leveling kit questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lentsnh, Jan 1, 2009.
  1. Jan 1, 2009 at 7:05 PM
    Lentsnh
    Lentsnh [OP] Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    im about to buy a leveling kit off of eBay but i need to know what level to get (2 in, 2.5 in, 3 in). and will it work with aftermarket suspension kits?
  2. Jan 1, 2009 at 7:41 PM
    Lentsnh
    Help!!
  3. Jan 1, 2009 at 7:48 PM
    WilsonTheDog
    WilsonTheDog Kylie's dad
    Eric
    Myrtle Beach SC
    07 Prerunner SR5 DC/SB V6
    Magnaflow 12576 muffler & chrome tip, Westin step bars, 27% tint, Pop N Lock, AFE ProdryS, bed mat, Husky liners, D-rings added, Access Literider tonneau, Pioneer 4-ways all around, GY Wrangler Duratracs 265/75/16, 5100's @ 1.75", 1.5" AAL
    What do you mean by "aftermarket suspension kits"? Are you talking about a lift kit? If so, you wouldn't need a spacer in the first place because it would be part of the kit.
    FYI: Hellbentsteel.com has a spacer that a few on here have used. It's similar to the Readylift but WAY cheaper ($65/free s&h right now). Basically, you only have to remove the coilover, bolt it on top, and replace it. No spring compressor involved.
    http://hellbentsteel.com/toyota_tacoma_leveling_kits.html
  4. Jan 1, 2009 at 7:52 PM
    Lentsnh
    yeah a lift kit. like do you use it with the lift kit or just separate.
  5. Jan 1, 2009 at 7:52 PM
    WilsonTheDog
    Eric
    Myrtle Beach SC
    Separate. A kit would include everything you'd need to lift it. These are leveling spacers. However, if you raise the front 2.5", more than likely it will be higher than the rear and you'd have to add an AAL or block to level it out. I wish HBS made a 1.5" spacer because that would be just about perfect.
  6. Jan 1, 2009 at 7:57 PM
    Lentsnh
    so it will work with your stock suspension? do you really need a lift kit if you were to get this?
  7. Jan 1, 2009 at 9:22 PM
    MyTaco
    MyTaco Well-Known Member
    Az
    08 Prerunner
    BLHM, Grillcraft grill, painted grill and eyelids. 285/70/17 BFG's on 17x9 Pro Comps 5100's all corners
    Put some 5100 Bilsteins on the front set at 2.5'' and you're good to go.
  8. Jan 1, 2009 at 9:54 PM
    Lentsnh
    what about the back? and the.... coilovers??
  9. Jan 2, 2009 at 7:02 AM
    MyTaco
    Az
    08 Prerunner
    If you're just leveling the back doesnt need anything lift wise. The Billy's use the stock front coils.
  10. Jan 2, 2009 at 8:06 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    I think setting the billys at 1.75 will be the level setting. 2.5 will be a little nose high I believe.
    Anyway, you can use the stock coils with the billys, but it gives you the option to upgrade to the adjustable coilover from ToyTec later. It's designed to work with the 5100s.
  11. Jan 2, 2009 at 8:10 AM
    FlawedXJ
    FlawedXJ mall crawlin', web wheelin', concrete cowboy
    Paul
    NorAla
    13 F150 FX4, 99 jeep xj, 04 msm miata
    I actually have a jeep now. Imagine that.
    just wait for a lift
  12. Jan 2, 2009 at 10:03 AM
    MyTaco
    Az
    08 Prerunner
    Yeah, you're right. Mine was a bit nose high at 2.5" before the rear TSB..now the rear is a bit higher.
