leveling kit or lift
Discussion in 'Technical Chat' started by bncp88, Sep 28, 2014.
  1. Sep 28, 2014 at 2:52 PM
    bncp88
    bncp88 [OP] Member
    Ben
    Ala
    Tacoma 4X4
    how big of tires can i use with a leveling kit and will it affect the quality of the ride? Please help....
  2. Sep 28, 2014 at 2:57 PM
    G8keepr
    G8keepr Well-Known Member
    Rich
    North central mass
    2017 TRD OR
    Ummmmmmm.......stock size!
  3. Sep 28, 2014 at 3:06 PM
    bncp88
    bncp88 [OP] Member
    Ben
    Ala
    Tacoma 4X4
    I hear that you can move up to a P265/75 16 with the leveling kit only without scrubbing is that true...
  4. Sep 28, 2014 at 3:09 PM
    Poodle Head Mikey
    Poodle Head Mikey Well-Known Member
    2007 Tacoma standard
    utility cap, ladder rack, frame hitch, sliding bed
    Maybe start with telling what model and equipment you are asking about?
    PHM
  5. Sep 28, 2014 at 3:19 PM
    bncp88
    bncp88 [OP] Member
    Ben
    Ala
    Tacoma 4X4
    2014 tacoma double cab 4X4 TRD Off-road
  6. Sep 28, 2014 at 3:29 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    You have much to learn. First from what ive read here from doing searches here. Its not good to use leveling kits and offroad.
    I think you should do searches (Homework) and then repost your question
    Welcome to T.W
  7. Sep 28, 2014 at 3:36 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    personally I like the Tacoma lean if that's why you want to level, but if you want bigger tires you need a lift. and for ride quality? a suspension lift
  8. Sep 28, 2014 at 3:40 PM
    bncp88
    bncp88 [OP] Member
    Ben
    Ala
    Tacoma 4X4
    I don't Plan to do very much off-roading I want looks mostly but with that being said I want it to be done right ... Oh and by the way I thought this was a place to ask questions and get some answers not to be a smart ass...
  9. Sep 28, 2014 at 3:55 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    just buy a suspension lift.... its what you want based on my understanding
  10. Sep 28, 2014 at 4:04 PM
    G8keepr
    Rich
    North central mass
    2017 TRD OR
    TW has been here many years! These questions have been asked and answered. Use the search feature and knowledge you will have.
  11. Sep 28, 2014 at 8:14 PM
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Sorry. ^^
  12. Sep 29, 2014 at 9:32 AM
    Poodle Head Mikey
    Just smile it off - it's just their way of being friendly around here. <g>
    PHM
  13. Sep 29, 2014 at 9:37 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    If you're looking for a lift, but don't want to spend gobs of money, ditch the spacer and look at:
    http://toyteclifts.3dcartstores.com/Bilstein-Adjustable-lift-kit-with-5100-shocks_p_132.html
    This will ride nicer. A majority of people on here run spacers because they're cheap etc then they hate the spacer lift and upgrade. Do it once and do it right!
    Here are also some good links to check out:
    http://www.tacomahq.com/66/tacoma-leveling-lift-kit/
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/345272-why-exactly-front-spacer-lifts-bad.html
  14. Sep 29, 2014 at 2:51 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    with that lift can you still keep the Tacoma lean?
  15. Sep 29, 2014 at 2:57 PM
    geekhouse23
    Rake or lean? I think you mean take but I want to confirm
  16. Sep 29, 2014 at 2:59 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    where the back sits higher than the front. I want 3 inches when I do it in a year, but I like how it handles with the back higher up.
  17. Sep 29, 2014 at 3:03 PM
    geekhouse23
    That's rake. As long as you lift evenly front and rear (I.e. 3" on all four corners) that take will still be there. However, before I got the dakar leaf pack I had a 2" AAL in the rear and after 3k miles, it started to sag causing the "bro lean" where the front is higher than the rear.
  18. Sep 29, 2014 at 3:05 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    how would I get the extra inch in the back?
  19. Sep 29, 2014 at 3:11 PM
    geekhouse23
    I can never and will never recommend spacers; with the exception of top plate spacers in the front. Now, I suggest replacing the whole leaf pack because adding a block, AAL or progressive AAL pack to the existing pack is not a good idea. The stock packs are not built/designed etc that well and those options are bandaids that will lead you to replacing the full leaf pack. The Dakars on their own give 2.75 inches of lift in the rear. They offer a D29XL AAL that you can add for extra load capacity as well as 5mm of extra lift. That is what I have now. The truck sits completely level.
    As for making it stock rake, all I would have to do is remove the half inch top plate spacer in the front. But I like the level look. So you could skip on that spacer and it would have that "raked" look you are trying to achieve.
  20. Sep 29, 2014 at 3:18 PM
    thewarriordinghy
    Ben
    Georgia
    Temporarily Stock
    would it fit 285s, would it be noticeable? and I don't offroad, so would the leafs be bad for the street?
