Leveling kit question why the front?
Discussion in 'Suspension' started by husqvarna 530rr, Jun 4, 2012.
  1. Jun 4, 2012 at 7:34 PM
    husqvarna 530rr
    husqvarna 530rr [OP] Well-Known Member
    oahu hawaii
    sport
    none
    Ok so my basic question is why raise the front to match the rear rather than lower the rear to match the front? I don't need the extra height. In fact lowering the rear a tad seems like a better solution for my needs.
    Thanks in advance. Aloha
  2. Jun 4, 2012 at 7:37 PM
    trdNick
    trdNick Odie
    Texas
    07 Trd Off Road AC PreRunner Grocery Getter
    That would require short, not as beefy leafs, therefore you would loose load capacity and bottom out easier
  3. Jun 4, 2012 at 7:40 PM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Load the bed with a few hundred pounds, problem solved.
  4. Jun 4, 2012 at 7:54 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Depends on the truck.
    For a 5-lug, you have three options. Spacers to raise the front, 4x4/Prerunner leafs to lower the rear, or blocks to lower the rear.
    4x4 and Prerunner do not have the latter two options, and generally, those owners want larger tires so they are looking for more lift.
  5. Jun 4, 2012 at 7:55 PM
    06ryan27
    06ryan27 Well-Known Member
    Aiken, SC
    12 DBL 4x4 SPORT
    3" RBP lift, anytime fogs
    DID THIS GUY JUST ASK THIS???? SMH:notsure:
  6. Jun 4, 2012 at 8:01 PM
    KPT
    09 Prerunner
    What's your point exactly?
  7. Jun 4, 2012 at 9:11 PM
    06ryan27
    Aiken, SC
    12 DBL 4x4 SPORT
    I'm not the kind to lower my truck to level it, If ima level it, ima lift it to accomplish my ultimate goal
  8. Jun 4, 2012 at 9:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    OP has a Sport, lives in Hawaii, doesn't sound like he offroads.
    I'd lower it too. Looks sharp:
    http://tundraracing.com/prerunnerdropkit.htm
  9. Jun 4, 2012 at 10:02 PM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Haha Thanks guys for your help. It's a 2010 extended cab. 2 wheel drive sport. I don't need to go baja'ing in the thing. The most weight it carries it 3 dirtbikes and gear. The only off road it sees it some crappy dirt roads. Maybe a curb check here and there. I'm due for tires so I think I'm going with the bf goodrich ta's KO. 265/70/17's. I'm gonna powdercoat the rims flat black while I'm at it. The whole reason I ask if I can drop the rear to match is because I don't need to carry 3,000lbs and if I drop the back the 2" or whatever it is makes it a tad easier to load bikes and more importantly it's easier on my furry critters to get in and out of.
    Btw why does it matter if I wanta lower my truck? I paid for it. Why did you jack yours up? Only to go to tge gocery store. It's not like I'm slamming it to the ground. It's a inch or two.
  10. Jun 4, 2012 at 10:57 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    Now that I think about it...is there even an option for a leaf pack that lowers the tacomas but provides a stiffer ride to compensate for larger loads??
    Maybe he needs to build his own leaf pack?? Might be a little stiff when riding around town, but should handle the 3 bikes pretty well. Kinda interesting situation, but I'm sure you can make something work!
  11. Jun 4, 2012 at 11:17 PM
    06ryan27
    Aiken, SC
    12 DBL 4x4 SPORT
    Ok, well that does look pretty good, kinda tough and sleek lookin at the same time. The kit they have on that thing looks like it retains factory rear springs, so the question is how to find a kit that just does the rear the same way. So another words a 1.5"-2" in the back instead of the full 3"
  12. Jun 4, 2012 at 11:26 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Dump everything but the main leaf (& yes, dump the overload) Go to the local wrecking yard & look for some early Dodge Dakota springs, minimal ARC, thicker than 'Yota springs, about the same width & these Dakotas are 3/4 ton rated but sit fairly low , load your bikes & call it a day.....
    Shorter leafs = more resistance to compression....;)
    Now whats this about a challenge Brock ???:D
  13. Jun 4, 2012 at 11:30 PM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    This thing is dope!! My wife absolutely hates lowered trucks. I think they can look good as long as they can still use the bed. This is too low for her taste I think
  14. Jun 5, 2012 at 12:38 AM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Wow you guys know your stuff!
  15. Jun 5, 2012 at 7:19 AM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    By dump everything but the leaf you mean what exactly? I and ignorant when it cones to 4 wheel things lol. Give me two wheels or landing gear... I got that shit. Oh and what year dakota leaf springs? I appreciate the help
  16. Jun 5, 2012 at 7:34 AM
    KPT
    09 Prerunner
    He means to take apart the leaf spring pack in the rear, and only reuse the main leaf, the one that connects to the shackle.
  17. Jun 5, 2012 at 9:21 AM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    Ok got it. Then get Dakota springs? Or can I get some fancy springs? Is there anyway to do the math so it will only drop it the 1.5 inches to level it?
  18. Jun 5, 2012 at 9:35 AM
    stowayman
    stowayman Well-Known Member
    Gary
    Monterey, CA
    08 DC 4X4 TRD O/R - Debadged
    Kenwood DNX9980HD Nav - BT - Sirius - backup camera, Weathertech digifits, maglite mod, 14" billet antenna
    just say no!:eek:
  19. Jun 5, 2012 at 10:26 AM
    husqvarna 530rr
    oahu hawaii
    sport
    none
    No to what?
  20. Jun 5, 2012 at 10:32 AM
    rab89
    rab89 Well-Known Member
    Ross
    Kelowna b.c canada
    2012 DCLB
    Grillcraft mx black upper and lower BHLM with Gloss black 265 70 17 bfg a/t center console light mini mag mounted in center console debadged bed lights 35W 5000k HID's
    I'd leave it alone, if you have springs that set you lower, but don't sag, that's because they are stiff leafs, so unloaded it's going to ride like a hard tail.
    With the truck how it is now, im sure it rides nice on the road, and when loaded, sits level and rides very smooth.
