Leveling kit questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mcdowell, Aug 30, 2011.
  1. Aug 30, 2011 at 10:45 AM
    mcdowell
    mcdowell [OP] My name is Mudd
    mike
    mobile al
    2011 prerunner SR5
    2in Toytec leveling kit TSB 4 leafpack 130w KC driving lights Wsetin 3 tab lightbar Black headlights Trex eyelids TRD sport wheels Firestone MT Hood protector Vent visors Tube stepbars Colormatch grille
    Got 2in kit. Talked to local 4x4 shop was told only about 2 of 10 trucks actually need allignment after. ?? Also headlight readjustment? Would such a small lift require this?
  2. Aug 30, 2011 at 10:47 AM
    GeauxTigers
    GeauxTigers //TRD
    Caleb
    Sterlington, Louisiana
    '14 TRD DCSB Off-Road 4x4
    265/70/17 BFG KO2/17"x7" Pro Sema Wheels/OME 884/Bilstein 5100 front & rear/HeadStrong 1/4" TP spacer/Deaver 1.5"-2" AAL/Mud-Flap delete/Westin Bed mat/UltraGauge/ WeatherTechs/AFE Pro Dry Drop in Filter/debadged/AVS in-channel window visors/color-matched OEM grille/Kicker 6.75" Components in front door/Alpine KTP-445U power pack behind factory head unit/
    id say 1 out of 5 need an alignment afterwards :D:D:D
  3. Aug 30, 2011 at 10:50 AM
    NathanielG11
    NathanielG11 Member
    Nate
    Ft. Rucker
    08 Tacoma TRD Off Road
    Weathertech Liners, URD CAI, Flowmaster Exhaust, Kenwood DNX 5120, OME 885's, Bilstien 5100's @ 0, Toytec 2" AAL, Grillecraft, Spidertrax Spacers
    Headlights should be fine.
    However, I would definitely get a front end alignment. I had a 2.5" leveling kit installed when I first lifted my truck and the alignment needed some adjustment. Your better off at least having them check it.
  4. Aug 30, 2011 at 10:53 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    If you lift the front end 2" and do nothing to the back end, how would the headlights be fine? You'll probably be able to see fine yourself but you'll be aimed into oncoming traffic... you should re-align your headlights if you affect the factory rake of the truck.
    Also, that 4x4 shop should know better. You can drive without re-aligning but you could end up chewing up your tires so in the end it'll cost you more money. An alignment is a good idea anytime you mess with the front suspension components.
  5. Aug 30, 2011 at 10:56 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I would do an alignment just to play it safe, I mean why not right? Better safe then sorry. Headlights just mess with those yourself. They are super easy to adjust to your likings and not to blind oncoming traffic. Might want to adjust your fogs to but your should be okay down there.
  6. Aug 30, 2011 at 10:58 AM
    mcdowell
    mike
    mobile al
    2011 prerunner SR5
    Thanks for all the help. Tackle that this weekend.
