leveling kit problem
Discussion in 'Suspension' started by obeseclay, Mar 29, 2010.
  1. Mar 29, 2010 at 8:37 PM
    obeseclay
    obeseclay [OP] Member
    clay
    San Rafael,California
    2001 white ext cab 4x4
    I recently purchased a Hell Bent Steel 2.5" front leveling kit online. Everything was going fine in the installation until i tried to put the strut back in with the Hell Bent spacer on top, and it would not fit. Even when pressing the steering knuckle down as far as i could with a pry bar i could not get the struts lower mounting bolt to line up with the mounts. Any suggestions? heres a link to the directions provided http://www.hellbentsteel.com/Instructions/410-000-1001_Toyota_Tacoma_R02.pdf
  2. Mar 29, 2010 at 8:40 PM
    01tacoprerunner
    01tacoprerunner Lifted 'n Locked 4WD Prerunner
    Brian
    Raleigh, NC
    01 4WD Prerunner with No-slip locker
    4WD Conversion, No-slip locker, 5100s set at 2.5" and shackles in the back. Black 2nd gen rims, and Courser M/T tires, Bull Bar,Fog lights, UWS toolbox, CB Radio, Fiberglass antenna, 2nd Gen Badges, Deck Plate Mod, Diff Breather Mod, Sockmonkey decals.
    Did you rotate the strut 180* when you installed it?
  3. Mar 29, 2010 at 8:40 PM
    TacomaDan
    TacomaDan Don't go off ninjin
    Daniel
    Woodland, CA
    1996 Toyota Tacoma Fully Not Loaded
    Love, Cobra 29 LTD BT CB w/ A2000 Highgear antenna, FOX/Fabtech Coilovers, Magnaflow
    Did u disconnect the sway bar?
  4. Mar 29, 2010 at 8:45 PM
    TacomaDan
    Daniel
    Woodland, CA
    I didnt dicso my lower ball joint. I did the upper one becuase the upper control arm does have tension on it when you lower it down. so here's what i would do. I would follow the directions as far as taking out the strut besides disconnecting the lower ball joint. I would disco the sway bar and disco the upper ball joint because i believe that one is easier. Then put the top in first and just get the bolts finger tight. Then pry on the lower control arm and slide the lower strut bolt back in. Then once you have the strut tightened i would place a jack under the lower control arm and jack it up enough until it would be easy to reconnect the upper ball joint! TADA lift installed.
  5. Mar 29, 2010 at 8:46 PM
    obeseclay
    clay
    i rotated the strut 180.. however i did not disconnect the sway bar? i followed Hell bent's directions for installation step by step..
  6. Mar 29, 2010 at 8:49 PM
    TacomaDan
    Daniel
    Woodland, CA
    Disco the sway bar!!!!!!!!!!
  7. Mar 29, 2010 at 8:50 PM
    obeseclay
    clay
    yea i did disconnect the lower ball joint.. but ill try leaving it and disconnecting the sway bar and upper ball joint instead
  8. Mar 29, 2010 at 8:51 PM
    obeseclay
    clay
    thanks for the advice btw :)
  9. Mar 29, 2010 at 8:51 PM
    TacomaDan
    Daniel
    Woodland, CA
    I think it will help out alot. I didnt have any instructions for installing my FOX/Fabtech coilovers and I disconnected the Upper Balljoint and Swaybar and the coilover slid in with a little help from a pry bar on the lower control arm.
    No Problem. Thats what were here for
  10. Mar 29, 2010 at 8:52 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    i put on that exact kit a few months ago. oyu really have to muscle it in. i found it was easiest if you unbolt the sway bar, unbolt the spindle from the LCA, and have a buddy with you...in the instructions they sent with mine, there were two guys doing the installation...i only noticed that after i had struggled through the first side by myself. got my little brother to help with the other side and it was much easier.
    i ran into the same problem. i used a pry bar to get the lower part of the strut (where the hole is) into the general position of the mount on the LCA. then to line up the holes, i wedged a very large flathead screwdriver between the two and pryed at it while my brother tried to push it into place. it just takes some time. be patient and you'll get it done
  11. Mar 29, 2010 at 8:56 PM
    Rustyota
    Rustyota well.....
    Central Coast, CA
    08 4x4 DC long bed
    debadged, rear spring TSB, leveled with Bilstein 5100s at 1.75", Goodyear Duratrac 265/75/r16, Leer shell with Yakima rack
    disconnecting the sway bar is critical. Then the long (5 foot?) pry bar to push the lower arm down. Careful not to tip it off the jack stands... We also needed a jack to push the lower arm up to reconnect everything, just as TacomaDan says.
  12. Mar 29, 2010 at 8:56 PM
    obeseclay
    clay
    good to know im not the only one.. thanks Colin
  13. Mar 29, 2010 at 9:39 PM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    ^^^ no worries....good news is the kit is rock solid once you get it in. i've been very pleased with it.
  14. Aug 25, 2012 at 9:09 PM
    John Reese 92
    John Reese 92 New Member
    Boulder, Colorado
    2004 Tacoma V6 4 speed
    i just bought this same kit recently, the 2.5" spacer, from Hell Bent Steel to put on my '04 Tacoma and had problems getting the shock back in too.
    i found these "better" instructions from ReadyLift and it worked perfectly. then its a piece of cake. you have to loosen the lower control arm bolt to make it fit perfectly. don't need to muscle anything in with a pry bar.
    http://www.readylift.com/files/instructions/66-5050_66-5055_66-5909.pdf
