truck than any lift. And considering your initial budget doesn't include tires, it isn't going to get you very far.
    Get some Bilstein 5100's, OME 884 springs, AAL in the rear - all of which is pretty cheap and still mostly functional. And then save for some C-rated Duratrac's or something. Don't bother with 33's. Get some aggressive looking 32's and you'll be more than happy.
    Also be well aware of the vibration and ECGS bushing thread. You probably won't need it though. Probably.....
  14. Oct 24, 2016 at 3:34 PM
    TacomaMona
    TacomaMona Well-Known Member
    I agree tires make a world of difference cause without the tires, it will look weird
