Leveling kit suggestions?
Discussion in 'Suspension' started by bstamas113, Sep 14, 2020.
  1. Sep 14, 2020 at 10:58 AM
    bstamas113
    bstamas113 [OP] New Member
    Brittney
    2013 Toyota Tacoma Prerunner
    265/70R17 tires
    Hey! I'm wanting to lift my truck just a little bit and have been looking into getting a leveling kit. I have a 2013 Prerunner TRD. It's not for crazy off-roading, mainly just for looks. I've seen some that lift the front 3in and the rear 2in. What leveling kits would you guys recommend?
  2. Sep 15, 2020 at 1:31 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Welcome!! Budget? What size tire do you want to run? Wheel? Etc.
  3. Sep 17, 2020 at 8:49 AM
    bstamas113
    Brittney
    265/70R17 tires
    Thank you! I'm probably looking for >$1,000 in total for the job.
  4. Sep 17, 2020 at 9:45 AM
    Dank Donkeh Luvver
    Dank Donkeh Luvver Well-Known Member
    Eric
    Maryland
    2020 TRD OR White 6MT
    OVTune/Coyoza, Eibach Pro Lift, Mobtown Sliders/Skid, Softopper, Martin Offroad Rack
    Bilstein 5100s with OME coils and Headstrong AAL comes in at ~$925 if you have headstrong do the coil assembly preshipment. It'd be around 3 frontand 1-1.5 rear (varies if you keep stock overload in) on your truck depending on spring. You can knock $90 off if you do the coil install yourself.
  5. Sep 17, 2020 at 10:37 AM
    gotoman1969
    If you go three inches in the front you will more than likely need ucas for proper alignment.
