Leveling kit that doesn't kill the ride..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BellyUpFish, Feb 2, 2017.
  1. Feb 11, 2017 at 8:19 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    There is a good reason they have abad rep. Spacer lifts suck and should be avoided like AIDS.
  2. Feb 11, 2017 at 8:23 PM
    Crosis
    Dunedin Fl
    If ride is the most important aspect of your truck, you shouldnt be in a truck. Yes there are better riding trucks but those trucks are not as good as the Taco off road.. where trucks get to be trucks.
  3. Feb 11, 2017 at 8:44 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I bought my spacer lift on Amazon. It arrived and sat in the boxes in my laundry room for a couple of weeks. When I finally got up the gumption to install it, I ripped everything apart one Saturday morning. The front spacer bolt holes wouldn't line up with the three bolts on the top of the struts. I had everything apart and had a lift that didn't fit. I have the TRD Off-Road so it may be different than a stock Tacoma or SR5 BUT my kit said it fit the TRD OR. SO...I spent the next hour calling around seeing if anyone had a front spacer lift that would work. I found a Daystar front 'leveling' kit at the Napa distributor 30 miles away. I went and bought it and installed it in the front and put the spacers from Amazon in the back. By the time I was done, I was in for about $150 more than I'd planned. I just didn't want to button everything back up without being done with it.
    I generally have good luck with Amazon but this one sucked. No store front to take it back to that day.
    Again, I don't want to get into a dick measuring contest here but I'm a Mechanical Engineer from a reputable school, I do ALL of my own maintenance with cars, plumbing, electrical, two stroke carbureators, home remodeling, gunsmithing, home vasectomy kits, etc, etc, etc. I can hear water dripping from the other end of the house. I feel every vibration and hear every noise a vehicle makes. I've diagnosed a mis-adjusted accelerator pump on a carbureator on a 4.3 liter in-board boat engine over the phone.............this spacer lift DID NOT change the ride on my 2014 TRD Off-Road Tacoma.
    You'll get a lot of speculative responses about spacer lifts. I have one and can give my opinion that they work for those of us that are not hard core wheelers.
    On a side note, it's my 52nd birthday and am about six beers into a twelve pack so I may be a little blunt.
    ace96, parsonsjr, kyuss88 and 3 others like this.
  4. Feb 11, 2017 at 8:51 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Happy birthday!
  5. Feb 11, 2017 at 8:56 PM
    winkel
    Corydon, IN
    Why? Axle wrap on the rear end?? Are these 4.0 engines really that powerful?
    I've seen this comment before but why? Mechanically speaking the spacer in the front only changes the angle of the upper and lower control arm and the axle shaft. Bilstein 5100's do the same thing, do they not?
    Beefier coils do the same thing, do they not??
    Justinlhc likes this.
  6. Feb 11, 2017 at 9:02 PM
    winkel
    Corydon, IN
    By the way, I have a set of 2" spacers for the front that don't fit my truck. If anyone is interested in them, PM me and they are yours for the price of shipping. First PM gets them. I have too much crap laying around anyway.
  7. Feb 11, 2017 at 9:12 PM
    winkel
    Corydon, IN
    I put limit straps on the front to keep the UCA's from hitting the coils. The passenger side was the only sided hitting at full droop. As stated earlier, I also added the Toytech shock extenders to the rear. They were about fifteen bucks. For the limit straps, I just marked a point on the shock tower at full droop and drilled the top mounting point an inch higher. I routinely jump a small bridge not far from here. My traction control light flickers when I go over it so I know I'm catching air. The truck lands like a Baja buggy. YMMV.
  8. Feb 11, 2017 at 9:21 PM
    teamfast
    teamfast Get busy living, or get busy dying.
    Winnipeg, Manitoba
    '10 DCLB
    BFG AT TKO2s 34 x 10.5 x17, Leer 550 Tonneau cover, weather tech digi fit liners, Viper 5901 remote start/security, 2" fr spacer, 3" TC AAL, All Pro IFS skid plate, Trans skid plate & Transfer Case skid plate, 12" roof mounted flip down dvd player, In channel vent visors.
    Been rocking a top plate spacer for last 7 years. Couldn't be happier. 2".
  9. Feb 11, 2017 at 9:55 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    Its cold out anyways
  10. Feb 11, 2017 at 10:12 PM
    KILLINTIME
    KILLINTIME Like a Villain
    Do 5100@1.75 and be done with it. I have an ARB bumper with a warn8k with steel cable and it still rides like a Cadillac. about to do full ome 886 /dakars and light racing uca only to get more lift and hold More weight that I'm adding. Otherwise the 5100@1.75 would be fine. You will probably Need the ecgs bushing tho, to fix the driveline vibes.
  11. Feb 11, 2017 at 10:16 PM
    KILLINTIME
    IMG_7953.jpg It's dark but u can see how 5100@1.75 still hold an ARB with warn8k/steel cable pretty damn good.
  12. Feb 12, 2017 at 7:26 AM
    Justinlhc
    Justinlhc Not looking for a relationship
    Dude, you are missing MY point. Don't take this personal or as an insult to your ego. It's my personal opinion that the Tacoma rides like shit. The rear leafs are WELL documented to be pure garbage and most have broken them.
    Having said that, I have still purchased TWO of them. Ride was obviously not THE determining factor in my purchaseS. I'm still allowed to state my opinion that the Tacoma rides like shit compared to other TRUCKS I've driven/owned.
  13. Feb 12, 2017 at 7:29 AM
    Justinlhc
    Please reread my posts. I never said the ride was the most important aspect. It is important though. I find it hard to believe anybody can honestly say the way a vehicle rides isn't at all important to them. o_O
    I love my truck, but I'm not going to act like it's perfect in every way and ignore its flaws just because it's parked in my garage.
  14. Feb 12, 2017 at 7:38 AM
    Juforrest
    Juforrest Dumb!
    Justin
    Seattle
    Reformed Taco driver in a GX460
    15TacoBase likes this.
  15. Feb 12, 2017 at 10:54 PM
    #35
    Jack0928
    Jack0928 Kind of a Well-Known Member
    Jack
    Huntington Beach, CA
    2013 MGM DCSB 4x4
    IG: Jacksoverland
    Go with 5100s, that will most likely fit your budget.
  16. Feb 14, 2017 at 2:36 AM
    #36
    Eduardo Kang
    Eduardo Kang Member
    Baltimore, MD
    2013 Tacoma DCSB TRD ORP
    I'm looking at an ARB bull bar, but concerned about the extra weight. Is the setup you have pictured using the stock front springs with the 5100s set at 1.75? I've wondered if I could do this without having to get heavier springs. I'd be looking less at a lift, more or supporting the front bumper and possibly a winch at stock height.
    Thanks!
  17. Feb 14, 2017 at 4:43 AM
    #37
    KILLINTIME
    Yes, they are the stock springs. They hold the weight fine, after settling they are a little lower than they were before the bumper, but I would say a little above stock height. The ride is no different from what I can tell.
  18. Feb 15, 2017 at 11:14 AM
    #38
    tgear.shead
    tgear.shead Well-Known Member
    Off road is NOT where "trucks get to be trucks".
    That's where PRETENDERS get to PRETEND that their... whatevers... are FOUR WHEELERS.
    Trucks are CARGO MOVERS... for ON the road.
  19. Feb 15, 2017 at 11:42 AM
    #39
    Collins
    Collins Well-Known Member
    North Carolina
    09' Tacoma, 2.7L, 5spd, 4x4
    ftfy...haha...Happy Birthday!!
    btw, while here what is the main differences between a 5100 and a 6112 Billy shock? Thinking of upgrading my shocks
    soon...straight stock suspension with 265/75 16's.
    Thanks.
  20. Feb 15, 2017 at 7:31 PM
    #40
    inwood customs
    Dave
    Cargo vans with large sunroof basically.
